Amazon Echo Control binding
I there.
I see many, many of this kind of WARN logs in openhab.log :
2020-05-20 16:32:36.670 [WARN ] [trol.internal.handler.AccountHandler] - handling of websockets fails
org.openhab.binding.amazonechocontrol.internal.HttpException: GET url 'https://alexa.amazon.fr/api/activities?startTime=1589985156393&size=10&offset=1' failed: Bad Request
	at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:644) ~[bundleFile:?]
	at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:499) ~[bundleFile:?]
	at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:494) ~[bundleFile:?]
	at org.openhab.binding.amazonechocontrol.internal.Connection.getActivities(Connection.java:938) ~[bundleFile:?]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.handlePushActivity(AccountHandler.java:773) ~[bundleFile:?]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.handleWebsocketCommand(AccountHandler.java:718) ~[bundleFile:?]
	at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.webSocketCommandReceived(AccountHandler.java:706) [bundleFile:?]
	at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection$Listener.onWebSocketBinary(WebSocketConnection.java:404) [bundleFile:?]
	at org.eclipse.jetty.websocket.common.events.JettyListenerEventDriver.onBinaryMessage(JettyListenerEventDriver.java:103) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.message.SimpleBinaryMessage.messageComplete(SimpleBinaryMessage.java:68) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.events.AbstractEventDriver.appendMessage(AbstractEventDriver.java:65) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.events.JettyListenerEventDriver.onBinaryFrame(JettyListenerEventDriver.java:74) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.events.AbstractEventDriver.incomingFrame(AbstractEventDriver.java:145) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.WebSocketSession.incomingFrame(WebSocketSession.java:321) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.extensions.ExtensionStack.incomingFrame(ExtensionStack.java:202) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.Parser.notifyFrame(Parser.java:226) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.Parser.parseSingleFrame(Parser.java:262) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.readParse(AbstractWebSocketConnection.java:582) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:441) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:428) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:426) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:320) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:158) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_151]
I saw some references to the same error log in the forum but quite old posts. I think this appeared since some weeks. Currently, I’m on OH 2.5.4 with snapshot releases (refrained myself to update to 2.5.5).
I also get this kind of unattended log :
2020-05-20 21:35:00.408 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@2ebbcb65': POST url 'https://alexa.amazon.fr/api/behaviors/preview' failed: Too Many Requests
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://alexa.amazon.fr/api/behaviors/preview' failed: Too Many Requests
	at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:644) ~[?:?]
	at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceNode(Connection.java:1186) ~[?:?]
	at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceCommand(Connection.java:1171) ~[?:?]
	at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.handleCommand(EchoHandler.java:387) ~[?:?]
	at sun.reflect.GeneratedMethodAccessor63.invoke(Unknown Source) ~[?:?]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_151]
	at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_151]
	at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
	at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
	at com.sun.proxy.$Proxy50902.handleCommand(Unknown Source) [?:?]
	at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
	at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_151]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_151]
	at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
	at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_151]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_151]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_151]
Swtched to iobroker to be uptodate with all the alexa function. Just send to value to your system or viseversa
Sorry, I do not get the meaning of your post.
This binding didn’t have any update since 5-6 months.
But on the amazon side the api has changed…so things breaks.
Do you face same errors ? If so, I may open an issue in Github.
I have as well:
2020-06-07 14:50:02.309 [WARN ] [trol.internal.handler.AccountHandler] - handling of websockets fails
org.openhab.binding.amazonechocontrol.internal.HttpException: GET url 'https://alexa.amazon.it/api/activities?startTime=1591534202065&size=10&offset=1' failed: Bad Request
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_252]
See also:
https://community.openhab.org/t/web-socket-error-on-amazonechocontrol-binding-every-65-seconds
I have tried for a year now to get iobroker to work on my Debian 10-based machine but have never been successful. I’ve spent many hours trying to get it to work without success, but I will try again…
I’ve used this binding in the past without issue but I have recently built a new server (Ubuntu 20.04 running Docker) and updated my OpenHab container to 2.5.8. I’m now going through the process of setting up my Amazon Echo Control binding but I’m running into an issue. When I go to http://192.168.xxx.xxx:8080/amazonechocontrol, get to the account login, and enter username and password the login is accepted. After accepting I receive a notification on my phone about suspicious attempt for which I accept. But… The login screen closes after only a few seconds (before I can accept the suspicion warning). This now puts me in a loop of attempting to login, login page only waits a few seconds before going back to asking for credentials again. Any suggestions? I’m hoping I’m overlooking something.
In bad need of a fix as well… with covid, my small retail business is short staffed and we use Alexa to announce customers entering the store and we can’t hear them if we are in the back…I know there are lower-tech solutions, but this is what we have built for now…
I’m having this problem now as well. It just keeps telling me the email or phone number (username) is invalid, which it is clearly not.
I had the same issue when I migrated from PI3 to PI4. I could solve the issue by un installing the ECHO binding modifying the thing file and installing ECHO binding again.
I changed the thing file from
Bridge amazonechocontrol:account:account1 “Amazon Account” @ “Accounts”
into
Bridge amazonechocontrol:account:accountXXX “Amazon Account” @ “Accounts”
I have a new problem with the binding - am I the only one? I get the following warning:
[WARN ] [mazonechocontrol.internal.Connection] - Parsing json failed
com.google.gson.JsonSyntaxException: java.lang.NumberFormatException: For input string: “1:1397661542”
at com.google.gson.internal.bind.TypeAdapters$7.read(TypeAdapters.java:227) ~[?:?]
at com.google.gson.internal.bind.TypeAdapters$7.read(TypeAdapters.java:217) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$1.read(ReflectiveTypeAdapterFactory.java:129) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:220) ~[?:?]
at com.google.gson.internal.bind.TypeAdapterRuntimeTypeWrapper.read(TypeAdapterRuntimeTypeWrapper.java:41) ~[?:?]
at com.google.gson.internal.bind.ArrayTypeAdapter.read(ArrayTypeAdapter.java:72) ~[?:?]
at com.google.gson.internal.bind.MapTypeAdapterFactory$Adapter.read(MapTypeAdapterFactory.java:187) ~[?:?]
at com.google.gson.internal.bind.MapTypeAdapterFactory$Adapter.read(MapTypeAdapterFactory.java:145) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:888) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:853) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:802) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:774) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.parseJson(Connection.java:966) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getPlaylists(Connection.java:1131) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:552) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshAfterCommand(AccountHandler.java:830) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_252]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_252]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_252]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_252]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_252]
Caused by: java.lang.NumberFormatException: For input string: “1:1397661542”
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:2043) ~[?:1.8.0_252]
at sun.misc.FloatingDecimal.parseDouble(FloatingDecimal.java:110) ~[?:1.8.0_252]
at java.lang.Double.parseDouble(Double.java:538) ~[?:1.8.0_252]
at com.google.gson.stream.JsonReader.nextInt(JsonReader.java:1201) ~[?:?]
at com.google.gson.internal.bind.TypeAdapters$7.read(TypeAdapters.java:225) ~[?:?]
and
[mazonechocontrol.internal.Connection] - Illegal json: {“playlists”:{“10”:[{“entryList”:null,“playlistId”:
Does anyone have similar problems? It happens since today in the morning… No clue what this "Input string is? I have already installed the binding new.
Crisyoph_Holler I’m getting bothered same error as of yesterday. Any find a solution?
I’m unable to locate the fie you are referring to. Should it be in the things folder?
My OpenHab installation is via a Docker container.
It is only a things file if you set it up to be in a thing file. In case you used the installation via GUI then it is not in a thing file.
I had the Bridge configuration in a thing file on the PI3. When I migrated to the PI4 the thing file was migrated too … but possibly not all required data like a “password token”.
I assume that during the migration to a different device (or different installation) not all required data was restored with the OH backup to my PI4. After the OH migration from the PI3 to the PI4 the Echo binding tried to login to Amazon with the “amazonechocontrol:account:account 1” defined on the PI3 … but I got a login error because the “password token” (or something like that) was not on the PI4. So I had to define a new account name “amazonechocontrol:account:account XXX” so that the binding started from scratch and created the missing data. After this change the login worked. I did not swith to a new Amazon account nor did I change the password. I only changed the name of the OH account definition (account thing) as described in my post. You may be able to do this change also in the GUI / PaperUI, thing name “Amazon Account”. The new name “account XXX” show up in the channel of this thing.
This is my interpretation of the error behavior without knowing the technical details of the binding.
