AllPlay binding problem - runtime corruption?
I’m running 2.3 Stable on Openhabian/RPi and the AllPlay binding has stopped working.
The binding installs nicely but no things or items show up. It looks good in PaperUI and appears ok in Karaf.
openhab> bundle:list -r 223
START LEVEL 100 , List Threshold: 50
 ID │ State  │ Lvl │ Version │ Revisions
223 │ Active │  80 │ 2.3.0   │ [osgi.identity; type="osgi.bundle"; version:Version="2.3.0"; osgi.identity="org.openhab.binding.allplay"; singleton:="
But it doesn’t work and at every restart it spits out errors en masse (see below). My Allplay things have been autodiscovered, everything else is setup with config files.
I have
  • Cleared the cache (sudo openhab-cli clean-cache)
  • Uninstalled the binding, deleted /var/lib/openhab2/tmp/mvn/org/openhab/binding/org.openhab.binding.allplay and reinstalled binding
  • Done a clean install of OH 2.3 on a Windows machine on the same network and the binding works just fine with my hardware
As it works fine in a new installation, I suspect a problem in the runtime files on my RPi. Broken config file, caches or similar.
The RPi system was installed as a fresh OH 2.3 in May so it has not seen major upgrades and has worked nicely so far. I am not sure when this problem appeared as I rarely use the Allplay things.
I have worked extensively in config files (/etc/openhab2)
I would really appreciate any help to pinpoint the problem or propose fixes.
What can I do to clear the any problems with runtime/caches to ensure a clean environment?
Around a dozen errors are logged when the binding is started.
The first one reads:
2018-12-08 22:26:07.308 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryServic
e(243)] The activate method has thrown an exception
java.lang.NoClassDefFoundError: Could not initialize class de.kaizencode.tchaikovsky.AllPlay
        at org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryService.startScan(AllPlaySpeakerDiscoveryService.java:56) ~[?:?]
        at org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryService.startBackgroundDiscovery(AllPlaySpeakerDiscoveryService.java:79) ~[?:?]
        at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.activate(AbstractDiscoveryService.java:381) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
        at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:229) ~[39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39) ~[39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:650) ~[39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:506) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:307) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.ActivateMethod.invoke(ActivateMethod.java:299) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:298) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:109) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:906) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:879) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [39:org.apache.felix.scr:2.0.12]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
        at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
        at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager.java:1829) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeUnbindMethod(SingleComponentManager.java:395) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:375) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:291) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1241) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1136) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:996) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1175) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127) [39:org.apache.felix.scr:2.0.12]
        at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222) [?:?]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:909) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:874) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:139) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterService(AbstractComponentManager.java:951) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:806) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:788) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:580) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:706) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:523) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:439) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.Activator.access$300(Activator.java:54) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:293) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.utils.extender.AbstractExtender$2.run(AbstractExtender.java:285) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.utils.extender.AbstractExtender.destroyExtension(AbstractExtender.java:307) [39:org.apache.felix.scr:2.0.12]
        at org.apache.felix.utils.extender.AbstractExtender.bundleChanged(AbstractExtender.java:181) [39:org.apache.felix.scr:2.0.12]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
        at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
        at org.eclipse.osgi.container.Module.doStop(Module.java:634) [?:?]
        at org.eclipse.osgi.container.Module.stop(Module.java:498) [?:?]
        at org.eclipse.osgi.internal.framework.EquinoxBundle.stop(EquinoxBundle.java:410) [?:?]
        at org.apache.karaf.bundle.command.Restart.doExecute(Restart.java:44) [44:org.apache.karaf.bundle.core:4.1.5]
        at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:52) [44:org.apache.karaf.bundle.core:4.1.5]
        at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) [12:org.apache.karaf.shell.core:4.1.5]
        at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) [12:org.apache.karaf.shell.core:4.1.5]
        at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) [12:org.apache.karaf.shell.core:4.1.5]
        at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:571) [12:org.apache.karaf.shell.core:4.1.5]
        at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:497) [12:org.apache.karaf.shell.core:4.1.5]
        at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:386) [12:org.apache.karaf.shell.core:4.1.5]
        at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:417) [12:org.apache.karaf.shell.core:4.1.5]
        at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) [12:org.apache.karaf.shell.core:4.1.5]
        at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) [12:org.apache.karaf.shell.core:4.1.5]
The following errors come next and are very similar so I don’t copy the full text here. But their first lines are:
2018-12-08 22:26:07.407 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.AllPlayHandlerFactory(244)] The activate method has thrown an exception
2018-12-08 22:26:07.437 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.AllPlayHandlerFactory(244)] The activate method has thrown an exception
2018-12-08 22:26:07.463 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.AllPlayHandlerFactory(244)] The activate method has thrown an exception
2018-12-08 22:26:07.502 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.AllPlayHandlerFactory(244)] The activate method has thrown an exception
2018-12-08 22:26:07.626 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryService(245)] The activate method has thrown an exception
2018-12-08 22:26:07.666 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryService(245)] The activate method has thrown an exception
2018-12-08 22:26:07.718 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryService(245)] The activate method has thrown an exception
2018-12-08 22:26:07.798 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.AllPlayHandlerFactory(246)] The activate method has thrown an exception
2018-12-08 22:26:07.831 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.AllPlayHandlerFactory(246)] The activate method has thrown an exception
2018-12-08 22:26:07.860 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.AllPlayHandlerFactory(246)] The activate method has thrown an exception
2018-12-08 22:26:07.898 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.AllPlayHandlerFactory(246)] The activate method has thrown an exception
2018-12-08 22:26:07.931 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.AllPlayHandlerFactory(246)] The activate method has thrown an exception
2018-12-08 22:26:07.958 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.AllPlayHandlerFactory(246)] The activate method has thrown an exception
You need to capture a debug log.
OK, I’m not 100% how to capture the relevant details but I’ve set the debug levels to
Logger                                             │ Level
ROOT                                               │ WARN
javax.jmdns                                        │ ERROR
org.apache.karaf.jaas.modules.audit                │ INFO
org.apache.karaf.kar.internal.KarServiceImpl       │ ERROR
org.apache.karaf.shell.support                     │ OFF
org.eclipse.smarthome                              │ INFO
org.jupnp                                          │ ERROR
org.openhab                                        │ WARN
org.openhab.binding.allplay                        │ DEBUG
org.openhab.binding.mysensors                      │ INFO
org.openhab.binding.network                        │ WARN
org.openhab.persistence                            │ WARN
org.ops4j.pax.url.mvn.internal.AetherBasedResolver │ ERROR
org.ops4j.pax.web.pax-web-runtime                  │ OFF
smarthome.event                                    │ WARN
smarthome.event.InboxUpdatedEvent                  │ ERROR
smarthome.event.ItemAddedEvent                     │ ERROR
smarthome.event.ItemRemovedEvent                   │ ERROR
smarthome.event.ItemStateChangedEvent              │ DEBUG
smarthome.event.ItemStateEvent                     │ ERROR
smarthome.event.ThingAddedEvent                    │ ERROR
smarthome.event.ThingRemovedEvent                  │ ERROR
smarthome.event.ThingStatusInfoEvent               │ ERROR
Then the log at startup reads:
[edit] (The allplay.things file was empty, later removed it to ensure that is not a problem.)
2018-12-09 07:49:12.840 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '59.39085885211591,17.056682403272905'.
2018-12-09 07:49:12.860 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'sv_SE'.
2018-12-09 07:49:25.108 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'proxy.items'
2018-12-09 07:49:25.265 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'climate.items'
2018-12-09 07:49:25.418 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lightandpower.items'
2018-12-09 07:49:25.618 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Nibe360P.items'
2018-12-09 07:49:25.756 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'groups.items'
2018-12-09 07:49:26.067 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'carheater.items'
2018-12-09 07:49:26.137 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'presence.items'
2018-12-09 07:49:26.949 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2018-12-09 07:49:29.550 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-12-09 07:49:35.627 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'carheater.rules'
2018-12-09 07:49:35.773 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'lastupdates.rules'
2018-12-09 07:49:36.322 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'proxy.rules'
2018-12-09 07:49:36.458 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'lastupdates.rules' is either empty or cannot be parsed correctly!
2018-12-09 07:49:37.119 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'heatpump.sitemap'
2018-12-09 07:49:37.187 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'carheater.sitemap'
2018-12-09 07:49:37.246 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'house.sitemap'
2018-12-09 07:49:37.303 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.sitemap'
2018-12-09 07:49:37.340 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'batteries.sitemap'
2018-12-09 07:49:37.706 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'allplay.things'
2018-12-09 07:49:37.712 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'allplay.things' is either empty or cannot be parsed correctly!
2018-12-09 07:49:37.752 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'network.things'
2018-12-09 07:49:37.935 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mysensors.things'
2018-12-09 07:49:39.869 [WARN ] [.discovery.MySensorsDiscoveryService] - Cannot automatic discover thing node: 0, child: 255 please insert it manually
2018-12-09 07:49:39.946 [INFO ] [al.protocol.ip.MySensorsIpConnection] - Successfully connected to MySensors Bridge.
2018-12-09 07:49:42.318 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-12-09 07:49:43.378 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-12-09 07:49:43.578 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-12-09 07:49:45.808 [DEBUG] [org.openhab.binding.allplay         ] - BundleEvent STARTING - org.openhab.binding.allplay
2018-12-09 07:49:45.834 [DEBUG] [overy.AllPlaySpeakerDiscoveryService] - Starting scan for AllPlay devices
2018-12-09 07:49:45.864 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryService(239)] The activate method has thrown an exception
java.lang.UnsatisfiedLinkError: /var/lib/openhab2/cache/org.eclipse.osgi/223/0/.cp/lib/arm/linux/liballjoyn_java.so: libcrypto.so.1.0.0: cannot open shared object file: No such file or directory
	at java.lang.ClassLoader$NativeLibrary.load(Native Method) ~[?:?]
	at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1941) ~[?:?]
	at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1837) ~[?:?]
	at java.lang.Runtime.loadLibrary0(Runtime.java:870) ~[?:?]
	at java.lang.System.loadLibrary(System.java:1122) ~[?:?]
	at de.kaizencode.tchaikovsky.AllPlay.<clinit>(AllPlay.java:44) ~[?:?]
	at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
	at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
	at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [39:org.apache.felix.scr:2.0.12]
	at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [39:org.apache.felix.scr:2.0.12]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
	at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2018-12-09 07:49:45.943 [DEBUG] [overy.AllPlaySpeakerDiscoveryService] - Starting scan for AllPlay devices
2018-12-09 07:49:45.943 [WARN ] [org.openhab.binding.allplay         ] - FrameworkEvent WARNING - org.openhab.binding.allplay
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
	at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) [?:?]
2018-12-09 07:49:45.953 [ERROR] [org.openhab.binding.allplay         ] - [org.openhab.binding.allplay.internal.discovery.AllPlaySpeakerDiscoveryService(239)] The activate method has thrown an exception
<--- snip --->
Found out what the problem is and how to fix it. Please see this post/thread for the details.
