Hi all,
I recently realised that Amanda was no longer making backups every night and had not been for around a year eek.
So I went back to the openhabian script and set it up once again.
I have a mounted remote volume I use for backups and all seemed good. but in the last couple of days I noticed the successful looking daily reports have stopped and I am getting unsuccessful reports.
Not wanting a repeat of not having backups for another year I would like to takle this head on, however I am really not sure what the report is telling me.
I get it makes files that it thinks of as virtual tapes . And it rotates the tapes used so that a long period of time is covered.
here is the report, any assistance in what I need to look at would be good. I am wondering if it is unable to delete the files and thus free up the name for reuse??? But really guessing right now.
I will take a look to see if anything in /var/logs provides a clue.
Hostname: openhab
Org : openHABian openhab-dir
Config : openhab-dir
Date : September 12, 2019
These dumps were to tapes openHABian-openhab-dir-015, openHABian-openhab-dir-016.
*** A TAPE ERROR OCCURRED: [No acceptable volumes found].
No dumps are left in the holding disk.
The next 10 tapes Amanda expects to use are: openHABian-openhab-dir-001, openHABian-openhab-dir-002, openHABian-openhab-dir-003, openHABian-openhab-dir-004, openHABian-openhab-dir-005, openHABian-openhab-dir-006, openHABian-openhab-dir-007, openHABian-openhab-dir-008, openHABian-openhab-dir-009, openHABian-openhab-dir-010.
STATISTICS:
Total Full Incr. Level:#
Estimate Time (hrs:min) 0:00
Run Time (hrs:min) 0:00
Dump Time (hrs:min) 0:00 0:00 0:00
Output Size (meg) 325.1 324.9 0.1
Original Size (meg) 325.1 324.9 0.1
Avg Compressed Size (%) 100.0 100.0 100.0
DLEs Dumped 2 1 1 1:1
Avg Dump Rate (k/s) 31070.7 31712.7 588.2
Tape Time (hrs:min) 0:00 0:00 0:00
Tape Size (meg) 325.1 324.9 0.1
Tape Used (%) 119.1 119.0 0.0
DLEs Taped 2 1 1 1:1
Parts Taped 3 2 1 1:1
Avg Tp Write Rate (k/s) 27509.1 27727.5 1300.0
USAGE BY TAPE:
Label Time Size % DLEs Parts
openHABian-openhab-dir-015 0:00 279330k 99.9 2 2
openHABian-openhab-dir-016 0:00 53530k 19.1 0 1
NOTES:
planner: Last full dump of openhab:/etc/openhab2 on tape openHABian-openhab-dir-027 overwritten in 2 runs.
planner: Last full dump of openhab:/var/lib/openhab2 on tape openHABian-openhab-dir-015 overwritten in 1 run.
planner: Last level 1 dump of openhab:/var/lib/openhab2 on tape openHABian-openhab-dir-027 overwritten in 2 runs.
driver: Taper error: "No acceptable volumes found"
taper: Slot 1 with label openHABian-openhab-dir-015 is usable
taper: Slot 2 with label openHABian-openhab-dir-016 is usable
taper: tape openHABian-openhab-dir-015 kb 279330 fm 2 [OK]
taper: Slot 3 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 4 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 5 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 6 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 7 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 8 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 9 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 10 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 11 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 12 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 13 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 14 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: Slot 15 is a volume in error: Error loading device header -- unlabeled volume?, autolabel disabled
taper: tape openHABian-openhab-dir-016 kb 53530 fm 1 [OK]
DUMP SUMMARY:
DUMPER STATS TAPER STATS
HOSTNAME DISK L ORIG-kB OUT-kB COMP% MMM:SS KB/s MMM:SS KB/s
openhab /etc/openhab2 1 130 130 -- 0:00 586.2 0:00 1300.0
openhab /var/lib/openhab2 0 332730 332730 -- 0:10 31710.2 0:12 27727.5
(brought to you by Amanda version 3.3.6)
Paul
