Trying to follow along to the directions at http://tinsley.io/2015/06/control-your-items-using-the-amazon-echo-openhab/ but having an issue. When I try to connect in Postman I get ‘Could not get a response’ It looks like maybe I’m getting an error upon installation?
First one being aboout address already in use. Looks like its trying to use 8080 even though I say to use 8081?
2016-12-24 09:51:06.007 ERROR 10225 — [ main] o.a.coyote.http11.Http11NioProtocol : Failed to start end point associated with ProtocolHandler [“http-nio-8080”]
java.net.BindException: Address already in use
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Net.java:433)
at sun.nio.ch.Net.bind(Net.java:425)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
at org.apache.tomcat.util.net.NioEndpoint.bind(NioEndpoint.java:339)
at org.apache.tomcat.util.net.AbstractEndpoint.start(AbstractEndpoint.java:760)
at org.apache.coyote.AbstractProtocol.start(AbstractProtocol.java:472)
at org.apache.catalina.connector.Connector.startInternal(Connector.java:986)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.StandardService.addConnector(StandardService.java:237)
at org.springframework.boot.context.embedded.tomcat.TomcatEmbeddedServletContainer.addPreviouslyRemovedConnectors(TomcatEmbeddedServletContainer.java:186)
at org.springframework.boot.context.embedded.tomcat.TomcatEmbeddedServletContainer.start(TomcatEmbeddedServletContainer.java:149)
at org.springframework.boot.context.embedded.EmbeddedWebApplicationContext.startEmbeddedServletContainer(EmbeddedWebApplicationContext.java:288)
at org.springframework.boot.context.embedded.EmbeddedWebApplicationContext.finishRefresh(EmbeddedWebApplicationContext.java:141)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:483)
at org.springframework.boot.context.embedded.EmbeddedWebApplicationContext.refresh(EmbeddedWebApplicationContext.java:118)
at org.springframework.boot.SpringApplication.refresh(SpringApplication.java:687)
at org.springframework.boot.SpringApplication.run(SpringApplication.java:321)
at org.springframework.boot.SpringApplication.run(SpringApplication.java:967)
at org.springframework.boot.SpringApplication.run(SpringApplication.java:956)
at com.armzilla.ha.SpringbootEntry.main(SpringbootEntry.java:22)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.boot.loader.MainMethodRunner.run(MainMethodRunner.java:53)
at java.lang.Thread.run(Thread.java:745)
2016-12-24 09:51:06.018 ERROR 10225 — [ main] o.apache.catalina.core.StandardService : Failed to start connector [Connector[HTTP/1.1-8080]]
org.apache.catalina.LifecycleException: Failed to start component [Connector[HTTP/1.1-8080]]
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:154)
Caused by: org.apache.catalina.LifecycleException: service.getName(): “Tomcat”; Protocol handler start failed
at org.apache.catalina.connector.Connector.startInternal(Connector.java:993)
… 18 common frames omitted
Caused by: java.net.BindException: Address already in use
… 19 common frames omitted
2016-12-24 09:51:06.495 ERROR 10225 — [ main] o.s.boot.SpringApplication : Application startup failed
java.lang.IllegalStateException: Tomcat connector in failed state
at org.springframework.boot.context.embedded.tomcat.TomcatEmbeddedServletContainer.start(TomcatEmbeddedServletContainer.java:157)
