Hi openHAB community,
I need your help. I’m using openHAB 2.0 and I’ve installed the Amazon Dash Button binding (based on master branch 06/12/2017). The first day everything works as expected. But then the button stops working. Does anyone have an idea what the reason might be?
I’ve installed openHAB on a Raspberry Pi 3.
Logs:
2017-05-10 20:20:55.264 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet, use default value: null
2017-05-10 20:20:55.265 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.inet6, use default value: null
2017-05-10 20:20:55.271 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.packet, use default value: null
2017-05-10 20:20:55.272 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.af.link, use default value: null
2017-05-10 20:20:55.332 [INFO ] [org.pcap4j.core.Pcaps ] - 7 NIF(s) found.
2017-05-10 20:20:55.441 [WARN ] [org.pcap4j.util.PropertiesLoader ] - [org/pcap4j/pcap4j.properties] Could not get value by org.pcap4j.dlt.raw, use default value: null
2017-05-10 20:20:55.461 [INFO ] [org.pcap4j.core.PcapHandle ] - Starting loop.
2017-05-10 20:21:18.484 [INFO ] [cap4j.packet.factory.PacketFactories] - Succeeded in FactoryBinder.getInstance()
2017-05-11 07:00:52.023 [INFO ] [org.pcap4j.core.PcapHandle ] - Closed.
Cap settings:
[13:13:55] openhabian@openHABianPi:/var/log/openhab2$ sudo getcap `realpath /usr/bin/java`
/usr/lib/jvm/zulu-embedded-8-armhf/bin/java = cap_net_admin,cap_net_raw+eip cap_net_bind_service+ep
Thing configuration
"statusInfo": {
"status": "ONLINE",
"statusDetail": "NONE"
"label": "Dash Button",
"configuration": {
"packetInterval": 5000,
"macAddress": "88:71:e5:3c:XX:XX",
"pcapNetworkInterfaceName": "wlan0"
"properties": {},
"UID": "amazondashbutton:dashbutton:88-71-e5-3c-XX-XX",
"thingTypeUID": "amazondashbutton:dashbutton",
"channels": [
"linkedItems": [],
"uid": "amazondashbutton:dashbutton:88-71-e5-3c-XX-XX:press",
"id": "press",
"channelTypeUID": "system:trigger",
"kind": "TRIGGER",
"label": "Amazon Dash Button press",
"description": "Amazon Dash Button press",
"defaultTags": [],
"properties": {},
"configuration": {}
"location": "Kammer"
Thanks for your help,
Jonas
