I’m new to Openhab and for my most of my problems I found a solution/help i this forum. But with this issue I’ve tried pretty much everything I found in the various threads: I just can’t get the Alexa App or my Echo (1st Gen.) to find my item.
Port forwarding: 80 -> 8080
All combinations Pairing on/off <-> with/without IP/Port
Hi Vradatta,
thanks for your anwer, but [ “Lighting” ] was the first thing I tried.
At the moment I’m trying it again (because I’m not sure if the other settings were correct at the first try) but it still doesn’t work. It is detected by the other apps and “http://(ip)/api/testuser/lights?debug=true” always shows the item but Alexa never finds it.
Have you also checked the “description.xml” file as mentioned in the troubleshoot section? The ip or port in there might be wrong. The apps will still work, because they ignore that value and just use the peer network device right away.
