Platform information:
- Hardware: Raspberry 2 + RaZberry Z-Wave module
additional: 2x Popp KFOB 4 button remote controls, 4x Philio PST02-1A 4in1 sensors, Aeotec siren gen5, Aeotec 6in1 sensor - OS: Raspian stretch
- Java Runtime Environment: ?
- openHAB version: 2.2 (actual)
Issue of the topic: Log error when saving the 1st .rules -file
*.items file:
Number KFOB_01_Scene "Schluessel1_Szene" <kfob_rc> (Presence, gPresent) {channel="zwave:device:84293c37:node3:scene_number", expire="1s,state=(10 + zwave:device:84293c37:node3:scene_number)" }
Number KFOB_01_Battery "Batterie" <battery> (Presence, gBattery) {channel="zwave:device:84293c37:node3:battery-level"}
Number KFOB_02_Scene "Schluessel2_Szene" <kfob_rc> (Presence, gPresent) {channel="zwave:device:84293c37:node4:scene_number", expire="1s,state=(10 + zwave:device:84293c37:node4:scene_number)" }
Number KFOB_02_Battery "Batterie" <battery> (Presence, gBattery) {channel="zwave:device:84293c37:node4:battery-level"}
Switch sAlarmanlage_aktiv "Alarmanlage_aktiv" <lock> (Presence, gPresent)
Switch sAlarm "A L A R M" <siren> (Presence, gPresent)
*.rules file:
var String alarm_source = null // Text: Alarmauslösender Sensor
rule "Systemstart"
System started
postUpdate(sAlarmanlage_aktiv, OFF)
postUpdate(sAlarm, OFF)
// sendCommand(sAlarmanlage_aktiv, OFF) // ..no sending to binding required for local flag
// sendCommand(sAlarm, OFF) // ..no sending to binding required for local flag
logInfo("Info", "RaZberry gestartet")
rule "Arm" // Scharfschalten
Item "KFOB_01_Scene.state" received update 1 or
Item "KFOB_02_Scene.state" received update 1
// sendCommand(sAlarmanlage_aktiv, ON)
postUpdate(sAlarmanlage_aktiv, ON)
postUpdate(sAlarm, ON)
alarm_source = "Alarmanlage SCHARF geschaltet"
logInfo("Info", "Alarmanlage SCHARF geschaltet")
If (KFOB_01_Scene.state == 1) { KFOB_01_Scene.state = 11 }
If (KFOB_02_Scene.state == 1) { KFOB_02_Scene.state = 11 }
// If (KFOB_01_Scene.state == 1) { KFOB_02_Scene.sendcommand(11) } ?
rule "UnArm" // Entschaerfen
Item "KFOB_01_Scene.state" received update 2 or
Item "KFOB_02_Scene.state" received update 2
alarm_source = "Alarmanlage DEaktiviert"
logInfo("Info", "Alarmanlage DEaktiviert")
If (KFOB_01_Scene.state == 2) { KFOB_01_Scene.state = 22 }
If (KFOB_02_Scene.state == 2) { KFOB_02_Scene.state = 22 }
Log messages:
2018-03-10 14:18:02.431 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'Alarmanlage.rules' has errors, therefore ignoring it: [32,5]: no viable alternative at input '"KFOB_01_Scene.state"'
[33,5]: no viable alternative at input '"KFOB_02_Scene.state"'
[47,5]: no viable alternative at input '"KFOB_01_Scene.state"'
[48,5]: no viable alternative at input '"KFOB_02_Scene.state"'
2018-03-10 14:18:02.715 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'Alarmanlage.rules' has errors, therefore ignoring it: [32,5]: no viable alternative at input '"KFOB_01_Scene.state"'
[48,5]: no viable alternative at input '"KFOB_01_Scene.state"'
[49,5]: no viable alternative at input '"KFOB_02_Scene.state"'
I tried some different version… with/without the .state, different version postUpdate/sendcommand… What do I make wrong? Thankfull for all tips & improvement suggestions!
