I have OH running happily on a RPi with openhabian (details below) but want to update to the latest stable version. On several occasions I have tried using openhab-config to update openhabian and OH but every time the update results in an unresponsive system that I’ve been unable to fix.
So instead I have gone back to my good copy of the live install, done an openHAB backup and copied the backup off the device. I then did a completely fresh install on a new SD card of openhabian and went through the basic openhab-config to set passwords, etc. I then copied across the backup and used the OH restore utility to resinstate it all.
During the restore I received a warning that the new configuration would belong to user ‘openhab’ - rather than ‘openhabian’. Not sure if that would be an issue, I went back to the openhab-config and used option 14 - ‘fix permissions’ which reported every time that ‘openhab’ and ‘openhabian’ were both members of all the different groups.
The restore was partly successful: several of my bindings, things, HABpanel configurations, etc. are in place. Tradfri gateway and smart lights are working fine. However zwave and other devices aren’t working. In the log viewer I received several errors :
[ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-gpio, openhab-action-mail, openhab-misc-restdocs, openhab-binding-mqtt1’
In the PaperUI I can see the z-wave controller keeps going online and offline again. In the log viewer I’m seeing:
[INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Connecting to serial port ‘/dev/ttyACM0’
[INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Serial port is initialized
then about 15 seconds later:
[hingStatusInfoChangedEvent] - ‘zwave:serial_zstick:3de03b5f’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
I’m wondering if I’ve misunderstood what the backup can and cannot do. Do I need to manually install bindings? Or do I need to do some Raspi-specific reconfiguration?
- Platform information:
- Hardware: Raspberry Pi 2 Model B V1.1
- OS: openhabian - new install uses openhabian V1.5; used openhab-config to update everything to latest stable
- openHAB version: was 2.2.0-1. New install was updated to latest stable.
Please can you help me work out the best way of resolving this?
Phil
