Amanda restore - 500 No dumps available on or before date
  • Platform information:
    Hardware: Raspberry Pi 4 Model B Rev 1.5
    OS: Openhabian
    openHAB 5.2.1 - Release Build
  • Issue of the topic:
    I have installed Amanda and it is doing its regular backup job every night since several weeks.
    The tapes are located on my local NAS and are mounted to the openHAB server.
    Everything looks good so far.
    Today, I have tried a test restore session without success and I am not able to locate the issue.
    Find below what I am doing to restore and the response from Amanda.
    I have tried to repair the index - no change.
[10:11:39] backup@anmahab:/home/openhabian/ama_recover2$ amcheck openhab-dir
Amanda Tape Server Host Check
Searching for label 'openhab-dir-07':found in slot 7: volume 'openhab-dir-07'
Will write to volume 'openhab-dir-07' in slot 7.
NOTE: skipping tape-writable test
Server check took 0.565 seconds
Amanda Backup Client Hosts Check
Client check: 1 host checked in 2.331 seconds.  0 problems found.
(brought to you by Amanda 3.5.1)
[10:12:00] backup@anmahab:/home/openhabian/ama_recover2$ amtape openhab-dir show
scanning all 15 slots in changer:
slot   1: date 20261105010237 label openhab-dir-01
slot   2: date 20261106010030 label openhab-dir-02
slot   3: date 20261107005820 label openhab-dir-03
slot   4: date 20261108010339 label openhab-dir-04
slot   5: date 20261109010232 label openhab-dir-05
slot   6: date 20261110005800 label openhab-dir-06
slot   7: date 20261027010040 label openhab-dir-07
slot   8: date 20261028010429 label openhab-dir-08
slot   9: date 20261029005914 label openhab-dir-09
slot  10: date 20261030005915 label openhab-dir-10
slot  11: date 20261031005512 label openhab-dir-11
slot  12: date 20261101010004 label openhab-dir-12
slot  13: date 20261102010129 label openhab-dir-13
slot  14: date 20261103005612 label openhab-dir-14
slot  15: date 20261104005912 label openhab-dir-15
[10:13:21] backup@anmahab:/home/openhabian/ama_recover2$ amadmin openhab-dir find anmahab /var/lib/openhab
No dump to list
[10:16:07] root@anmahab:/home/openhabian/ama_recover2# amrecover openhab-dir
AMRECOVER Version 3.5.1. Contacting server on localhost ...
220 anmahab AMANDA index server (3.5.1) ready.
Setting restore date to today (2026-11-10)
200 Working date set to 2026-11-10.
200 Config set to openhab-dir.
200 Dump host set to anmahab.
Use the setdisk command to choose dump disk to recover
amrecover> listdisk
200- List of disk for host anmahab
201- /boot
201- /etc
201- /var/lib/openhab
200 List of disk for host anmahab
amrecover> setdisk /etc
200 Disk set to /etc.
500 No dumps available on or before date "2026-11-10"
No index records for disk for specified date
If date correct, notify system administrator
Thanks.
