Airplay server as an audio sink?
I know this has been asked before
but things may have changed?
I have a couple of shairport-sync servers and hifiberry cards on raspberry pi (soon also a pi zero) and find it somehow amusing to consider the possibility of playing messages on them for certain events from openHAB. Have anyone been successful in getting this to work somehow? I saw that the shairport-sync server is able to use pulseaudio rather than alsa, which opens up some possibilities for non-apple receivers. But, maybe there is a simpler way???
I’m using the Squeezebox binding and can stream to Squeezelite clients and apple airplay receivers at the same time. It’s another layer to work with, but may be the easiest solution
