Hi
I’ve discovered that something that used to work prior to OH2.5 seems to no longer work as expected.
I have a rule that at 5pm everyday sends the command Echo_Living_Room_RadioStationId.sendCommand(’’), this simply tells Alexa to stop playing TuneIn radio and is as per the Binding notes. It no longer works as it generates an error
Echo_Living_Room_RadioStationId changed from s12244 to
2020-02-25 15:50:02.948 [vent.ItemStateChangedEvent] - Echo_Living_Room_Radio changed from ON to OFF
2020-02-25 15:50:02.950 [vent.ItemStateChangedEvent] - Echo_Living_Room_Subtitle2 changed from Kitchener, ON to
2020-02-25 15:50:06.091 [ome.event.ItemCommandEvent] - Item 'Echo_Living_Room_RadioStationId' received command
2020-02-25 15:50:06.098 [nt.ItemStatePredictedEvent] - Echo_Living_Room_RadioStationId predicted to become
2020-02-25 15:50:06.297 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@6105f9': POST url 'https://alexa.amazon.ca/api/np/command?deviceSerialNumber=G0xxLF1072451R84&deviceType=A3S5BxxHU6VAYF' failed: Not Found
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://alexa.amazon.ca/api/np/command?deviceSerialNumber=G0xxLF1072451R84&deviceType=A3S5BxxHU6VAYF' failed: Not Found
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:648) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.command(Connection.java:982) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.playRadio(Connection.java:1046) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.handleCommand(EchoHandler.java:569) ~[?:?]
at sun.reflect.GeneratedMethodAccessor245.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy364.handleCommand(Unknown Source) [?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at sun.reflect.GeneratedMethodAccessor246.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
However, performing the same action using the sitemap…
2020-02-25 15:54:12.068 [ome.event.ItemCommandEvent] - Item 'Echo_Living_Room_RadioStationId' received command
2020-02-25 15:54:12.076 [nt.ItemStatePredictedEvent] - Echo_Living_Room_RadioStationId predicted to become
2020-02-25 15:54:12.124 [vent.ItemStateChangedEvent] - Echo_Living_Room_RadioStationId changed from s12244 to
2020-02-25 15:54:13.607 [vent.ItemStateChangedEvent] - Echo_Living_Room_Radio changed from ON to OFF
2020-02-25 15:54:13.611 [vent.ItemStateChangedEvent] - Echo_Living_Room_Player changed from PLAY to PAUSE
No error?
Anyone have any ideas for me to look at?
Could it be related to typecasting - to turn on in the morning I use Echo_Living_Room_RadioStationId.sendCommand(‘s12244’) maybe the (’’) is the thing it doesn’t like
openHab build 2.5.2 Stable
