Amazon echo control binding - Bad Request
Hi everybody,
since the first installation of the Amazon Echo Control Binding I am on the hunt for a solution. But I did not find any.
Error discription:
After e.g. asking Alexa to start spotify or anything else, the following error appears in the
openhab.log;
2020-06-07 13:56:21.494 [WARN ] [trol.internal.handler.AccountHandler] - handling of websockets fails
org.openhab.binding.amazonechocontrol.internal.HttpException: GET url 'https://alexa.amazon.de/api/activities?startTime=1591530980166&size=10&offset=1' failed: Bad Request
    at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:644) ~[bundleFile:?]
    at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:499) ~[bundleFile:?]
    at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:494) ~[bundleFile:?]
    at org.openhab.binding.amazonechocontrol.internal.Connection.getActivities(Connection.java:938) ~[bundleFile:?]
    at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.handlePushActivity(AccountHandler.java:773) ~[bundleFile:?]
    at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.handleWebsocketCommand(AccountHandler.java:718) ~[bundleFile:?]
    at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.webSocketCommandReceived(AccountHandler.java:706) [bundleFile:?]
    at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection$Listener.onWebSocketBinary(WebSocketConnection.java:404) [bundleFile:?]
    at org.eclipse.jetty.websocket.common.events.JettyListenerEventDriver.onBinaryMessage(JettyListenerEventDriver.java:103) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.message.SimpleBinaryMessage.messageComplete(SimpleBinaryMessage.java:68) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.events.AbstractEventDriver.appendMessage(AbstractEventDriver.java:65) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.events.JettyListenerEventDriver.onBinaryFrame(JettyListenerEventDriver.java:74) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.events.AbstractEventDriver.incomingFrame(AbstractEventDriver.java:145) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.WebSocketSession.incomingFrame(WebSocketSession.java:321) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.extensions.ExtensionStack.incomingFrame(ExtensionStack.java:202) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.Parser.notifyFrame(Parser.java:226) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.Parser.parseSingleFrame(Parser.java:262) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.readParse(AbstractWebSocketConnection.java:582) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:441) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:428) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:426) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:320) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:158) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
    at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
    at java.lang.Thread.run(Thread.java:748) [?:1.8.0_152]
I tried the installation of Release Candidate and Support: Amazon Echo Control Binding
But no success. Even with the last offical stable binding no silence.
My things:
Bridge amazonechocontrol:account:XXXXXXXX"Amazon Account" @ "Amazon"{
    Thing echospot  SpotSchlaf      "Echo Spot Schlafzimmer"    @   "Amazon"        [serialNumber="XXXXXX"]
    Thing echo      DotWohn         "Echo Dot Wohnzimmer"       @   "Amazon"        [serialNumber="XXXXXX"]
    Thing echo      DotKinder       "Echo Dot Kinder"           @   "Amazon"        [serialNumber="XXXXXX"]
    Thing echoshow  ShowKueche      "Echo Show Küche"           @   "Amazon"        [serialNumber="XXXXXX"]
    Thing echoshow  ShowEssen       "Echo Show Essen"           @   "Amazon"        [serialNumber="XXXXXXX"]
    Thing echo      EchoBad         "Echo Badezimmer"           @   "Amazon"        [serialNumber="XXXXXX"]
    Thing wha       GruppeAlle      "Echo Wohnungsgruppe"        @   "Amazon"        [serialNumber="XXXXXXX"]
Items are similar to the discribed ones in the Binding dicription.
Overall there is no error in the openhan-platform coming up from this.
I just want to now a solution to get rid of this error. Wether by configuration or changing the logging.
Thank you!
The configuration looks good so you can try to filter the logs if everything is working.
Not sure what binding version your using but you can try the latest snapshot found here.
https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/addons/bundles/org.openhab.binding.amazonechocontrol/2.5.6-SNAPSHOT/
Uninstall the binding via PaperUI, then place the jar file in /usr/share/openhab2/addons and restart OH.
tried the snapshot at first, but the same Warn.result. Then tried the filter, but the Alexa request for each item suddenly did not work anymore.
Back to the normal Binding.
Will try log:set INFO for that entry in the openhab-cli.
Thanks for your help! .
