Raspberry Pi 4 4Gb
Openhabian 3.1.0
Hi, new installation here. Instead of migrating from RaspberryPi3 to 4 i decided to install everything from scratch, to increase my openhabian’s skills…
So, i’ve mounted on my raspberry a folder from my freenas server via NFS under /mnt/backup. The folder works, it mount automatically at boot and user openhabian@backup could write and delete files in it.
After installing amanda via openhabian-config i get no result for backup. The backup should not backup SD card, i would create an another job for that.
This is report i get:
[07:33:13] backup@openhabian:~$ amreport openhab-dir
Hostname: openhabian
Org : openHABian openhab-dir
Config : openhab-dir
Date : ottobre 18, 2021
The next 10 tapes Amanda expects to use are: 10 new tapes.
FAILURE DUMP SUMMARY:
openhabian /var/lib/openhab RESULTS MISSING
openhabian /boot lev 0 FAILED [can't do degraded dump without holding disk]
openhabian /etc lev 0 FAILED [can't do degraded dump without holding disk]
STATISTICS:
Total Full Incr. Level:#
Estimate Time (hrs:min) 0:00
Run Time (hrs:min) 0:00
Dump Time (hrs:min) 0:00 0:00 0:00
Output Size (meg) 0.0 0.0 0.0
Original Size (meg) 0.0 0.0 0.0
Avg Compressed Size (%) -- -- --
DLEs Dumped 0 0 0
Avg Dump Rate (k/s) -- -- --
Tape Time (hrs:min) 0:00 0:00 0:00
Tape Size (meg) 0.0 0.0 0.0
Tape Used (%) 0.0 0.0 0.0
DLEs Taped 0 0 0
Parts Taped 0 0 0
Avg Tp Write Rate (k/s) -- -- --
NOTES:
planner: Adding new disk openhabian:/boot.
planner: Adding new disk openhabian:/etc.
planner: Adding new disk openhabian:/var/lib/openhab.
planner: WARNING: no history available for openhabian:/var/lib/openhab; guessing that size will be 500000 KB
planner: WARNING: no history available for openhabian:/etc; guessing that size will be 500000 KB
planner: WARNING: no history available for openhabian:/boot; guessing that size will be 500000 KB
driver: Taper protocol error
driver: going into degraded mode because of taper component error.
taper: Slot 1 without label can be labeled
DUMP SUMMARY:
DUMPER STATS TAPER STATS
HOSTNAME DISK L ORIG-KB OUT-KB COMP% MMM:SS KB/s MMM:SS KB/s
openhabian /boot FAILED
openhabian /etc FAILED
openhabian /var/lib/openhab MISSING -------------------------------------------
(brought to you by Amanda version 3.5.1)
Backup size in 0 bytes and i get MISSING on /var/lib/openhab folder line.
This is the (big) log i get from var/log for this job:
openhabian@openhabian:~ $ sudo cat /var/log/amanda/openhab-dir/amdump.1
amdump: start at lun ott 18 07:43:58 CEST 2021
amdump: datestamp 20211018
amdump: starttime 20211018074358
amdump: starttime-locale-independent 2021-10-18 07:43:58 CEST
planner: pid 28737 executable /usr/lib/amanda/planner version 3.5.1
planner: build: VERSION="Amanda-3.5.1" BUILT_DATE="" BUILT_MACH=""
planner: BUILT_REV="7557" BUILT_BRANCH="tags" CC="gcc"
planner: paths: bindir="/usr/sbin" sbindir="/usr/sbin"
planner: libexecdir="/usr/lib/amanda"
planner: amlibexecdir="/usr/lib/amanda" mandir="/usr/share/man"
planner: AMANDA_TMPDIR="/tmp/amanda"
planner: AMANDA_DBGDIR="/var/log/amanda" CONFIG_DIR="/etc/amanda"
planner: DEV_PREFIX="/dev/" DUMP="/sbin/dump"
planner: RESTORE="/sbin/restore" VDUMP=UNDEF VRESTORE=UNDEF
planner: XFSDUMP="/sbin/xfsdump" XFSRESTORE="/sbin/xfsrestore"
planner: VXDUMP=UNDEF VXRESTORE=UNDEF
planner: SAMBA_CLIENT="/usr/bin/smbclient" GNUTAR="/bin/tar"
planner: COMPRESS_PATH="/bin/gzip" UNCOMPRESS_PATH="/bin/gzip"
planner: LPR="/usr/bin/lpr" MAILER="/usr/bin/Mail"
planner: listed_incr_dir="/var/lib/amanda/gnutar-lists"
driver: pid 28738 executable /usr/lib/amanda/driver version 3.5.1
planner: defs: DEFAULT_SERVER="localhost" DEFAULT_CONFIG="DailySet1"
planner: DEFAULT_TAPE_SERVER="localhost" DEFAULT_TAPE_DEVICE=""
planner: NEED_STRSTR AMFLOCK_POSIX AMFLOCK_FLOCK AMFLOCK_LOCKF
planner: AMFLOCK_LNLOCK SETPGRP_VOID AMANDA_DEBUG_DAYS=4 BSD_SECURITY
planner: USE_AMANDAHOSTS CLIENT_LOGIN="backup" CHECK_USERID HAVE_GZIP
planner: COMPRESS_SUFFIX=".gz" COMPRESS_FAST_OPT="--fast"
planner: COMPRESS_BEST_OPT="--best" UNCOMPRESS_OPT="-dc"
planner: CONFIGURE_ARGS=" '--build=arm-linux-gnueabihf' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--localstatedir=/var' '--disable-silent-rules' '--libdir=${prefix}/lib/arm-linux-gnueabihf' '--libexecdir=${prefix}/lib/arm-linux-gnueabihf' '--disable-maintainer-mode' '--disable-dependency-tracking' '--prefix=/usr' '--bindir=/usr/sbin' '--libexecdir=/usr/lib/amanda' '--without-amlibexecdir' '--without-amperldir' '--sysconfdir=/etc' '--sharedstatedir=/var/lib' '--localstatedir=/var/lib' '--with-user=backup' '--with-group=backup' '--with-tcpportrange=50000,50100' '--with-udpportrange=840,860' '--with-debugging=/var/log/amanda' '--with-gnutar-listdir=/var/lib/amanda/gnutar-lists' '--with-amandates=/var/lib/amanda/amandates' '--with-index-server=localhost' '--with-bsd-security' '--with-smbclient=/usr/bin/smbclient' '--with-amandahosts' '--with-ssh-security' '--with-bsdtcp-security' '--with-bsdudp-security' '--without-ipv6' '--enable-s3-device' 'build_alias=arm-linux-gnueabihf' 'CFLAGS=-g -O2 -fdebug-prefix-map=/build/amanda-Jk4Jds/amanda-3.5.1=. -fstack-protector-strong -Wformat -Werror=format-security' 'LDFLAGS=-Wl,-z,relro -Wl,-z,now' 'LIBS=-lssl' 'CPPFLAGS=-Wdate-time -D_FORTIFY_SOURCE=2'"
READING CONF INFO...
planner: timestamp 20211018074358
planner: tape_length is set from tape length (6553600 KB) * runtapes (10) == 65536000 KB
planner: time 0.000: startup took 0.000 secs
SENDING FLUSHES...
ENDFLUSH
SETTING UP FOR ESTIMATES...
planner: time 0.001: setting up estimates for openhabian:/boot
openhabian:/boot overdue 18918 days for level 0
setup_estimate: openhabian:/boot: command 0, options: none last_level -1 next_level0 -18918 level_days 0 getting estimates 0 (-3) -1 (-3) -1 (-3)
planner: time 0.001: setting up estimates for openhabian:/etc
reserving 0 out of 0 for degraded-mode dumps
openhabian:/etc overdue 18918 days for level 0
setup_estimate: openhabian:/etc: command 0, options: none last_level -1 next_level0 -18918 level_days 0 getting estimates 0 (-3) -1 (-3) -1 (-3)
planner: time 0.001: setting up estimates for openhabian:/var/lib/openhab
openhabian:/var/lib/openhab overdue 18918 days for level 0
setup_estimate: openhabian:/var/lib/openhab: command 0, options: none last_level -1 next_level0 -18918 level_days 0 getting estimates 0 (-3) -1 (-3) -1 (-3)
planner: time 0.001: setting up estimates took 0.000 secs
GETTING ESTIMATES...
driver: taper taper0 storage openhab-dir tape_size 6553600
driver: started dumper0 pid 28741
driver: send-cmd time 0.005 to dumper0: START 20211018074358
driver: started dumper1 pid 28742
driver: send-cmd time 0.006 to dumper1: START 20211018074358
driver: started dumper2 pid 28743
driver: send-cmd time 0.011 to dumper2: START 20211018074358
driver: started dumper3 pid 28744
driver: send-cmd time 0.013 to dumper3: START 20211018074358
driver: started dumper4 pid 28745
driver: send-cmd time 0.014 to dumper4: START 20211018074358
driver: started dumper5 pid 28746
driver: send-cmd time 0.016 to dumper5: START 20211018074358
driver: started dumper6 pid 28747
driver: send-cmd time 0.018 to dumper6: START 20211018074358
driver: started dumper7 pid 28748
driver: send-cmd time 0.020 to dumper7: START 20211018074358
driver: started dumper8 pid 28749
driver: send-cmd time 0.022 to dumper8: START 20211018074358
driver: started dumper9 pid 28750
driver: send-cmd time 0.024 to dumper9: START 20211018074358
driver: send-cmd time 0.024 to taper0: START-TAPER taper0 worker0-0 openhab-dir 20211018074358
driver: start time 0.024 inparallel 10 bandwidth 90000 diskspace 0 dir OBSOLETE datestamp 20211018074358 driver: drain-ends tapeq FIRST big-dumpers ttt
driver: state time 0.024 free kps: 90000 space: 0 taper: idle idle-dumpers: 10 qlen tapeq taper0: 0:0 runq: 0 directq: 0 roomq: 0 wakeup: 0 driver-idle: not-idle
driver: interface-state time 0.024 if default: free 90000
driver: hdisk-state time 0.024
dumper: pid 28741 executable dumper0 version 3.5.1
dumper: pid 28742 executable dumper1 version 3.5.1
dumper: pid 28749 executable dumper8 version 3.5.1
dumper: pid 28748 executable dumper7 version 3.5.1
dumper: pid 28746 executable dumper5 version 3.5.1
dumper: pid 28745 executable dumper4 version 3.5.1
dumper: pid 28747 executable dumper6 version 3.5.1
dumper: pid 28743 executable dumper2 version 3.5.1
dumper: pid 28744 executable dumper3 version 3.5.1
dumper: pid 28750 executable dumper9 version 3.5.1
planner time 1.804: got result for host openhabian disk /var/lib/openhab: 0 -> 1000000K, -1 -> -3K, -1 -> -3K
planner time 1.804: got result for host openhabian disk /etc: 0 -> 1000000K, -1 -> -3K, -1 -> -3K
planner time 1.805: got result for host openhabian disk /boot: 0 -> 1000000K, -1 -> -3K, -1 -> -3K
driver: state time 2.342 free kps: 90000 space: 0 taper: idle idle-dumpers: 10 qlen tapeq taper0: 0:0 runq: 0 directq: 0 roomq: 0 wakeup: 0 driver-idle: not-idle
driver: interface-state time 2.342 if default: free 90000
driver: hdisk-state time 2.342
driver: result time 2.342 from taper0: TAPER-OK worker0-0 ALLOW-TAKE-SCRIBE-FROM
planner: time 2.905: got partial result for host openhabian disk /var/lib/openhab: 0 -> 1000000K, -1 -> -3K, -1 -> -3K
planner: time 2.905: got partial result for host openhabian disk /etc: 0 -> 1000000K, -1 -> -3K, -1 -> -3K
planner: time 2.905: got partial result for host openhabian disk /boot: 0 -> 1000000K, -1 -> -3K, -1 -> -3K
planner: time 2.958: got result for host openhabian disk /var/lib/openhab: 0 -> 1000000K, -1 -> -3K, -1 -> -3K
planner: time 2.958: got result for host openhabian disk /etc: 0 -> 1000000K, -1 -> -3K, -1 -> -3K
planner: time 2.958: got result for host openhabian disk /boot: 0 -> 1000000K, -1 -> -3K, -1 -> -3K
planner: time 2.959: getting estimates took 2.957 secs
FAILED QUEUE: empty
DONE QUEUE:
0: openhabian /var/lib/openhab
1: openhabian /etc
2: openhabian /boot
ANALYZING ESTIMATES...
pondering openhabian:/var/lib/openhab... next_level0 -18918 last_level -1 (due for level 0) (new disk, can't switch to degraded mode)
curr level 0 nsize 1000000 csize 500000 total size 500099 total_lev0 500000 balanced-lev0size 71428
pondering openhabian:/etc... next_level0 -18918 last_level -1 (due for level 0) (new disk, can't switch to degraded mode)
curr level 0 nsize 1000000 csize 500000 total size 1000132 total_lev0 1000000 balanced-lev0size 142856
pondering openhabian:/boot... next_level0 -18918 last_level -1 (due for level 0) (new disk, can't switch to degraded mode)
curr level 0 nsize 1000000 csize 500000 total size 1500165 total_lev0 1500000 balanced-lev0size 214284
INITIAL SCHEDULE (size 1500165):
openhabian /var/lib/openhab pri 18919 lev 0 nsize 1000000 csize 500000
openhabian /etc pri 18919 lev 0 nsize 1000000 csize 500000
openhabian /boot pri 18919 lev 0 nsize 1000000 csize 500000
DELAYING DUMPS IF NEEDED, total_size 1500165, tape length 65536000 mark 1
delay: Total size now 1500165.
PROMOTING DUMPS IF NEEDED, total_lev0 1500000, balanced_size 214284...
planner: time 2.959: analysis took 0.000 secs
GENERATING SCHEDULE:
DUMP openhabian ffffffff9efefbfffffffffffffff3fffbf71f /var/lib/openhab 20211018074358 18919 0 1970:1:1:0:0:0 1000000 500000 488 1024 "Skipping: new disk can't be dumped in degraded mode"
DUMP openhabian ffffffff9efefbfffffffffffffff3fffbf71f /etc 20211018074358 18919 0 1970:1:1:0:0:0 1000000 500000 488 1024 "Skipping: new disk can't be dumped in degraded mode"
DUMP openhabian ffffffff9efefbfffffffffffffff3fffbf71f /boot 20211018074358 18919 0 1970:1:1:0:0:0 1000000 500000 488 1024 "Skipping: new disk can't be dumped in degraded mode"
driver: flush size 0
driver: send-cmd time 2.967 to taper0: SHM-WRITE worker0-0 00-00001 openhabian /var/lib/openhab 0 20211018074358 "" "" "" "" "" "" "" "" AMANDA
driver: state time 2.967 free kps: 88976 space: 0 taper: writing idle-dumpers: 9 qlen tapeq taper0: 0:0 runq: 0 directq: 2 roomq: 0 wakeup: 0 driver-idle: no-dumpers
driver: interface-state time 2.967 if default: free 88976
driver: hdisk-state time 2.967
driver: state time 2.978 free kps: 88976 space: 0 taper: writing idle-dumpers: 9 qlen tapeq taper0: 0:0 runq: 0 directq: 2 roomq: 0 wakeup: 0 driver-idle: no-dumpers
driver: interface-state time 2.978 if default: free 88976
driver: hdisk-state time 2.978
driver: result time 2.978 from taper0: (eof)
driver: send-cmd time 2.979 to dumper0: ABORT 00-00001 "Taper Failed"
dump of driver schedule before start degraded mode:
dump of driver schedule after start degraded mode:
driver: state time 2.979 free kps: 88976 space: 0 taper: down idle-dumpers: 9 qlen tapeq taper0: 0:0 runq: 0 directq: 2 roomq: 0 wakeup: 0 driver-idle: no-dumpers
driver: interface-state time 2.979 if default: free 88976
driver: hdisk-state time 2.979
Move runq to directq
driver: state time 2.980 free kps: 88976 space: 0 taper: down idle-dumpers: 9 qlen tapeq taper0: 0:0 runq: 0 directq: 2 roomq: 0 wakeup: 0 driver-idle: no-dumpers
driver: interface-state time 2.980 if default: free 88976
driver: hdisk-state time 2.980
driver: state time 2.980 free kps: 88976 space: 0 taper: down idle-dumpers: 9 qlen tapeq taper0: 0:0 runq: 0 directq: 0 roomq: 0 wakeup: 0 driver-idle: no-dumpers
driver: QUITTING time 2.980 telling children to quit
driver: send-cmd time 2.980 to dumper0: QUIT ""
driver: send-cmd time 2.980 to dumper1: QUIT ""
driver: send-cmd time 2.981 to dumper2: QUIT ""
driver: send-cmd time 2.981 to dumper3: QUIT ""
driver: send-cmd time 2.981 to dumper4: QUIT ""
driver: send-cmd time 2.981 to dumper5: QUIT ""
driver: send-cmd time 2.981 to dumper6: QUIT ""
driver: send-cmd time 2.981 to dumper7: QUIT ""
driver: send-cmd time 2.981 to dumper8: QUIT ""
driver: send-cmd time 2.981 to dumper9: QUIT ""
driver: taper0 pid 28739 exited with signal 11
driver: error time 3.004 bug: serial in use: 00-00001
driver: FINISHED time 3.004
amdump: end at lun ott 18 07:44:01 CEST 2021
Any hint?? Are thoso errors reletate to some missing permissions? i can’t understand, i’ve tried to search on google for thoso errors but i had no luck.
PS: i’ve followed the tutorial on the docs, i have enabled no_root_squash
These are the permissions for the folders:
openhabian@openhabian:~ $ ls -all /mnt/backups/
totale 18
drwxrwxr-x 5 backup backup 5 ott 17 11:34 .
drwxr-xr-x 3 root root 4096 ott 17 09:38 ..
drwxrwxr-x 2 backup backup 3 ott 18 02:03 amanda-backups
drwxrwxr-x 4 backup backup 4 ott 17 09:46 Old
drwxrwxr-x 17 backup backup 21 ott 18 07:44 slots
totale 9
drwxr-xr-x 19 root root 4096 ott 18 07:18 ..
drwxrwxr-x 5 backup backup 5 ott 17 11:34 backups
This is the amcheck, that report everything should be ok (only NOTE no warnings);
[07:56:22] backup@openhabian:~$ amcheck openhab-dir
Amanda Tape Server Host Check
slot 1: contains an empty volume
Will write label 'openhab-dir-01' to new volume in slot 1.
NOTE: skipping tape-writable test
NOTE: host info dir '/var/lib/amanda/openhab-dir/curinfo/openhabian' does not exist
It will be created on the next run
NOTE: index dir '/var/lib/amanda/openhab-dir/index/openhabian' does not exist
it will be created on the next run
Server check took 0.786 seconds
Amanda Backup Client Hosts Check
Client check: 1 host checked in 2.893 seconds. 0 problems found.
(brought to you by Amanda 3.5.1)
