var Timer timerAlarm = null
rule "Alarm Clock"
Item AlarmClock changed
Thread::sleep(1000) //for test purpose
if (AlarmClock.state as Number == 0) {
if (timerAlarm !== null) {
timerAlarm.cancel
timerAlarm = null
logInfo("alarm", "All alarms are cancelled")
} else {
var epoch = new DateTime((AlarmClock.state as Number).longValue)
logInfo("alarm", "Scheduling alarm for " + epoch.toString)
logInfo("alarm", "Reschedule alarm")
timerAlarm.reschedule(epoch)
} else {
logInfo("alarm", "New Alarm")
timerAlarm = createTimer(epoch, [ |
// Turn on stuff, e.g. radio or light
VSwitch2.sendCommand(ON)
logInfo("alarm", "alarm is expired")
When I set the Alarm I receive:
2019-12-08 21:31:06.233 [ome.event.ItemCommandEvent] - Item ‘AlarmClock’ received command 1575837120000
2019-12-08 21:31:06.236 [vent.ItemStateChangedEvent] - AlarmClock changed from 0 to 1575837120000
2019-12-08 21:31:07.237 [INFO ] [eclipse.smarthome.model.script.alarm] - Scheduling alarm for 2019-12-08T21:32:00.000+01:00
2019-12-08 21:31:07.238 [INFO ] [eclipse.smarthome.model.script.alarm] - New Alarm
2019-12-08 21:31:25.448 [vent.ItemStateChangedEvent] - CurrentTime changed from 2019-12-08T21:30:25.322+0100 to 2019-12-08T21:31:25.325+0100
2019-12-08 21:31:54.823 [ome.event.ItemCommandEvent] - Item 'AlarmClock' received command 0
2019-12-08 21:31:54.827 [vent.ItemStateChangedEvent] - AlarmClock changed from 1575837120000 to 0
2019-12-08 21:31:55.828 [INFO ] [eclipse.smarthome.model.script.alarm] - All alarms are cancelled
same behavior for AlarmDroid and Samsung Alarm.
the original rule had a “k” inside the lambda part:
[ k |
Light.sendCommand(ON)
but that “k” throws a “Type mismatch: cannot convert from (Object)=>void to Procedure0” in VSC, anyhow it doesn´t work with or without k…
whats wrong?
Android sends shortly (~0,7s) before the actual alarm time the command 0 2020-02-14 19:39:59.269 [ome.event.ItemCommandEvent] - Item 'AlarmClock' received command 0
which will delete reset the timerAlarm.
A Thread::sleep(1000)
before timerAlarm.cancel
will prevent setting the timerAlarm to null, before it can be active. It’s a quick and dirty bug fix and I’m sure there is a more elegant solution.
No, I did not. Currently I cannot see a huge benefit when changing something compared to what I have. my rule is working nicely even with the new App version.
I am at the exact same spot and played around with the rule all morning.
I copy/pasted the rule from the documentation, deleted the “k” in the createtimer section and it worked right away except for the part when canceling a timer.
In that case I would get [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘Alarm Clock’: Could not cast UNDEF to java.lang.Number;
After reading this thread I found out that only some versions of the app create that error!
Phone1: Version 2.12.1 sends the correct value and the rule works.
Phone2: Version 2.12.11 beta sends the UNDEF value
Fortunately I have to use Phone 1 for this application but it would be great to have the bug fixed or find a simple workaround.
Im bumping this one. Trying to get this code to work on my newly setup of Openhab 3 but I can’t get it to work.
This is what I get:
2020-12-29 01:05:40.537 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'EriksAlarmClock' changed from 2020-12-29T09:45:00.000+0000 to UNDEF
2020-12-29 01:05:45.347 [INFO ] [org.openhab.core.model.script.alarm ] - Scheduling alarm for 2020-12-29T10:45:00.000+0100 (1609235100000)
2020-12-29 01:05:45.352 [INFO ] [org.openhab.core.model.script.alarm ] - New alarm
2020-12-29 01:05:45.356 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'static-1' failed: An error occurred during the script execution: null in static
I don’t understand? Is this supported in Openhab 3: createTimer(new DateTime(epoch)
I’ve read about different time conversion but I can’t figure out what I would have to do to get it to work.
No, it is not supported anymore. DateTime was part of Joda library which has been removed and everything has been aligned to use ZonedDateTime. The respective rule in OH3 should be slightly easier than before because you can just pass value of the Item’s state to the createTimer(). I updated it:
DSL (openHAB 3 version)
rule "Alarm Clock"
if( newState instanceof DateTimeType ) {
logInfo("alarm", "Scheduling alarm for {} ({})", newState.toLocaleZone, newState)
if( timerAlarm !== null ) {
timerAlarm.reschedule(newState.toLocaleZone.zonedDateTime)
} else {
logInfo("alarm", "New alarm")
timerAlarm = createTimer(newState.toLocaleZone.zonedDateTime, [ |
// TODO your stuff
logInfo("alarm", "alarm", "Alarm expired")
timerAlarm = null
} else {
timerAlarm.cancel
timerAlarm = null
logInfo("alarm", "Alarm canceled")
Okay I understand. That looks easier than the code I had before.
I tried it but I still get an error:
Script execution of rule with UID 'static-1' failed: An error occurred during the script execution: Could not invoke method: org.openhab.core.model.script.actions.ScriptExecution.createTimer(java.time.ZonedDateTime,org.eclipse.xtext.xbase.lib.Procedures$Procedure0) on instance: null in static
