I have set up Alexa to control my openhab items. All but 1 work fine, but the 1 dimmer is not supported by voice (at least that is what Alexa tells me). I have other dimmers and they work fine. The dimmer in question is able to be manually controlled by Alexa (via the app). So I am not sure what exactly the issue is, has anyone else experienced this or managed to troubleshoot it.
Assuming you mean FGD212 there are 2 different entries, depending on firmware level of the dimmer. Perhaps there are differences in the binding configuration.= if you have one of each.
@chris The second device below looks quite different than the first. Group 1 is not controller in the first. The second one has Endpoint 0 switch multilevel set as basic but has no dimmer entry. Suggestions?
Hi, thanks for your help on this, I renamed the item from Lounge to Pantry and rediscovered it with Alexa and amazingly that worked. So I suspect Alexa thinks that Lounge is something else. Not sure what since there are no other devices around with that name.
That is quite normal for the older Fibaro devices. Group 1 being set to the controller was only made standard with the introduction of ZWave+. Before that Fibaro tended to use group 3.
