Amazon Binding - a lot of errors in log file
I don’t know when it started, but everything seems to be running fine. However, my OpenHAB log is filled with errors like this:
The full text is longer, but I’m not sure if it contains credentials, so here’s only the beginning:
2025-03-05 13:53:49.013 [WARN ] [mazonechocontrol.internal.Connection] - Parsing json failed:
<!doctype html><html class="a-no-js a-touch a-mobile" data-19ax5a9jf="mongoose">
  <head>
<script type='text/javascript'>var ue_t0=ue_t0||+new Date();</script>
window.ue_ihb = (window.ue_ihb || window.ueinit || 0) + 1;
if (window.ue_ihb === 1) {
var ue_csm = window,
    ue_hob = +new Date();
(function(d){var e=d.ue=d.ue||{},f=Date.now||function(){return+new Date};e.d=function(b){return f()-(b?0:d.ue_t0)};e.stub=function(b,a){if(!b[a]){var c=[];b[a]=function(){c.push([c.slice.call(arguments),e.d(),d.ue_id])};b[a].replay=function(b){for(var a;a=c.shift();)b(a[0],a[1],a[2])};b[a].isStub=1}};e.exec=function(b,a){return function(){try{return b.apply(this,arguments)}catch(c){ueLogError(c,{attribution:a||"undefined",logLevel:"WARN"})}}}})(ue_csm);
    var ue_err_chan = 'jserr-rw';
(function(d,e){function h(f,b){if(!(a.ec>a.mxe)&&f){a.ter.push(f);b=b||{};var c=f.logLevel||b.logLevel;c&&c!==k&&c!==m&&c!==n&&c!==p||a.ec++;c&&c!=k||a.ecf++;b.pageURL=""+(e.location?e.location.href:"");b.logLevel=c;b.attribution=f.attribution||b.attribution;a.erl.push({ex:f,info:b})}}function l(a,b,c,e,g){d.ueLogError({m:a,f:b,l:c,c:""+e,err:g,fromOnError:1,args:arguments},g?{attribution:g.attribution,logLevel:g.logLevel}:void 0);return!1}var k="FATAL",m="ERROR",n="WARN",p="DOWNGRADED",a={ec:0,ecf:0,
pec:0,ts:0,erl:[],ter:[],buffer:[],mxe:50,startTimer:function(){a.ts++;setInterval(function(){d.ue&&a.pec<a.ec&&d.uex("at");a.pec=a.ec},1E4)}};l.skipTrace=1;h.skipTrace=1;h.isStub=1;d.ueLogError=h;d.ue_err=a;e.onerror=l})(ue_csm,window);
var ue_id = 'xxxxxxxxxxxxxxxxxxxxxxxxxxxx',
    ue_url = '/ap/uedata',
    ue_navtiming = 1,
    ue_mid = 'xxxxxxxxxxxxxxxx',
    ue_sid = '257-xxxxxx-xxxx',
    ue_sn = 'www.amazon.de',
    ue_furl = 'fls-eu.amazon.com',
    ue_surl = 'https://unagi-eu.amazon.com/1/events/com.amazon.csm.nexusclient.prod',
    ue_int = 0,
    ue_fcsn = 1,
    ue_urt = 3,
    ue_rpl_ns = 'cel-rpl',
    ue_ddq = 1,
    ue_fpf = '//fls-eu.amazon.com/1/batch/1/OP/xxxxxxxxxxx:257-xxxxxxxxxxxxx-xxxxx:xxxxxxxxxxxxxxxxxxxx$uedata=s:',
    ue_sbuimp = 1,
    ue_ibft = 0,
    ue_sswmts = 0,
    ue_jsmtf = 0,
    ue_fnt = 0,
    ue_lpsi = 6000,
    ue_no_counters = 0,
    ue_lob = '0',
    ue_sjslob = 0,
I have the same problem since the update to 4.3.3.
System restart with cleaned cache and temp did nothing…
Can anyone help?
i’ve created an bug report on git: [AmazonEchoControl] a lot of Exceptions since 04 march 2025 in openhab log · Issue #18368 · openhab/openhab-addons · GitHub
same issue running OH 2.5 and binding v2.5.12
see here,
