I have succesfully set up my Amazon Account in openhab using the “Amazon Echo Control”- Binding. Unfortunately my Echo device cannot find any of my smarthome devices (already implemented in OH3). Do I have to “tag” the items somehow? If so: where and how?
yes I did but couldn´t find the answer, the documentations are not really end-user friendly.
The forum should be an addition to the documentation at least. Why are you assuming I haven´t read the documentation? For me, as an non english native speaker, it is not an easy task to read and understand technical documentations, so I often need some extra step by step support. Don´t feel adressed if you don´t want to take someone by the hand.
unfortunately the “Amazon Alexa Smart Home Skill” ist not available for OH3.
I added some Metadata to my items like “Lighting” or “Switchable”. That way my devices are discovered and it seems to work.
I installed this skill and I am logged in. As I mentioned above I already discovered my items/devices in Alexa so from my point of view everything works now (still having some trouble with my homematic radiator controllers, but that´s probably some other problem…). So what´s the point here? Am I doing sth. wrong?
first of all: evertyhing fine now?
second: did you add the metadata via the recommended “Metadata” - “Amazon Alexa” way?
because, if you just “tagged” the item with “Lighting”, this is a deprecated functionality and will soon not work anymore.
Really? I did this during the migration from OH2 – OH3 and all is fine.
So a good idea to remove all devices from the alexa app and start add metadata instead of the tagging?
jepp. The tagging still works, but will be removed in some further releases of OH3, which makes sense, because the tagging doesn’t give you complete control over the Alexa-API.
I used the new Metadata way and I can confirm everything works fine now. Of course it´s a change to tag items this way when you have done it textual before. But now I really like the new way.
