If logs where generated please post these here using code fences:
2019-11-08 17:49:30.464 [hingStatusInfoChangedEvent] - 'avmfritz:fritzbox:main' changed from UNINITIALIZED to INITIALIZING
2019-11-08 17:49:31.381 [hingStatusInfoChangedEvent] - 'avmfritz:fritzbox:main' changed from INITIALIZING to ONLINE: Established FRITZ!Box connection with SID 4e848xxxxxxxxx
2019-11-08 17:49:31.406 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Bath' changed from UNINITIALIZED to INITIALIZING
2019-11-08 17:49:31.417 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Bath' changed from INITIALIZING to UNKNOWN
2019-11-08 17:49:31.437 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Alex' changed from UNINITIALIZED to INITIALIZING
2019-11-08 17:49:31.445 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Alex' changed from INITIALIZING to UNKNOWN
2019-11-08 17:49:31.490 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Sport' changed from UNINITIALIZED to INITIALIZING
2019-11-08 17:49:31.493 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Sport' changed from INITIALIZING to UNKNOWN
2019-11-08 17:49:31.510 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Living' changed from UNINITIALIZED to INITIALIZING
2019-11-08 17:49:31.515 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Living' changed from INITIALIZING to UNKNOWN
2019-11-08 17:49:31.532 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Toilet' changed from UNINITIALIZED to INITIALIZING
2019-11-08 17:49:31.538 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Toilet' changed from INITIALIZING to UNKNOWN
2019-11-08 17:49:31.552 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Elias' changed from UNINITIALIZED to INITIALIZING
2019-11-08 17:49:31.556 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Elias' changed from INITIALIZING to UNKNOWN
2019-11-08 17:49:31.566 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Parents' changed from UNINITIALIZED to INITIALIZING
2019-11-08 17:49:31.574 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Parents' changed from INITIALIZING to UNKNOWN
I can log into the fritz box with those credentials and the rights are set with smart home to on… so this should not be the issue.
In the fritz box all devices look perfectly normal, have a green light, report all values … the ains in the config are correct, i double checked everything…
This started when i wanted to try a few groups in the fritzbox, to control multiple thermostats the same way. Now i have removed all groups, went back to previous configuration and the still report UNKNOWN.
I tried disabling, back enabling the items… nothing seems to fix it. Does someone maybe have a clue whats going on ?
If your FRITZ!Box recently rebooted the connection between openHAB and the FRITZ!Box is lost.
To reestablish the connection uninstall the AVM binding and install it again…
hmm, ok, i removed the binding and installed it again, but still the same stuff, box gets online, all fritzdects are unknown status…
2019-11-08 20:39:54.309 [thome.event.ExtensionEvent] - Extension 'binding-avmfritz' has been installed.
2019-11-08 20:39:54.593 [hingStatusInfoChangedEvent] - 'avmfritz:fritzbox:main' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-11-08 20:39:55.139 [hingStatusInfoChangedEvent] - 'avmfritz:fritzbox:main' changed from INITIALIZING to ONLINE: Established FRITZ!Box connection with SID 0cb1abae3f89476e
2019-11-08 20:39:55.194 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Bath' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-11-08 20:39:55.200 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Bath' changed from INITIALIZING to UNKNOWN
2019-11-08 20:39:55.208 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Living' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-11-08 20:39:55.211 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Sport' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-11-08 20:39:55.216 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Living' changed from INITIALIZING to UNKNOWN
2019-11-08 20:39:55.231 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Sport' changed from INITIALIZING to UNKNOWN
2019-11-08 20:39:55.255 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Alex' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-11-08 20:39:55.260 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Alex' changed from INITIALIZING to UNKNOWN
2019-11-08 20:39:55.263 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Elias' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-11-08 20:39:55.270 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Toilet' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-11-08 20:39:55.277 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Elias' changed from INITIALIZING to UNKNOWN
2019-11-08 20:39:55.280 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Toilet' changed from INITIALIZING to UNKNOWN
2019-11-08 20:39:55.289 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Play' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-11-08 20:39:55.294 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Play' changed from INITIALIZING to UNKNOWN
2019-11-08 20:39:55.298 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Parents' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2019-11-08 20:39:55.301 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:main:Heat_Parents' changed from INITIALIZING to UNKNOWN
they did work before with exactly the same settings, but at some time they just turned unknown and now i dont know how to bring them back, since i didnt change anything in the configs at all.
I have the same problem, but it appears only for 3 out of 7 thermostats (all 7 worked before, I removed them, re-installed them, reinstalled the Fritz binding and so on - all works fine in the Fritz-UI, but Status is unknown at openhab…)
I uninstalled the fritz- binding, removed all item-files regarding the fritz-devices, re-installed the fritz-binding, and created the item-file again (with the vs-code plugin), device by device. Now it works all again - not sure, what caused the problem.
…and .items files to test the DECT 301 implementation before importing it into my main openhab instance. But both of the the devices’ status is unknown.
2020-04-13 01:15:35.980 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'avm.things'
2020-04-13 01:15:36.101 [hingStatusInfoChangedEvent] - 'avmfritz:fritzbox:192_168_dummy_1' changed from UNINITIALIZED to INITIALIZING
2020-04-13 01:15:37.109 [hingStatusInfoChangedEvent] - 'avmfritz:fritzbox:192_168_dummy_1' changed from INITIALIZING to ONLINE: Established FRITZ!Box connection with SID dummy
2020-04-13 01:15:37.154 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:192_168_dummy_1:Heat_Sleeping' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2020-04-13 01:15:37.172 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:192_168_dummy_1:Heat_Living' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2020-04-13 01:15:38.641 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:192_168_dummy_1:Heat_Sleeping' changed from UNINITIALIZED (DISABLED) to OFFLINE (GONE): Device not present in response
2020-04-13 01:15:38.649 [hingStatusInfoChangedEvent] - 'avmfritz:FRITZ_DECT_301:192_168_dummy_1:Heat_Living' changed from UNINITIALIZED (DISABLED) to OFFLINE (GONE): Device not present in response
2020-04-13 01:15:38.656 [hingStatusInfoChangedEvent] - 'avmfritz:fritzbox:192_168_dummy_1' changed from ONLINE: Established FRITZ!Box connection with SID dummyto ONLINE
Deleted my .item config and reinstalled the binding various times like korny suggested. Obviously, there is a connection to the Fritzbox but the DECT 301’s are only discovered by the PaperUI - the config way does not work, at least for me. Can anyone help? At the moment, I am installing an ioBroker docker for testing purposes because smartheating is a feature I really want to use… but would love if I could stick to Openhab.
Best wishes.
edit
Retried again. Works with adding the things via the PaperUI and using a config for the items. But still… is there any way to get the devices running without the PaperUI?
It looks that the binding is a little bit buggy. I recognized that all values from channels will be shown as unknown when the fritzbox name has been changed!
After a reset of the name the binding will work correctly again. In case you are not allowed to empty this value you can set it to “fritz.box”. That works in my case.
