Update of Yannick SchausMaintainer template to JS Scripting and with the option to use broadcast or sending a command.
This rule template will create a rule that monitors the power consumption of a washing machine (for example, with a smart plug that can report consumption), and either send a boradcast notification or a command to an item when it gets below a threshold, meaning it has finished.
Configuration
| Parameter | Type | Description |
| Power Item | Item | Item that holds the power (in watts) of the washing machine. Can be a quantity type (Number:Power). |
| Threshold | Decimal | When the power measurement was at or above the threshold and crosses below it, trigger the alert. |
| Option | List | Select either to send a command or a broadcast message. |
| Alert Item | Item | Item to send a command to when the measured power gets below the threshold. For instance, a Hue light advanced Alert channel. |
| Alert Field | Text | Broadcast message to be sent or command to send to the alert item (for an item linked to a Hue light alert channel, LSELECT will flash the light for a few seconds). |
Changelog
Version 0.1
- initial release
