Hi!
I want to make Alexa switching my heating and switch on/off intertechno switches. Intertechno is controlled by a CUL and it works in Habpanel so far. Concerning the heating: A couple of days ago it worked when I said: Set Bedroom Temperature to 15 degrees (certainly in german) - Schalte Schlafzimmertemperatur auf 15 Grad - Alexa said “okay”.
Now she´s a bit confused about another item with the same name.
These are my configs:
Group gSchalterWohnraum "Wohnraum Schalter" ["Schalter"]
Group gSchalterFlur "Flur Schalter" [Schalter]
Group gSchalterKinderzimmer "Kinderzimmer Schalter" [Schalter]
Group gSchalterKueche "Kueche Schalter" [Schalter]
//Heizungen
Group gThermoSchlafzimmer "Schlafzimmer Thermostat" ["Thermostat"]
Number Schlafzimmer_SetTemperature "Schlafzimmer Temperatur einstellen" (gThermostat, gThermoSchlafzimmer) [ "TargetTemperature" ]
Number ThermostatSchlafzimmer_Isttemperatur "Aktuelle Schlafzimmer Temperatur" (gThermoSchlafzimmer) [ "CurrentTemperature" ]
String ThermostatSchlafzimmer_ModusDesGerTes "Schlafzimmer Thermostat Heating/Cooling Mode" (gThermoSchlafzimmer) [ "homekit:HeatingCoolingMode" ]
Switch Schlafzimmer_Auto "Schlafzimmer Auto" [ "Switchable" ]
String Schlafzimmer_Vac "Schlafzimmer Vac" [ "Switchable" ]
Contact Fensterkontakt_Schlafzimmer "Fensterkontakt Schlafzimmer"
Group gThermoKueche "Kueche Thermostat" ["Thermostat"]
Number Kueche_SetTemperature "Kuechen Temperatur einstellen" (gThermostat, gThermoKueche) [ "TargetTemperature" ]
Number ThermostatKueche_Isttemperatur "Aktuelle Kuechen Temperatur" (gThermoKueche) [ "CurrentTemperature" ]
String ThermostatKueche_ModusDesGerTes "Kueche Thermostat Heating/Cooling Mode" (gThermoKueche) [ "homekit:HeatingCoolingMode" ]
Contact Fensterkontakt_Kueche "Fensterkontakt Kueche"
Group gThermoBadezimmer "Badezimmer Thermostat" ["Thermostat"]
Number Badezimmer_SetTemperature "Badezimmer Temperatur einstellen" (gThermostat, gThermoBadezimmer) [ "TargetTemperature" ]
Number ThermostatBadezimmer_Isttemperatur "Aktuelle Badezimmer Temperatur" (gThermoBadezimmer) [ "CurrentTemperature" ]
String ThermostatBadezimmer_ModusDesGerTes "Badezimmer Thermostat Heating/Cooling Mode" (gThermoBadezimmer) [ "homekit:HeatingCoolingMode" ]
Contact Fensterkontakt_Badezimmer "Fensterkontakt Badezimmer"
Group gThermoKinderzimmer "Kinderzimmer Thermostat" ["Thermostat"]
Number Kinderzimmer_SetTemperature "Kinderzimmer Temperatur einstellen" (gThermostat, gThermoKinderzimmer) [ "TargetTemperature" ]
Number ThermostatKinderzimmer_Isttemperatur "Aktuelle Kinderzimmer Temperatur" (gThermoKinderzimmer) [ "CurrentTemperature" ]
String ThermostatKinderzimmer_ModusDesGerTes "Kinderzimmer Thermostat Heating/Cooling Mode" (gThermoKinderzimmer) [ "homekit:HeatingCoolingMode" ]
Contact Fensterkontakt_Kinderzimmer "Fensterkontakt Kinderzimmer"
Group gThermoFlur "Flur Thermostat" ["Thermostat"]
Number Flur_SetTemperature "Flur Temperatur einstellen" (gThermostat, gThermoFlur) [ "TargetTemperature" ]
Number ThermostatFlur_Isttemperatur "Aktuelle Flur Temperatur" (gThermoFlur) [ "CurrentTemperature" ]
String ThermostatFlur_ModusDesGerTes "Flur Thermostat Heating/Cooling Mode" (gThermoFlur) [ "homekit:HeatingCoolingMode" ]
Group gThermoWohnraum "Wohnraum Thermostat" ["Thermostat"]
Number Wohnraum_SetTemperature "Wohnraum Temperatur einstellen" (gThermostat, gThermoWohnraum) [ "TargetTemperature" ]
Number ThermostatWohnraum_Isttemperatur "Aktuelle Wohnraum Temperatur" (gThermoWohnraum) [ "CurrentTemperature" ]
String ThermostatWohnraum_ModusDesGerTes "Wohnraum Thermostat Heating/Cooling Mode" (gThermoWohnraum) [ "homekit:HeatingCoolingMode" ]
Contact Fensterkontakt_Balkon "Fensterkontakt Balkon"
/* Mkalender */
String CalDav_Muelltonne "Tonne [%s]" <calendar> { caldavPersonal="calendar:muellkalender type:EVENT eventNr:1 value:NAME" }
DateTime CalDav_Date "Datum der Abholung [%1$td.%1$tm.%1$tY]" <calendar> { caldavPersonal="calendar:muellkalender type:EVENT eventNr:1 value:START" }
DateTime date_today "Heute [%1$td.%1$tm.%1$tY]" <calendar> { channel="ntp:ntp:local:dateTime" }
Switch Glaserschrank "Glaeserschrank" (gSchalterWohnraum) {culintertechno="type=raw;address=FF000F000F;commandOn=FF;commandOff=F0"}
Switch Schrank_Kinderzimmer "Schrankkinderzimmer" (gSchalterKinderzimmer) {culintertechno="type=raw;address=0000F0000F;commandOn=FF;commandOff=F0"}
Switch Tvlampe "TV" (gSchalterWohnraum) {culintertechno="type=raw;address=FF0000000F;commandOn=FF;commandOff=F0"}
Switch Laterne_Diele "Laterne" (gSchalterFlur) {culintertechno="type=raw;address=F000F0000F;commandOn=FF;commandOff=F0"}
Switch Schrank_klein "Schrankklein" (gSchalterWohnraum) {culintertechno="type=raw;address=0F000F000F;commandOn=FF;commandOff=F0"}
Switch Nachtwaechter "Nacht Waechter" (gSchalterWohnraum) {culintertechno="type=raw;address=00000F000F;commandOn=FF;commandOff=F0"}
Switch Schrank_Flur "Schrankflur" (gSchalterFlur) {culintertechno="type=raw;address=000000000F;commandOn=FF;commandOff=F0"}
Switch Decke_Kueche1 "Tischkueche" (gSchalterKueche) {culintertechno="type=raw;address=0F00F0000F;commandOn=FF;commandOff=F0"}
Switch Decke_Kueche2 "Eingangkueche" (gSchalterKueche) {culintertechno="type=raw;address=0F0000000F;commandOn=FF;commandOff=F0"}
What about the CUL? How can I get that work with alexa and Homekit?
@marius3012…it doesn´t work anymore ![]()
