- Platform information:
- Hardware: Debian Buster VM 2CPUs at 2Ghz, 2GB Ram, 60GB Hdd
- OS: Debian Buster
- Java Runtime Environment: openjdk version “11.0.12” 2021-07-20
- openHAB version: 3.2.0.M4
- Issue of the topic: I installed Amazon echo control and upon login I get an ssl error. 2FA is turned on. the primary usecase is for Echo to announce when a rule is triggered. Am looking to have openhab use the Echo to announce when a door has been opened etc via rules. The bridge shows online on the GUI but am unable to send anything for the Echo to say. I have reverted to a previous snapshot and tried a few times. It always ends up with the same SSL error. Amazon account shows that the openhab bindsing is installed as a device. Any help would be massively appreciated.
I have manually created a thing with the bridge ID
THINGS
Bridge amazonechocontrol:account:8aca69b423 "Amazon Account" @ "Accounts" [discoverSmartHome=2, pollingIntervalSmartHomeAlexa=30, pollingIntervalSmartSkills=120]
Thing echo MyEcho "Alexa" @ "Living Room" [serialNumber="Serial number of my Echo"]
ITEMS
/// Alexa Echo Control ///
Switch Alexa_Dummy "Alexa Dummy" (Group_Dummy, Power_Switches)
String Echo_Living_Room_Announcement "Announcement" (Alexa_Living_Room) {channel="amazonechocontrol:echo:8aca69b423:MyEcho:announcement"}
String Echo_Living_Room_TTS "Text to Speech" (Alexa_Living_Room) {channel="amazonechocontrol:echo:8aca69b423:MyEcho:textToSpeech"}
Dimmer Echo_Living_Room_TTS_Volume "Text to Speech Volume" (Alexa_Living_Room) {channel="amazonechocontrol:echo:8aca69b423:MyEcho:textToSpeechVolume"}
String Echo_Living_Room_Remind "Remind" (Alexa_Living_Room) {channel="amazonechocontrol:echo:8aca69b423:MyEcho:remind"}
String Echo_Living_Room_PlayAlarmSound "Play Alarm Sound" (Alexa_Living_Room) {channel="amazonechocontrol:echo:8aca69b423:MyEcho:playAlarmSound"}
String Echo_Living_Room_StartRoutine "Start Routine" (Alexa_Living_Room) {channel="amazonechocontrol:echo:8aca69b423:MyEcho:startRoutine"}
Dimmer Echo_Living_Room_NotificationVolume "Notification volume" (Alexa_Living_Room) {channel="amazonechocontrol:echo:8aca69b423:MyEcho:notificationVolume"}
Switch Echo_Living_Room_AscendingAlarm "Ascending alarm" (Alexa_Living_Room) {channel="amazonechocontrol:echo:8aca69b423:MyEcho:ascendingAlarm"}
RULES
rule "Alexa Dummy Changed to off"
Item Alexa_Dummy changed to OFF
Echo_Living_Room_TTS.sendCommand('Hello World')
rule "Alexa Dummy Changed to ON"
Item Alexa_Dummy changed to ON
Echo_Living_Room_TTS.sendCommand('<speak>I want to tell you a secret.<amazon:effect name="whispered">I am not a real human.</amazon:effect>.Can you believe it?</speak>')
//Echo_Living_Room_Announcement.sendCommand('Door opened')
EVENTS
2021-11-30 19:14:49.641 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'amazonechocontrol:account:8aca69b423' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Unsupported or unrecognized SSL message
2021-11-30 19:14:49.641 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'amazonechocontrol:echo:8aca69b423:MyEcho' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2021-11-30 19:14:49.699 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'amazonechocontrol:echo:8aca69b423:MyEcho' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2021-11-30 19:14:50.253 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'amazonechocontrol:account:8aca69b423' changed from OFFLINE (COMMUNICATION_ERROR): Unsupported or unrecognized SSL message to ONLINE
2021-11-30 19:15:50.339 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'amazonechocontrol:account:8aca69b423' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Unsupported or unrecognized SSL message
2021-11-30 19:15:50.341 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'amazonechocontrol:echo:8aca69b423:MyEcho' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2021-11-30 19:15:50.406 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'amazonechocontrol:echo:8aca69b423:MyEcho' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2021-11-30 19:15:50.986 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'amazonechocontrol:account:8aca69b423' changed from OFFLINE (COMMUNICATION_ERROR): Unsupported or unrecognized SSL message to ONLINE
OPENHAB LOG
2021-11-30 19:14:49.638 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/devices-v2/device?cached=false' fails with unknown error
javax.net.ssl.SSLException: Unsupported or unrecognized SSL message
at sun.security.ssl.SSLSocketInputRecord.handleUnknownRecord(SSLSocketInputRecord.java:451) ~[?:?]
at sun.security.ssl.SSLSocketInputRecord.decode(SSLSocketInputRecord.java:175) ~[?:?]
at sun.security.ssl.SSLTransport.decode(SSLTransport.java:111) ~[?:?]
at sun.security.ssl.SSLSocketImpl.decode(SSLSocketImpl.java:1426) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readHandshakeRecord(SSLSocketImpl.java:1336) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:450) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:421) ~[?:?]
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:572) ~[?:?]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:197) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1592) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1520) ~[?:?]
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:527) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:334) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:639) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:555) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:550) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getDeviceListJson(Connection.java:1043) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getDeviceList(Connection.java:1033) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.updateDeviceList(AccountHandler.java:616) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:506) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.checkData(AccountHandler.java:455) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
2021-11-30 19:14:49.693 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/wake-word?cached=true' fails with unknown error
at org.openhab.binding.amazonechocontrol.internal.Connection.getWakeWords(Connection.java:986) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.updateDeviceList(AccountHandler.java:627) ~[?:?]
2021-11-30 19:14:49.697 [INFO ] [mazonechocontrol.internal.Connection] - getting wakewords failed
2021-11-30 19:14:49.751 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/device-notification-state' fails with unknown error
at org.openhab.binding.amazonechocontrol.internal.Connection.getDeviceNotificationStates(Connection.java:1235) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:516) ~[?:?]
2021-11-30 19:14:49.753 [INFO ] [mazonechocontrol.internal.Connection] - Error getting device notification states
2021-11-30 19:14:49.810 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/ascending-alarm' fails with unknown error
at org.openhab.binding.amazonechocontrol.internal.Connection.getAscendingAlarm(Connection.java:1247) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:519) ~[?:?]
2021-11-30 19:14:49.811 [INFO ] [mazonechocontrol.internal.Connection] - Error getting device notification states
2021-11-30 19:14:49.866 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/bluetooth?cached=true' fails with unknown error
at org.openhab.binding.amazonechocontrol.internal.Connection.getBluetoothConnectionStates(Connection.java:1136) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:522) ~[?:?]
2021-11-30 19:14:49.937 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/behaviors/entities?skillId=amzn1.ask.1p.music' fails with unknown error
at org.openhab.binding.amazonechocontrol.internal.Connection.getMusicProviders(Connection.java:1970) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:527) ~[?:?]
2021-11-30 19:14:49.939 [WARN ] [mazonechocontrol.internal.Connection] - getMusicProviders fails: Unsupported or unrecognized SSL message
2021-11-30 19:14:49.963 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-30 19:14:50.000 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/notification/sounds?deviceSerialNumber=MyEchoSerialNumberremoved&deviceType=A3FX4UWTP28V1P&softwareVersion=6208506244' fails with unknown error
at org.openhab.binding.amazonechocontrol.internal.Connection.getNotificationSounds(Connection.java:1912) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:542) ~[?:?]
2021-11-30 19:14:50.058 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/cloudplayer/playlists?deviceSerialNumber=MyEchoSerialNumberremoved&deviceType=A3FX4UWTP28V1P&mediaOwnerCustomerId=APNJ8EU5WIBNF' fails with unknown error
at org.openhab.binding.amazonechocontrol.internal.Connection.getPlaylists(Connection.java:1147) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:548) ~[?:?]
2021-11-30 19:14:50.124 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/equalizer/MyEchoSerialNumberremoved/A3FX4UWTP28V1P' fails with unknown error
at org.openhab.binding.amazonechocontrol.internal.Connection.getEqualizer(Connection.java:2033) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.updateEqualizerState(EchoHandler.java:1161) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.updateState(EchoHandler.java:841) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:571) ~[?:?]
2021-11-30 19:14:50.183 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/np/player?deviceSerialNumber=MyEchoSerialNumberremoved&deviceType=A3FX4UWTP28V1P&screenWidth=1440' fails with unknown error
at org.openhab.binding.amazonechocontrol.internal.Connection.getPlayer(Connection.java:1107) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.updateState(EchoHandler.java:851) ~[?:?]
2021-11-30 19:14:50.185 [INFO ] [control.internal.handler.EchoHandler] - getPlayer fails
2021-11-30 19:14:50.250 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.co.uk/api/notifications' fails with unknown error
at org.openhab.binding.amazonechocontrol.internal.Connection.notifications(Connection.java:1920) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshNotifications(AccountHandler.java:478) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:576) ~[?:?]
