Amazon Echo SmartJ Binding Too Many Requests - 429 error
Every day I get a warning about too many requests with the Smartj Amazon Echo Control binding. I suspect I can resolve this with the polling interval. I’ll increase from 30 to 60 to see if that makes a difference. Is “Polling Interval Alexa” the most important to change?
I’m using 4.1.1.202403231635 on OH 4.1.2
Anyone else seeing this?
2024-04-11 08:28:46.442 [INFO ] [ntrol.internal.connection.Connection] - getting activities failed
org.smarthomej.binding.amazonechocontrol.internal.ConnectionException: https://www.amazon.com/alexa-privacy/apd/rvh/customer-history-records?startTime=1712849189783&endTime=1712849339783&maxRecordSize=1 failed with code 429: Too Many Requests
        at org.smarthomej.binding.amazonechocontrol.internal.util.HttpRequestBuilder$HttpResponseListener.onComplete(HttpRequestBuilder.java:385) ~[?:?]
        at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:218) ~[?:?]
        at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:210) ~[?:?]
        at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:481) ~[?:?]
        at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:461) ~[?:?]
        at org.eclipse.jetty.client.HttpReceiver.responseSuccess(HttpReceiver.java:424) ~[?:?]
        at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.messageComplete(HttpReceiverOverHTTP.java:374) ~[?:?]
        at org.eclipse.jetty.http.HttpParser.parseFields(HttpParser.java:1188) ~[?:?]
        at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1560) ~[?:?]
        at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:208) ~[?:?]
        at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:148) ~[?:?]
        at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:80) ~[?:?]
        at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
        at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) ~[?:?]
        at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
        at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
        at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) ~[?:?]
        at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) ~[?:?]
        at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) ~[?:?]
        at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) ~[?:?]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) ~[?:?]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) ~[?:?]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) ~[?:?]
        at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) ~[?:?]
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) ~[?:?]
        at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) ~[?:?]
Hello, i think i do have the same issue.
The Things and Bridge is going online → offline → online every ~5 minute.
Error message: Too many requests
I do have openHAB 4.0.4 and SmartHome/J Amazon Echo Control Binding (beta) V4.0.2-SNAPSHOT.
TRACE log is:
2024-09-20 09:27:41.448 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:27:43.826 [TRACE] [control.internal.push.PushConnection] - Sending ping in session 1911297681
2024-09-20 09:27:43.867 [TRACE] [rol.internal.push.PushSessionHandler] - Session 1911297681 received pingFrame (reply=true)
2024-09-20 09:27:43.868 [TRACE] [control.internal.push.PushConnection] - Cancelling pingWaitJob
2024-09-20 09:27:51.448 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:27:58.955 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/phoenix, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=-945216820], cookies = [session-id="144-3170767-6201868";$Path="/";$Domain=".amazon.com";$Port="", ubid-main="130-5038696-4613567";$Path="/";$Domain=".amazon.com";$Port="", x-main=""4pG6DxH7HJCFuGfWnRFfbbSkjqgrDKLj"";$Path="/";$Domain=".amazon.com";$Port="", at-main=""Atza|IwEBINuOnKgQ8lg66v1lx8fbT_JTJlrn0QW1jF0IJ2OiXKxQO09vtftYE9OlOnb8uIMXVCGTzfA5F9mektxAKogwm_buwC4o6iLfPUGp-NUapiLrtwxsm_Ry8ssEXboo5-jr4FYXoaNI7AzFIwK4MZKcF9sBCTzpIaCaAb-gqsbmP8DGAQh1LMmdAagKIGFxifFJN3J5EpFDtK-yt5BXo-oclnkW0wu0UhaOo13C97dMgM4o2ERv9wt2kYrgavDr37zbaVXvfYNaYFZwzASUCDVAuyxcke4vcproNEo9cmIf5f__m_xXWe8hOxAAsIkK0o9DKfw"";$Path="/";$Domain=".amazon.com";$Port="", sess-at-main=""BROlGl+JT17G3VxClyHVPffca5QalgbbjZFyia+qgaU="";$Path="/";$Domain=".amazon.com";$Port="", csrf=-945216820], content = null
2024-09-20 09:27:59.181 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/phoenix: 429, headers = [Content-Type=application/json,Content-Length=74,Connection=keep-alive,Server=Server,Date=Fri, 20 Sep 2024 07:27:59 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=GFCDVJHGT9P53SBYRBXW,Content-Encoding=gzip,X-Amzn-RequestId=4404acf3-4786-4209-883e-1864645841f3,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Error from cloudfront,Via=1.1 92c2f36c465b846f668f475f8669bfe2.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P6,X-Amz-Cf-Id=b3ZOY6kHdYtFQyf28rp2QC-wv-we7KBhrIEkwia6IZYwuXA81v5-4A==], content = {"message":"Too many requests. Try again in some time."}
2024-09-20 09:28:01.183 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/phoenix, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=-945216820], cookies = [session-id="144-3170767-6201868";$Path="/";$Domain=".amazon.com";$Port="", ubid-main="130-5038696-4613567";$Path="/";$Domain=".amazon.com";$Port="", x-main=""4pG6DxH7HJCFuGfWnRFfbbSkjqgrDKLj"";$Path="/";$Domain=".amazon.com";$Port="", at-main=""Atza|IwEBINuOnKgQ8lg66v1lx8fbT_JTJlrn0QW1jF0IJ2OiXKxQO09vtftYE9OlOnb8uIMXVCGTzfA5F9mektxAKogwm_buwC4o6iLfPUGp-NUapiLrtwxsm_Ry8ssEXboo5-jr4FYXoaNI7AzFIwK4MZKcF9sBCTzpIaCaAb-gqsbmP8DGAQh1LMmdAagKIGFxifFJN3J5EpFDtK-yt5BXo-oclnkW0wu0UhaOo13C97dMgM4o2ERv9wt2kYrgavDr37zbaVXvfYNaYFZwzASUCDVAuyxcke4vcproNEo9cmIf5f__m_xXWe8hOxAAsIkK0o9DKfw"";$Path="/";$Domain=".amazon.com";$Port="", sess-at-main=""BROlGl+JT17G3VxClyHVPffca5QalgbbjZFyia+qgaU="";$Path="/";$Domain=".amazon.com";$Port="", csrf=-945216820], content = null
2024-09-20 09:28:01.268 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/phoenix: 429, headers = [Content-Type=application/json,Content-Length=74,Connection=keep-alive,Server=Server,Date=Fri, 20 Sep 2024 07:28:01 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=C0C0RX7ZJYCGMAT6FDEK,Content-Encoding=gzip,X-Amzn-RequestId=d1ea5565-17a4-4fcb-8024-2c78f4973971,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Error from cloudfront,Via=1.1 92c2f36c465b846f668f475f8669bfe2.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P6,X-Amz-Cf-Id=rzVfUFnH_aQi44mqvS0_PtnOx715zvbREz8OYyv8SKoizJoL5osAXw==], content = {"message":"Too many requests. Try again in some time."}
2024-09-20 09:28:01.449 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:28:03.269 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/phoenix, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=-945216820], cookies = [session-id="144-3170767-6201868";$Path="/";$Domain=".amazon.com";$Port="", ubid-main="130-5038696-4613567";$Path="/";$Domain=".amazon.com";$Port="", x-main=""4pG6DxH7HJCFuGfWnRFfbbSkjqgrDKLj"";$Path="/";$Domain=".amazon.com";$Port="", at-main=""Atza|IwEBINuOnKgQ8lg66v1lx8fbT_JTJlrn0QW1jF0IJ2OiXKxQO09vtftYE9OlOnb8uIMXVCGTzfA5F9mektxAKogwm_buwC4o6iLfPUGp-NUapiLrtwxsm_Ry8ssEXboo5-jr4FYXoaNI7AzFIwK4MZKcF9sBCTzpIaCaAb-gqsbmP8DGAQh1LMmdAagKIGFxifFJN3J5EpFDtK-yt5BXo-oclnkW0wu0UhaOo13C97dMgM4o2ERv9wt2kYrgavDr37zbaVXvfYNaYFZwzASUCDVAuyxcke4vcproNEo9cmIf5f__m_xXWe8hOxAAsIkK0o9DKfw"";$Path="/";$Domain=".amazon.com";$Port="", sess-at-main=""BROlGl+JT17G3VxClyHVPffca5QalgbbjZFyia+qgaU="";$Path="/";$Domain=".amazon.com";$Port="", csrf=-945216820], content = null
2024-09-20 09:28:03.353 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/phoenix: 429, headers = [Content-Type=application/json,Content-Length=74,Connection=keep-alive,Server=Server,Date=Fri, 20 Sep 2024 07:28:03 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=R7VAS64YJD5KRVHJ5CT4,Content-Encoding=gzip,X-Amzn-RequestId=da55a05f-3c93-43e2-9ebd-30bc44ed3201,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Error from cloudfront,Via=1.1 92c2f36c465b846f668f475f8669bfe2.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P6,X-Amz-Cf-Id=6tAJUjuf-4k66zZ8DYxDu8YHvHxLRL_4L9FAt_Pb7OUTo3_CKrtRCw==], content = {"message":"Too many requests. Try again in some time."}
2024-09-20 09:28:05.355 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/phoenix, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=-945216820], cookies = [session-id="144-3170767-6201868";$Path="/";$Domain=".amazon.com";$Port="", ubid-main="130-5038696-4613567";$Path="/";$Domain=".amazon.com";$Port="", x-main=""4pG6DxH7HJCFuGfWnRFfbbSkjqgrDKLj"";$Path="/";$Domain=".amazon.com";$Port="", at-main=""Atza|IwEBINuOnKgQ8lg66v1lx8fbT_JTJlrn0QW1jF0IJ2OiXKxQO09vtftYE9OlOnb8uIMXVCGTzfA5F9mektxAKogwm_buwC4o6iLfPUGp-NUapiLrtwxsm_Ry8ssEXboo5-jr4FYXoaNI7AzFIwK4MZKcF9sBCTzpIaCaAb-gqsbmP8DGAQh1LMmdAagKIGFxifFJN3J5EpFDtK-yt5BXo-oclnkW0wu0UhaOo13C97dMgM4o2ERv9wt2kYrgavDr37zbaVXvfYNaYFZwzASUCDVAuyxcke4vcproNEo9cmIf5f__m_xXWe8hOxAAsIkK0o9DKfw"";$Path="/";$Domain=".amazon.com";$Port="", sess-at-main=""BROlGl+JT17G3VxClyHVPffca5QalgbbjZFyia+qgaU="";$Path="/";$Domain=".amazon.com";$Port="", csrf=-945216820], content = null
2024-09-20 09:28:05.442 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/phoenix: 429, headers = [Content-Type=application/json,Content-Length=74,Connection=keep-alive,Server=Server,Date=Fri, 20 Sep 2024 07:28:05 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=VD1RAK1NYM0S3N56A7QK,Content-Encoding=gzip,X-Amzn-RequestId=9a3a0559-e8cd-44af-b4e5-2cd3583ca691,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Error from cloudfront,Via=1.1 92c2f36c465b846f668f475f8669bfe2.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P6,X-Amz-Cf-Id=B7q4QaUQEEA4zHike1ooyyfPo6oYu61iACi-tQjk-x9g_HqODpWCEQ==], content = {"message":"Too many requests. Try again in some time."}
2024-09-20 09:28:11.449 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:28:21.450 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:28:31.451 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:28:41.451 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:28:43.836 [TRACE] [control.internal.push.PushConnection] - Sending ping in session 1911297681
2024-09-20 09:28:43.921 [TRACE] [rol.internal.push.PushSessionHandler] - Session 1911297681 received pingFrame (reply=true)
2024-09-20 09:28:43.921 [TRACE] [control.internal.push.PushConnection] - Cancelling pingWaitJob
2024-09-20 09:28:51.452 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:29:01.453 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:29:11.454 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:29:21.454 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:29:31.455 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:29:41.455 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:29:43.844 [TRACE] [control.internal.push.PushConnection] - Sending ping in session 1911297681
2024-09-20 09:29:43.883 [TRACE] [rol.internal.push.PushSessionHandler] - Session 1911297681 received pingFrame (reply=true)
2024-09-20 09:29:43.884 [TRACE] [control.internal.push.PushConnection] - Cancelling pingWaitJob
2024-09-20 09:29:51.456 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:30:01.457 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:30:11.458 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:30:21.458 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:30:31.459 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:30:41.460 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:30:43.852 [TRACE] [control.internal.push.PushConnection] - Sending ping in session 1911297681
2024-09-20 09:30:43.891 [TRACE] [rol.internal.push.PushSessionHandler] - Session 1911297681 received pingFrame (reply=true)
2024-09-20 09:30:43.892 [TRACE] [control.internal.push.PushConnection] - Cancelling pingWaitJob
2024-09-20 09:30:51.460 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:31:01.461 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:31:11.462 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:31:21.462 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:31:31.463 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:31:41.464 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:31:43.933 [TRACE] [control.internal.push.PushConnection] - Sending ping in session 1911297681
2024-09-20 09:31:43.972 [TRACE] [rol.internal.push.PushSessionHandler] - Session 1911297681 received pingFrame (reply=true)
2024-09-20 09:31:43.973 [TRACE] [control.internal.push.PushConnection] - Cancelling pingWaitJob
2024-09-20 09:31:51.464 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:32:01.465 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:32:11.466 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:32:21.467 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:32:31.467 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:32:41.468 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:32:43.941 [TRACE] [control.internal.push.PushConnection] - Sending ping in session 1911297681
2024-09-20 09:32:43.980 [TRACE] [rol.internal.push.PushSessionHandler] - Session 1911297681 received pingFrame (reply=true)
2024-09-20 09:32:43.981 [TRACE] [control.internal.push.PushConnection] - Cancelling pingWaitJob
2024-09-20 09:32:51.468 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:33:01.469 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:33:05.445 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/phoenix, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=-945216820], cookies = [session-id="144-3170767-6201868";$Path="/";$Domain=".amazon.com";$Port="", ubid-main="130-5038696-4613567";$Path="/";$Domain=".amazon.com";$Port="", x-main=""4pG6DxH7HJCFuGfWnRFfbbSkjqgrDKLj"";$Path="/";$Domain=".amazon.com";$Port="", at-main=""Atza|IwEBINuOnKgQ8lg66v1lx8fbT_JTJlrn0QW1jF0IJ2OiXKxQO09vtftYE9OlOnb8uIMXVCGTzfA5F9mektxAKogwm_buwC4o6iLfPUGp-NUapiLrtwxsm_Ry8ssEXboo5-jr4FYXoaNI7AzFIwK4MZKcF9sBCTzpIaCaAb-gqsbmP8DGAQh1LMmdAagKIGFxifFJN3J5EpFDtK-yt5BXo-oclnkW0wu0UhaOo13C97dMgM4o2ERv9wt2kYrgavDr37zbaVXvfYNaYFZwzASUCDVAuyxcke4vcproNEo9cmIf5f__m_xXWe8hOxAAsIkK0o9DKfw"";$Path="/";$Domain=".amazon.com";$Port="", sess-at-main=""BROlGl+JT17G3VxClyHVPffca5QalgbbjZFyia+qgaU="";$Path="/";$Domain=".amazon.com";$Port="", csrf=-945216820], content = null
2024-09-20 09:33:05.671 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/phoenix: 429, headers = [Content-Type=application/json,Content-Length=74,Connection=keep-alive,Server=Server,Date=Fri, 20 Sep 2024 07:33:05 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=MJBG8QB82WZZ3AAXYFZ6,Content-Encoding=gzip,X-Amzn-RequestId=707c212c-3903-4578-852c-460ce5a58c61,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Error from cloudfront,Via=1.1 711bf86dc2898a8122a5a6c5b71ec626.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P6,X-Amz-Cf-Id=10Vsq-y_ytuhovQvoQ-Hz1hQ_NalBTpBIJfm3sOB3BodwrZ8vbNjgQ==], content = {"message":"Too many requests. Try again in some time."}
2024-09-20 09:33:07.673 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/phoenix, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=-945216820], cookies = [session-id="144-3170767-6201868";$Path="/";$Domain=".amazon.com";$Port="", ubid-main="130-5038696-4613567";$Path="/";$Domain=".amazon.com";$Port="", x-main=""4pG6DxH7HJCFuGfWnRFfbbSkjqgrDKLj"";$Path="/";$Domain=".amazon.com";$Port="", at-main=""Atza|IwEBINuOnKgQ8lg66v1lx8fbT_JTJlrn0QW1jF0IJ2OiXKxQO09vtftYE9OlOnb8uIMXVCGTzfA5F9mektxAKogwm_buwC4o6iLfPUGp-NUapiLrtwxsm_Ry8ssEXboo5-jr4FYXoaNI7AzFIwK4MZKcF9sBCTzpIaCaAb-gqsbmP8DGAQh1LMmdAagKIGFxifFJN3J5EpFDtK-yt5BXo-oclnkW0wu0UhaOo13C97dMgM4o2ERv9wt2kYrgavDr37zbaVXvfYNaYFZwzASUCDVAuyxcke4vcproNEo9cmIf5f__m_xXWe8hOxAAsIkK0o9DKfw"";$Path="/";$Domain=".amazon.com";$Port="", sess-at-main=""BROlGl+JT17G3VxClyHVPffca5QalgbbjZFyia+qgaU="";$Path="/";$Domain=".amazon.com";$Port="", csrf=-945216820], content = null
2024-09-20 09:33:07.755 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/phoenix: 429, headers = [Content-Type=application/json,Content-Length=74,Connection=keep-alive,Server=Server,Date=Fri, 20 Sep 2024 07:33:07 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=2M6B4G731JB5G1NFV04W,Content-Encoding=gzip,X-Amzn-RequestId=f932f8fd-08fd-4687-a35e-d62f3d6a3eec,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Error from cloudfront,Via=1.1 711bf86dc2898a8122a5a6c5b71ec626.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P6,X-Amz-Cf-Id=Wz8X9NgDUTGnXp_t-kW8syywP7ZPJxhaWmkT8kYf4V_JTdtLZQAIZQ==], content = {"message":"Too many requests. Try again in some time."}
2024-09-20 09:33:09.756 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/phoenix, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=-945216820], cookies = [session-id="144-3170767-6201868";$Path="/";$Domain=".amazon.com";$Port="", ubid-main="130-5038696-4613567";$Path="/";$Domain=".amazon.com";$Port="", x-main=""4pG6DxH7HJCFuGfWnRFfbbSkjqgrDKLj"";$Path="/";$Domain=".amazon.com";$Port="", at-main=""Atza|IwEBINuOnKgQ8lg66v1lx8fbT_JTJlrn0QW1jF0IJ2OiXKxQO09vtftYE9OlOnb8uIMXVCGTzfA5F9mektxAKogwm_buwC4o6iLfPUGp-NUapiLrtwxsm_Ry8ssEXboo5-jr4FYXoaNI7AzFIwK4MZKcF9sBCTzpIaCaAb-gqsbmP8DGAQh1LMmdAagKIGFxifFJN3J5EpFDtK-yt5BXo-oclnkW0wu0UhaOo13C97dMgM4o2ERv9wt2kYrgavDr37zbaVXvfYNaYFZwzASUCDVAuyxcke4vcproNEo9cmIf5f__m_xXWe8hOxAAsIkK0o9DKfw"";$Path="/";$Domain=".amazon.com";$Port="", sess-at-main=""BROlGl+JT17G3VxClyHVPffca5QalgbbjZFyia+qgaU="";$Path="/";$Domain=".amazon.com";$Port="", csrf=-945216820], content = null
2024-09-20 09:33:09.844 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/phoenix: 429, headers = [Content-Type=application/json,Content-Length=74,Connection=keep-alive,Server=Server,Date=Fri, 20 Sep 2024 07:33:09 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=9JXA57EWQZKRYX0HAWDJ,Content-Encoding=gzip,X-Amzn-RequestId=8b39b0ce-1f40-40a2-a0db-ee42ac930947,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Error from cloudfront,Via=1.1 711bf86dc2898a8122a5a6c5b71ec626.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P6,X-Amz-Cf-Id=eBdZbGNC9PEf5drMGJ-9vw50nqf4BuucRgMMcJJmauY8khvNBndh-w==], content = {"message":"Too many requests. Try again in some time."}
2024-09-20 09:33:11.469 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:33:11.846 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/phoenix, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=-945216820], cookies = [session-id="144-3170767-6201868";$Path="/";$Domain=".amazon.com";$Port="", ubid-main="130-5038696-4613567";$Path="/";$Domain=".amazon.com";$Port="", x-main=""4pG6DxH7HJCFuGfWnRFfbbSkjqgrDKLj"";$Path="/";$Domain=".amazon.com";$Port="", at-main=""Atza|IwEBINuOnKgQ8lg66v1lx8fbT_JTJlrn0QW1jF0IJ2OiXKxQO09vtftYE9OlOnb8uIMXVCGTzfA5F9mektxAKogwm_buwC4o6iLfPUGp-NUapiLrtwxsm_Ry8ssEXboo5-jr4FYXoaNI7AzFIwK4MZKcF9sBCTzpIaCaAb-gqsbmP8DGAQh1LMmdAagKIGFxifFJN3J5EpFDtK-yt5BXo-oclnkW0wu0UhaOo13C97dMgM4o2ERv9wt2kYrgavDr37zbaVXvfYNaYFZwzASUCDVAuyxcke4vcproNEo9cmIf5f__m_xXWe8hOxAAsIkK0o9DKfw"";$Path="/";$Domain=".amazon.com";$Port="", sess-at-main=""BROlGl+JT17G3VxClyHVPffca5QalgbbjZFyia+qgaU="";$Path="/";$Domain=".amazon.com";$Port="", csrf=-945216820], content = null
2024-09-20 09:33:11.929 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/phoenix: 429, headers = [Content-Type=application/json,Content-Length=74,Connection=keep-alive,Server=Server,Date=Fri, 20 Sep 2024 07:33:11 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=P18BJRTVV4QX7DNAF1PX,Content-Encoding=gzip,X-Amzn-RequestId=0dd22b9d-6a6a-4210-8d6c-b0f372140506,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Error from cloudfront,Via=1.1 711bf86dc2898a8122a5a6c5b71ec626.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P6,X-Amz-Cf-Id=MrWTOTvdApbvbyKEOkeBhpdFZrnfpO8ykgs9yk8zsDRZ6uGCGN-R1Q==], content = {"message":"Too many requests. Try again in some time."}
2024-09-20 09:33:21.470 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:33:31.471 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:33:41.471 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:33:43.949 [TRACE] [control.internal.push.PushConnection] - Sending ping in session 1911297681
2024-09-20 09:33:43.989 [TRACE] [rol.internal.push.PushSessionHandler] - Session 1911297681 received pingFrame (reply=true)
2024-09-20 09:33:43.990 [TRACE] [control.internal.push.PushConnection] - Cancelling pingWaitJob
2024-09-20 09:33:51.472 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:34:01.473 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:34:11.473 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:34:21.474 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-09-20 09:34:31.474 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
Can someone help?
Generally the alexa communication is working fine. But i think there is a problem because of the many error messages.
Thank you!
since a couple of days I am facing this issue as well.
Latest SmartHome/J Amazon Echo Control Binding and openHAB 4.3.0.M1.
Log:
amazonechocontrol:account:abc123' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): https://eu-api-alexa.amazon.com/api/phoenix failed with code 429: Too Many Requests
I already tried logout and re-register here: openHAB-IP:8080/amazonechocontrol
That changed the connected-to-URL to https://eu-api-alexa.amazon.com but the problem still exists.
Is there a solution/workaround available?
May I tag @J-N-K here for help? :innocent:
I guess you use smarthomedevies connected to alexa?
Thanks for super-fast answer.
yes, I do have smarthome devices connected to Alexa- but not many.
Most devices are openHAB-devices, -switches, -lights.
update-1: I uninstalled all skills in Alexa-App except openHAB Skill.
Still same error.
update-2:
the HomeAssistant community seems to have the same issue:
https://github.com/alandtse/alexa_media_player/issues/2177
Can you disable smarthome discovery and all smarthome devices?
I changed the amazon account thing in openHAB to “no discovery” - and unit yet the error disappeared :ok_hand:
I keep my fingers crossed. :grinning:
Thanks, Jan!
my account-thing is online again. but all my devices that are connected via the echo binding are offline (Can’t find smarthomeBaseDevice), and new devices are not found either. What can I do?
Thank you!
ok, my experience with the SmartJ version:
  1. I set the amazon account-thing offline for a few days
    don’t know, if that’s relevant?
  2. set the amazon account-thing to no discovery
  3. set all my alexa-things offline.
  4. set the amazon account-thing online again (had to reconnect via the /amazonechocontrol/)
  5. set the alexas online each at a time
Now I don’t have the 429-errors anymore, and all my alexa-devices are online (for the time present).
What I can say:
  • I disconnected (aka removed it from the outlet) an Wifi smart plug, which was added via Alexa
  • I have an echo, which is not online anytime, but only, if the room is powered
  • I had an echo in the thing list, which I removed completely since a year or so
For all of those things, I didn’t set them to Online.
What I experience nevertheless:
  • no functions available for the binding. e.g. if I send a text to the “say”-channel, but the echo stays silent:
2024-10-04 09:10:56.721 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'AMZ_EchoOffice_Sprich' changed from NULL to das ist test
  • If I say something to the echo, which works (turn on lights via the OH-skill), shortly after:
    could be unrelated, as I get this error (info?) randomly?
2024-10-04 09:10:06.755 [INFO ] [ntrol.internal.connection.Connection] - getting activities failed
org.smarthomej.binding.amazonechocontrol.internal.ConnectionException: https://www.amazon.de/alexa-privacy/apd/rvh/customer-history-records?startTime=1728025673496&endTime=1728025823496&maxRecordSize=1 failed with code 401: Unauthorized
	at org.eclipse.jetty.client.AuthenticationProtocolHandler$AuthenticationListener.forwardFailureComplete(AuthenticationProtocolHandler.java:297) ~[?:?]
	at org.eclipse.jetty.client.AuthenticationProtocolHandler$AuthenticationListener.onComplete(AuthenticationProtocolHandler.java:164) ~[?:?]
edit:
this error appears every 2 to 8 minutes, no exact interval:
2024-10-04 09:08:30.033 [INFO ] [ntrol.internal.connection.Connection] - getting activities failed
2024-10-04 09:09:54.763 [INFO ] [ntrol.internal.connection.Connection] - getting activities failed
2024-10-04 09:12:10.719 [INFO ] [ntrol.internal.connection.Connection] - getting activities failed
2024-10-04 09:15:32.845 [INFO ] [ntrol.internal.connection.Connection] - getting activities failed
2024-10-04 09:22:40.202 [INFO ] [ntrol.internal.connection.Connection] - getting activities failed
edit2:
since the 09:22 entry, there was no more. Until I again said something to my alexa. Then the entry came in about 20secs after. I guess other family members turning lights on/off or using the shopping list… ;). I was turning the Coffeemaker on :wink:
so my bet is, it is indeed connected to using echos or at least a Alexa-paired device?
2024-10-04 09:47:01.559 [INFO ] [openhab.event.ItemCommandEvent      ] - Item 'COFF_Status' received command ON
2024-10-04 09:47:22.263 [INFO ] [ntrol.internal.connection.Connection] - getting activities failed
Hello, I have the same problem here.
OH stable 4.2.1 with 12 amazon thing devices connected.
I tried 2 versions of binding :
  • official 4.2.1 : cannot even login and connect, direct error 429 too many connect
  • smarthomej 4.2.0 : can login and connect, but every 5 min logout/login with message 429 too many connect (all devices cycle online/offline)
At the end I still use smarthomej binding because main feature I use is lastVoiceCommand, and it is not working with official binding 4.2.1.
I tried logout/relogin, restarting bindings, uninstall/reinstall, nothing can fix.
Hi
I updated to version 4.2.2 and I also have the problem.
I’m going to change the Amazon account in openHAB to “no discovery” to see what happens. To be continued.
if i do so the Bridge is getting online, but all Amazon-Things like Power-Switches are in the State “Can’t find smarthomeBaseDevice”
Hm. I can’t imagine that only a few people here has had this problems …
Daniel
in the meantime (since my post #9 above) I did experience:
  1. stable “Online”-state for all my things and alexa devices (solely echos, no smart devices anymore)
  2. no 429 errors anymore
  3. but the 401-errors as described in my thread, they appear random after using alexa devices
what I cannot do
  1. do anything with the channels, I tried textToSpeech, textCommand or textToSpeechVolume, without anything going on afterwards
  2. They don’t even get the infos via imageUrl or title, if playing music
in essence:
I do get “green” things, but the channels don’t work.
What I saw, while turning the log-level to “trace”:
  1. If I use textcommand - nothing ever happens in the logs.
  2. If I tell Alexa to play music, the items won’t change, but the TRACE-log spits out:
perhaps this helps?
2024-10-08 11:52:18.056 [TRACE] [trol.internal.push.PushStreamAdapter] - Received raw data Content-Type: application/json
{"directive":{"header":{"namespace":"Alexa.Mobile.Push","name":"RenderUpdate","messageId":"b4811371-5d27-44f6-af35-397ea49014d8"},"payload":{"renderingUpdates":[{"route":"EventBus:tcomm::message","resourceId":"PUSH_VOLUME_CHANGE","resourceMetadata":"{\"command\":\"PUSH_VOLUME_CHANGE\",\"timeStamp\":1728381141675,\"payload\":\"{\\\"dopplerId\\\":{\\\"deviceSerialNumber\\\":\\\"xxx\\\",\\\"deviceType\\\":\\\"A2TF17PFR55MTB\\\"},\\\"volumeSetting\\\":13,\\\"isMuted\\\":false,\\\"destinationUserId\\\":\\\"yyy\\\"}\"}"}]}}}
--------abcde123
2024-10-08 11:52:18.057 [DEBUG] [trol.internal.handler.AccountHandler] - Processing CommandTO{command='PUSH_VOLUME_CHANGE', payload='{"dopplerId":{"deviceSerialNumber":"xxx","deviceType":"A2TF17PFR55MTB"},"volumeSetting":13,"isMuted":false,"destinationUserId":"yyy"}', timeStamp=1728381141675}
2024-10-08 11:52:20.488 [TRACE] [trol.internal.push.PushStreamAdapter] - Received raw data Content-Type: application/json
{"directive":{"header":{"namespace":"Alexa.Mobile.Push","name":"RenderUpdate","messageId":"2c80c1d6-fe02-4ab8-96ad-721444c1d316"},"payload":{"renderingUpdates":[{"route":"EventBus:tcomm::message","resourceId":"PUSH_EQUALIZER_STATE_CHANGE","resourceMetadata":"{\"command\":\"PUSH_EQUALIZER_STATE_CHANGE\",\"timeStamp\":1728381144116,\"payload\":\"{\\\"dopplerId\\\":{\\\"deviceSerialNumber\\\":\\\"zzz\\\",\\\"deviceType\\\":\\\"aaa\\\"},\\\"bass\\\":0,\\\"midrange\\\":0,\\\"treble\\\":0,\\\"destinationUserId\\\":\\\"yyy\\\"}\"}"}]}}}
--------abcde123
2024-10-08 11:52:20.489 [DEBUG] [trol.internal.handler.AccountHandler] - Processing CommandTO{command='PUSH_EQUALIZER_STATE_CHANGE', payload='{"dopplerId":{"deviceSerialNumber":"zzz","deviceType":"aaa"},"bass":0,"midrange":0,"treble":0,"destinationUserId":"yyy"}', timeStamp=1728381144116}
2024-10-08 11:52:20.490 [DEBUG] [control.internal.handler.EchoHandler] - Handle push command PUSH_EQUALIZER_STATE_CHANGE
2024-10-08 11:52:20.520 [TRACE] [trol.internal.push.PushStreamAdapter] - Received raw data Content-Type: application/json
{"directive":{"header":{"namespace":"Alexa.Mobile.Push","name":"RenderUpdate","messageId":"133397a5-f4d9-476b-99b9-94a9b2638453"},"payload":{"renderingUpdates":[{"route":"EventBus:tcomm::message","resourceId":"PUSH_VOLUME_CHANGE","resourceMetadata":"{\"command\":\"PUSH_VOLUME_CHANGE\",\"timeStamp\":1728381144129,\"payload\":\"{\\\"dopplerId\\\":{\\\"deviceSerialNumber\\\":\\\"zzz\\\",\\\"deviceType\\\":\\\"aaa\\\"},\\\"volumeSetting\\\":40,\\\"isMuted\\\":false,\\\"destinationUserId\\\":\\\"yyy\\\"}\"}"}]}}}
--------abcde123
2024-10-08 11:52:20.521 [DEBUG] [trol.internal.handler.AccountHandler] - Processing CommandTO{command='PUSH_VOLUME_CHANGE', payload='{"dopplerId":{"deviceSerialNumber":"zzz","deviceType":"aaa"},"volumeSetting":40,"isMuted":false,"destinationUserId":"yyy"}', timeStamp=1728381144129}
2024-10-08 11:52:20.522 [DEBUG] [control.internal.handler.EchoHandler] - Handle push command PUSH_VOLUME_CHANGE
2024-10-08 11:52:20.554 [TRACE] [trol.internal.handler.AccountHandler] - updateSmartHomeState started with deviceFilterId=null
2024-10-08 11:52:20.659 [TRACE] [trol.internal.push.PushStreamAdapter] - Received raw data Content-Type: application/json
{"directive":{"header":{"namespace":"Alexa.Mobile.Push","name":"RenderUpdate","messageId":"6de01cb0-78ec-40ac-a412-fd5124ddbb3c"},"payload":{"renderingUpdates":[{"route":"EventBus:tcomm::message","resourceId":"PUSH_AUDIO_PLAYER_STATE","resourceMetadata":"{\"command\":\"PUSH_AUDIO_PLAYER_STATE\",\"timeStamp\":1728381144278,\"payload\":\"{\\\"dopplerId\\\":{\\\"deviceSerialNumber\\\":\\\"zzz\\\",\\\"deviceType\\\":\\\"aaa\\\"},\\\"audioPlayerState\\\":\\\"INTERRUPTED\\\",\\\"quality\\\":null,\\\"error\\\":false,\\\"errorMessage\\\":null,\\\"mediaReferenceId\\\":\\\"EMP_ALEXA-92d042e9-96f4-43d1-9059-97a3c5ccd86e:spotify:track:2dR5WkrpwylTuT3jRWNufa\\\",\\\"destinationUserId\\\":\\\"yyy\\\"}\"}"}]}}}
--------abcde123
2024-10-08 11:52:20.661 [DEBUG] [trol.internal.handler.AccountHandler] - Processing CommandTO{command='PUSH_AUDIO_PLAYER_STATE', payload='{"dopplerId":{"deviceSerialNumber":"zzz","deviceType":"aaa"},"audioPlayerState":"INTERRUPTED","quality":null,"error":false,"errorMessage":null,"mediaReferenceId":"EMP_ALEXA-92d042e9-96f4-43d1-9059-97a3c5ccd86e:spotify:track:2dR5WkrpwylTuT3jRWNufa","destinationUserId":"yyy"}', timeStamp=1728381144278}
2024-10-08 11:52:20.662 [DEBUG] [control.internal.handler.EchoHandler] - Handle push command PUSH_AUDIO_PLAYER_STATE
2024-10-08 11:52:20.663 [DEBUG] [rol.internal.util.HttpRequestBuilder] - > GET: https://eu-api-alexa.amazon.com/api/np/player?deviceSerialNumber=zzz&deviceType=aaa&screenWidth=1440 (available: 2)
2024-10-08 11:52:20.669 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/np/player?deviceSerialNumber=zzz&deviceType=aaa&screenWidth=1440, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=1426054511], cookies = [sid=bV0tLBjMud1GRy==|af73dRSF3q8S4N1fqMMLnfzwTy13s+7+Bo3gmAVJSmU=, csrf=1426054511, x-main=gXolkPqEYOJIBCwVmd69CCibVEzhTtDq, at-main=Atza|HGRvTzTt5V9Z3fUgbW9QeHLQYEb4vIFX3t_vbj4QnChQCEX-F0bRl1Uo9WizKO5Ngqj1MLqB2X_IQVhCfWfINPUv9wsJCCZCEfxHqxazRQNB2Eom8Ab1B-NaimTqfCW6Rfb03pNm3sHieYatCFTGchFICtnn3mteTv-5HwtIiny6xZljOSZMqLc__CM7cYXQMb59XM7KO9E4ziFF5pF22-n3jBqXY6648ceezGzQ, sess-at-main=+5C9g6BMQZqDQdmWhT9mngwQwrLmm7NICN2UWjPgf7c=, session-id=135-1233478-0053710, session-id-time=2359097771l, ubid-main=135-7816253-4117326, session-token=ytcy00+u+A4WCr0fVidQHt+WWireGl1ogsmnf5GoNz4uqWF0K12iPkBx8QvjY0zj1ombEsPvHC0Y7ApSctjLVdxyP3pGourJboerHjMvMBLGeg0lENArOXpQyrF1QEJRb4CG1U1mCxn62jPWDJQFYddSgNhRdwKT6iGFjskDc+kSuiSA4GNs3NcbUSEPDoNqRdHe4a62v2vt8imcqnjxsCwj137qqY44eRXPXlAUyoFtDK50srJiBbLsWdhyzU0sARSDTl5UWRZFsWK6zJymEyDql56I/v2jUi2IA77Ss/ruWZMqHen3JmND1tG0Bp9BJHOd1+7SGD7jvSftc3jPX0kpbomrJ/kpFB7alKoZEbIx8mDRYNQ==], content = null
2024-10-08 11:52:20.964 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/np/player?deviceSerialNumber=zzz&deviceType=aaa&screenWidth=1440: 200, headers = [Content-Type=application/json,Content-Length=1574,Connection=keep-alive,Server=Server,Date=Tue, 08 Oct 2024 09:52:24 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=5M5WREYSR9C3PHX6SQY5,x-amzn-RequestId=15cd3206-35c8-4b61-b294-ed43bcc3e858,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Miss from cloudfront,Via=1.1 3f7bbc22c659b2b7470c819d073f58b6.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P3,X-Amz-Cf-Id=okeo7dWQ6YHxQFA-BWVISXqXJ-hiiu6klqSgI632cX459jDLF7MFRQ==], content = {"playerInfo":{"hint":null,"infoText":{"header":null,"headerSubtext1":null,"multiLineMode":false,"subText1":"Frank Sinatra","subText2":"Jazz Classics","title":"Fly Me To The Moon"},"isPlayingInLemur":false,"lemurVolume":null,"lyrics":null,"mainArt":{"altText":"Album Art","artType":"UrlArtSource","contentType":"image/jpeg","url":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae"},"mediaId":"spotify:track:2dR5WkrpwylTuT3jRWNufa","miniArt":{"altText":"Album Art","artType":"UrlArtSource","contentType":"image/jpeg","url":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae"},"miniInfoText":{"header":null,"headerSubtext1":null,"multiLineMode":false,"subText1":"Frank Sinatra","subText2":"Jazz Classics","title":"Fly Me To The Moon"},"playbackSource":null,"playingInLemurId":null,"progress":{"allowScrubbing":true,"locationInfo":null,"mediaLength":147,"mediaProgress":89,"showTiming":true,"visible":true},"provider":{"artOverlay":null,"fallbackMainArt":null,"providerDisplayName":"Spotify","providerLogo":{"altText":null,"artType":"UrlArtSource","contentType":"image/png","url":"https://music-service-provider-logos.s3.amazonaws.com/dms-gui-logos/wordmark-logos/Spotify.png"},"providerName":"Spotify"},"quality":null,"queueId":"spotify:artist:1Mxqyy3pSjf8kZZL4QVxS0","state":"PLAYING","template":null,"transport":{"closedCaptions":null,"layoutType":"MusicTransportLayout","lyrics":null,"next":"ENABLED","playPause":"ENABLED","previous":"ENABLED","repeat":"DISABLED","shuffle":"ENABLED"},"upNextItems":null,"volume":{"muted":false,"volume":40}}}
2024-10-08 11:52:21.166 [TRACE] [trol.internal.push.PushStreamAdapter] - Received raw data Content-Type: application/json
{"directive":{"header":{"namespace":"Alexa.Mobile.Push","name":"RenderUpdate","messageId":"bffaec58-e8c0-4145-af8b-dfa4d35a620a"},"payload":{"renderingUpdates":[{"route":"EventBus:tcomm::message","resourceId":"NotifyNowPlayingUpdated","resourceMetadata":"{\"command\":\"NotifyNowPlayingUpdated\",\"timeStamp\":1728381144787,\"payload\":\"{\\\"messageId\\\":\\\"756d1fad-dd74-4184-9329-dcbd4e451b51\\\",\\\"fallbackAllowed\\\":true,\\\"customerId\\\":\\\"yyy\\\",\\\"update\\\":{\\\"type\\\":\\\"SessionUpdate\\\",\\\"taskSessionId\\\":\\\"amzn1.echo-api.session.1b4238b2-5009-4779-8098-45c584e60509\\\",\\\"update\\\":{\\\"type\\\":\\\"NotifyNowPlayingUpdated\\\",\\\"cause\\\":\\\"PLAYBACK_STOPPED\\\",\\\"nowPlayingData\\\":{\\\"@class\\\":\\\"com.amazon.alexa.media.access.shared.model.MusicNowPlayingData\\\",\\\"transport\\\":{\\\"playPause\\\":\\\"ENABLED\\\",\\\"next\\\":\\\"ENABLED\\\",\\\"previous\\\":\\\"ENABLED\\\",\\\"shuffle\\\":\\\"ENABLED\\\",\\\"repeat\\\":\\\"ENABLED\\\",\\\"seekForward\\\":\\\"HIDDEN\\\",\\\"seekBackward\\\":\\\"HIDDEN\\\",\\\"thumbsUp\\\":\\\"HIDDEN\\\",\\\"thumbsDown\\\":\\\"HIDDEN\\\"},\\\"progress\\\":{\\\"visible\\\":true,\\\"mediaProgress\\\":89899,\\\"mediaLength\\\":147146,\\\"allowScrubbing\\\":false,\\\"showTiming\\\":true},\\\"playerState\\\":\\\"PLAYING\\\",\\\"queueId\\\":\\\"spotify:playlist:37i9dQZF1DXbITWG1ZJKYt\\\",\\\"mediaId\\\":\\\"spotify:track:2dR5WkrpwylTuT3jRWNufa\\\",\\\"quality\\\":{\\\"name\\\":\\\"Default Quality\\\",\\\"badge\\\":{\\\"altText\\\":null,\\\"url\\\":\\\"\\\",\\\"contentType\\\":null}},\\\"provider\\\":{\\\"providerName\\\":\\\"Spotify\\\",\\\"providerLogo\\\":{\\\"altText\\\":\\\"Spotify\\\",\\\"url\\\":\\\"https://music-service-provider-logos.s3.amazonaws.com/dms-gui-logos/wordmark-logos/Spotify.png\\\",\\\"contentType\\\":\\\"image/*\\\"}},\\\"mainArt\\\":{\\\"altText\\\":null,\\\"contentType\\\":\\\"image/jpeg\\\",\\\"tinyUrl\\\":\\\"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae\\\",\\\"smallUrl\\\":\\\"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae\\\",\\\"mediumUrl\\\":\\\"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae\\\",\\\"largeUrl\\\":\\\"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae\\\",\\\"fullUrl\\\":\\\"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae\\\"},\\\"infoText\\\":{\\\"title\\\":\\\"Fly Me To The Moon\\\",\\\"subText1\\\":\\\"Frank Sinatra\\\",\\\"subText2\\\":\\\"Jazz Classics\\\",\\\"multiLineMode\\\":false},\\\"mediaReference\\\":{\\\"namespace\\\":\\\"Alexa.Media.ExternalMediaPlayer\\\",\\\"name\\\":\\\"item\\\",\\\"value\\\":\\\"{\\\\\\\"contentId\\\\\\\":\\\\\\\"spotify:playlist:37i9dQZF1DXbITWG1ZJKYt\\\\\\\",\\\\\\\"externalItemId\\\\\\\":\\\\\\\"spotify:track:2dR5WkrpwylTuT3jRWNufa\\\\\\\"}\\\"}},\\\"playbackError\\\":false,\\\"errorMessage\\\":null}},\\\"name\\\":\\\"NotifyNowPlayingUpdated\\\"}\"}"}]}}}
--------abcde123
2024-10-08 11:52:21.169 [DEBUG] [trol.internal.handler.AccountHandler] - Processing CommandTO{command='NotifyNowPlayingUpdated', payload='{"messageId":"756d1fad-dd74-4184-9329-dcbd4e451b51","fallbackAllowed":true,"customerId":"yyy","update":{"type":"SessionUpdate","taskSessionId":"amzn1.echo-api.session.1b4238b2-5009-4779-8098-45c584e60509","update":{"type":"NotifyNowPlayingUpdated","cause":"PLAYBACK_STOPPED","nowPlayingData":{"@class":"com.amazon.alexa.media.access.shared.model.MusicNowPlayingData","transport":{"playPause":"ENABLED","next":"ENABLED","previous":"ENABLED","shuffle":"ENABLED","repeat":"ENABLED","seekForward":"HIDDEN","seekBackward":"HIDDEN","thumbsUp":"HIDDEN","thumbsDown":"HIDDEN"},"progress":{"visible":true,"mediaProgress":89899,"mediaLength":147146,"allowScrubbing":false,"showTiming":true},"playerState":"PLAYING","queueId":"spotify:playlist:37i9dQZF1DXbITWG1ZJKYt","mediaId":"spotify:track:2dR5WkrpwylTuT3jRWNufa","quality":{"name":"Default Quality","badge":{"altText":null,"url":"","contentType":null}},"provider":{"providerName":"Spotify","providerLogo":{"altText":"Spotify","url":"https://music-service-provider-logos.s3.amazonaws.com/dms-gui-logos/wordmark-logos/Spotify.png","contentType":"image/*"}},"mainArt":{"altText":null,"contentType":"image/jpeg","tinyUrl":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae","smallUrl":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae","mediumUrl":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae","largeUrl":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae","fullUrl":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae"},"infoText":{"title":"Fly Me To The Moon","subText1":"Frank Sinatra","subText2":"Jazz Classics","multiLineMode":false},"mediaReference":{"namespace":"Alexa.Media.ExternalMediaPlayer","name":"item","value":"{\"contentId\":\"spotify:playlist:37i9dQZF1DXbITWG1ZJKYt\",\"externalItemId\":\"spotify:track:2dR5WkrpwylTuT3jRWNufa\"}"}},"playbackError":false,"errorMessage":null}},"name":"NotifyNowPlayingUpdated"}', timeStamp=1728381144787}
2024-10-08 11:52:21.171 [WARN ] [trol.internal.push.PushStreamAdapter] - Exception while processing message
java.lang.NullPointerException: Cannot invoke "String.equals(Object)" because "this.currentlyPlayingQueueId" is null
	at org.smarthomej.binding.amazonechocontrol.internal.handler.EchoHandler.lambda$10(EchoHandler.java:976) ~[bundleFile:?]
	at java.util.Optional.ifPresent(Optional.java:178) ~[?:?]
	at org.smarthomej.binding.amazonechocontrol.internal.handler.EchoHandler.handleNowPlayingUpdated(EchoHandler.java:975) ~[bundleFile:?]
	at org.smarthomej.binding.amazonechocontrol.internal.handler.AccountHandler.lambda$22(AccountHandler.java:644) ~[bundleFile:?]
	at java.util.concurrent.ConcurrentHashMap$ValuesView.forEach(ConcurrentHashMap.java:4780) ~[?:?]
	at org.smarthomej.binding.amazonechocontrol.internal.handler.AccountHandler.onPushCommandReceived(AccountHandler.java:644) ~[bundleFile:?]
	at org.smarthomej.binding.amazonechocontrol.internal.push.PushConnection.onPushMessageReceived(PushConnection.java:199) ~[bundleFile:?]
	at java.util.ArrayList.forEach(ArrayList.java:1511) ~[?:?]
	at org.smarthomej.binding.amazonechocontrol.internal.push.PushStreamAdapter.onData(PushStreamAdapter.java:105) [bundleFile:?]
	at org.eclipse.jetty.http2.HTTP2Stream.notifyData(HTTP2Stream.java:658) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.HTTP2Stream.onData(HTTP2Stream.java:394) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.HTTP2Stream.process(HTTP2Stream.java:315) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.HTTP2Session.onData(HTTP2Session.java:287) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.HTTP2Connection$ParserListener.onData(HTTP2Connection.java:400) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.parser.BodyParser.notifyData(BodyParser.java:108) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.parser.DataBodyParser.onData(DataBodyParser.java:150) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.parser.DataBodyParser.onData(DataBodyParser.java:145) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.parser.DataBodyParser.parse(DataBodyParser.java:111) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.parser.Parser.parseBody(Parser.java:222) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.parser.Parser.parse(Parser.java:151) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.HTTP2Connection$HTTP2Producer.produce(HTTP2Connection.java:271) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produceTask(EatWhatYouKill.java:362) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:186) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:137) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.HTTP2Connection.produce(HTTP2Connection.java:193) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.HTTP2Connection.onFillable(HTTP2Connection.java:148) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.http2.HTTP2Connection$FillableCallback.succeeded(HTTP2Connection.java:371) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.54.v20240208]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.54.v20240208]
2024-10-08 11:52:21.343 [TRACE] [trol.internal.push.PushStreamAdapter] - Received raw data Content-Type: application/json
{"directive":{"header":{"namespace":"Alexa.Mobile.Push","name":"RenderUpdate","messageId":"e5a612f1-4772-428b-8fc1-48206cf5367a"},"payload":{"renderingUpdates":[{"route":"EventBus:tcomm::message","resourceId":"PUSH_EQUALIZER_STATE_CHANGE","resourceMetadata":"{\"command\":\"PUSH_EQUALIZER_STATE_CHANGE\",\"timeStamp\":1728381144969,\"payload\":\"{\\\"dopplerId\\\":{\\\"deviceSerialNumber\\\":\\\"zzz\\\",\\\"deviceType\\\":\\\"aaa\\\"},\\\"bass\\\":0,\\\"midrange\\\":0,\\\"treble\\\":0,\\\"destinationUserId\\\":\\\"yyy\\\"}\"}"}]}}}
--------abcde123
2024-10-08 11:52:21.345 [DEBUG] [trol.internal.handler.AccountHandler] - Processing CommandTO{command='PUSH_EQUALIZER_STATE_CHANGE', payload='{"dopplerId":{"deviceSerialNumber":"zzz","deviceType":"aaa"},"bass":0,"midrange":0,"treble":0,"destinationUserId":"yyy"}', timeStamp=1728381144969}
2024-10-08 11:52:21.346 [DEBUG] [control.internal.handler.EchoHandler] - Handle push command PUSH_EQUALIZER_STATE_CHANGE
2024-10-08 11:52:21.359 [TRACE] [trol.internal.push.PushStreamAdapter] - Received raw data Content-Type: application/json
{"directive":{"header":{"namespace":"Alexa.Mobile.Push","name":"RenderUpdate","messageId":"67f57570-cb40-4f48-9eec-9ee3c3336489"},"payload":{"renderingUpdates":[{"route":"EventBus:tcomm::message","resourceId":"PUSH_VOLUME_CHANGE","resourceMetadata":"{\"command\":\"PUSH_VOLUME_CHANGE\",\"timeStamp\":1728381144985,\"payload\":\"{\\\"dopplerId\\\":{\\\"deviceSerialNumber\\\":\\\"zzz\\\",\\\"deviceType\\\":\\\"aaa\\\"},\\\"volumeSetting\\\":40,\\\"isMuted\\\":false,\\\"destinationUserId\\\":\\\"yyy\\\"}\"}"}]}}}
--------abcde123
2024-10-08 11:52:21.360 [DEBUG] [trol.internal.handler.AccountHandler] - Processing CommandTO{command='PUSH_VOLUME_CHANGE', payload='{"dopplerId":{"deviceSerialNumber":"zzz","deviceType":"aaa"},"volumeSetting":40,"isMuted":false,"destinationUserId":"yyy"}', timeStamp=1728381144985}
2024-10-08 11:52:21.361 [DEBUG] [control.internal.handler.EchoHandler] - Handle push command PUSH_VOLUME_CHANGE
2024-10-08 11:52:21.560 [TRACE] [trol.internal.push.PushStreamAdapter] - Received raw data Content-Type: application/json
{"directive":{"header":{"namespace":"Alexa.Mobile.Push","name":"RenderUpdate","messageId":"ce14ecad-4e7e-4bb9-99c9-e1aaa28db899"},"payload":{"renderingUpdates":[{"route":"EventBus:tcomm::message","resourceId":"PUSH_AUDIO_PLAYER_STATE","resourceMetadata":"{\"command\":\"PUSH_AUDIO_PLAYER_STATE\",\"timeStamp\":1728381145177,\"payload\":\"{\\\"dopplerId\\\":{\\\"deviceSerialNumber\\\":\\\"zzz\\\",\\\"deviceType\\\":\\\"aaa\\\"},\\\"audioPlayerState\\\":\\\"PLAYING\\\",\\\"quality\\\":null,\\\"error\\\":false,\\\"errorMessage\\\":null,\\\"mediaReferenceId\\\":\\\"EMP_ALEXA-40d6c37a-68f0-4d4e-af1c-29b94b585179:spotify:track:2dR5WkrpwylTuT3jRWNufa\\\",\\\"destinationUserId\\\":\\\"yyy\\\"}\"}"}]}}}
--------abcde123
2024-10-08 11:52:21.561 [DEBUG] [trol.internal.handler.AccountHandler] - Processing CommandTO{command='PUSH_AUDIO_PLAYER_STATE', payload='{"dopplerId":{"deviceSerialNumber":"zzz","deviceType":"aaa"},"audioPlayerState":"PLAYING","quality":null,"error":false,"errorMessage":null,"mediaReferenceId":"EMP_ALEXA-40d6c37a-68f0-4d4e-af1c-29b94b585179:spotify:track:2dR5WkrpwylTuT3jRWNufa","destinationUserId":"yyy"}', timeStamp=1728381145177}
2024-10-08 11:52:21.561 [DEBUG] [control.internal.handler.EchoHandler] - Handle push command PUSH_AUDIO_PLAYER_STATE
2024-10-08 11:52:21.562 [DEBUG] [rol.internal.util.HttpRequestBuilder] - > GET: https://eu-api-alexa.amazon.com/api/np/player?deviceSerialNumber=zzz&deviceType=aaa&screenWidth=1440 (available: 2)
2024-10-08 11:52:21.563 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/np/player?deviceSerialNumber=zzz&deviceType=aaa&screenWidth=1440, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=1426054511], cookies = [sid=bV0tLBjMud1GRy==|af73dRSF3q8S4N1fqMMLnfzwTy13s+7+Bo3gmAVJSmU=, csrf=1426054511, x-main=gXolkPqEYOJIBCwVmd69CCibVEzhTtDq, at-main=Atza|HGRvTzTt5V9Z3fUgbW9QeHLQYEb4vIFX3t_vbj4QnChQCEX-F0bRl1Uo9WizKO5Ngqj1MLqB2X_IQVhCfWfINPUv9wsJCCZCEfxHqxazRQNB2Eom8Ab1B-NaimTqfCW6Rfb03pNm3sHieYatCFTGchFICtnn3mteTv-5HwtIiny6xZljOSZMqLc__CM7cYXQMb59XM7KO9E4ziFF5pF22-n3jBqXY6648ceezGzQ, sess-at-main=+5C9g6BMQZqDQdmWhT9mngwQwrLmm7NICN2UWjPgf7c=, session-id=135-1233478-0053710, session-id-time=2359097771l, ubid-main=135-7816253-4117326, session-token=ytcy00+u+A4WCr0fVidQHt+WWireGl1ogsmnf5GoNz4uqWF0K12iPkBx8QvjY0zj1ombEsPvHC0Y7ApSctjLVdxyP3pGourJboerHjMvMBLGeg0lENArOXpQyrF1QEJRb4CG1U1mCxn62jPWDJQFYddSgNhRdwKT6iGFjskDc+kSuiSA4GNs3NcbUSEPDoNqRdHe4a62v2vt8imcqnjxsCwj137qqY44eRXPXlAUyoFtDK50srJiBbLsWdhyzU0sARSDTl5UWRZFsWK6zJymEyDql56I/v2jUi2IA77Ss/ruWZMqHen3JmND1tG0Bp9BJHOd1+7SGD7jvSftc3jPX0kpbomrJ/kpFB7alKoZEbIx8mDRYNQ==], content = null
2024-10-08 11:52:21.895 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/np/player?deviceSerialNumber=zzz&deviceType=aaa&screenWidth=1440: 200, headers = [Content-Type=application/json,Content-Length=1573,Connection=keep-alive,Server=Server,Date=Tue, 08 Oct 2024 09:52:25 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=ZTYZVNYF2V17FBM1Q4DR,x-amzn-RequestId=377cd5f5-d932-4f58-bb4f-baeba442e75d,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Miss from cloudfront,Via=1.1 3f7bbc22c659b2b7470c819d073f58b6.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P3,X-Amz-Cf-Id=VvMUHIMH5oL3ar70d7fpn0933O_UUcqG7roVhRISLitZf9m2CFd6Aw==], content = {"playerInfo":{"hint":null,"infoText":{"header":null,"headerSubtext1":null,"multiLineMode":false,"subText1":"Frank Sinatra","subText2":"Jazz Classics","title":"Fly Me To The Moon"},"isPlayingInLemur":false,"lemurVolume":null,"lyrics":null,"mainArt":{"altText":"Album Art","artType":"UrlArtSource","contentType":"image/jpeg","url":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae"},"mediaId":"spotify:track:2dR5WkrpwylTuT3jRWNufa","miniArt":{"altText":"Album Art","artType":"UrlArtSource","contentType":"image/jpeg","url":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae"},"miniInfoText":{"header":null,"headerSubtext1":null,"multiLineMode":false,"subText1":"Frank Sinatra","subText2":"Jazz Classics","title":"Fly Me To The Moon"},"playbackSource":null,"playingInLemurId":null,"progress":{"allowScrubbing":true,"locationInfo":null,"mediaLength":147,"mediaProgress":0,"showTiming":true,"visible":true},"provider":{"artOverlay":null,"fallbackMainArt":null,"providerDisplayName":"Spotify","providerLogo":{"altText":null,"artType":"UrlArtSource","contentType":"image/png","url":"https://music-service-provider-logos.s3.amazonaws.com/dms-gui-logos/wordmark-logos/Spotify.png"},"providerName":"Spotify"},"quality":null,"queueId":"spotify:artist:1Mxqyy3pSjf8kZZL4QVxS0","state":"PLAYING","template":null,"transport":{"closedCaptions":null,"layoutType":"MusicTransportLayout","lyrics":null,"next":"ENABLED","playPause":"ENABLED","previous":"ENABLED","repeat":"DISABLED","shuffle":"ENABLED"},"upNextItems":null,"volume":{"muted":false,"volume":40}}}
2024-10-08 11:52:21.993 [TRACE] [trol.internal.push.PushStreamAdapter] - Received raw data Content-Type: application/json
{"directive":{"header":{"namespace":"Alexa.Mobile.Push","name":"RenderUpdate","messageId":"d3e8130b-6d5e-4bb7-96a6-3c349f46c820"},"payload":{"renderingUpdates":[{"route":"EventBus:tcomm::message","resourceId":"NotifyMediaSessionsUpdated","resourceMetadata":"{\"command\":\"NotifyMediaSessionsUpdated\",\"timeStamp\":1728381145615,\"payload\":\"{\\\"messageId\\\":\\\"553fff83-6a54-43f4-89a5-786adaa6caee\\\",\\\"fallbackAllowed\\\":true,\\\"customerId\\\":\\\"yyy\\\",\\\"update\\\":{\\\"type\\\":\\\"NotifyMediaSessionsUpdated\\\"},\\\"name\\\":\\\"NotifyMediaSessionsUpdated\\\"}\"}"}]}}}
--------abcde123
2024-10-08 11:52:21.994 [DEBUG] [trol.internal.handler.AccountHandler] - Processing CommandTO{command='NotifyMediaSessionsUpdated', payload='{"messageId":"553fff83-6a54-43f4-89a5-786adaa6caee","fallbackAllowed":true,"customerId":"yyy","update":{"type":"NotifyMediaSessionsUpdated"},"name":"NotifyMediaSessionsUpdated"}', timeStamp=1728381145615}
2024-10-08 11:52:21.994 [DEBUG] [rol.internal.util.HttpRequestBuilder] - > GET: https://eu-api-alexa.amazon.com/api/np/list-media-sessions?deviceSerialNumber=zzz&deviceType=aaa (available: 2)
2024-10-08 11:52:21.995 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/np/list-media-sessions?deviceSerialNumber=zzz&deviceType=aaa, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=1426054511], cookies = [sid=bV0tLBjMud1GRy==|af73dRSF3q8S4N1fqMMLnfzwTy13s+7+Bo3gmAVJSmU=, csrf=1426054511, x-main=gXolkPqEYOJIBCwVmd69CCibVEzhTtDq, at-main=Atza|HGRvTzTt5V9Z3fUgbW9QeHLQYEb4vIFX3t_vbj4QnChQCEX-F0bRl1Uo9WizKO5Ngqj1MLqB2X_IQVhCfWfINPUv9wsJCCZCEfxHqxazRQNB2Eom8Ab1B-NaimTqfCW6Rfb03pNm3sHieYatCFTGchFICtnn3mteTv-5HwtIiny6xZljOSZMqLc__CM7cYXQMb59XM7KO9E4ziFF5pF22-n3jBqXY6648ceezGzQ, sess-at-main=+5C9g6BMQZqDQdmWhT9mngwQwrLmm7NICN2UWjPgf7c=, session-id=135-1233478-0053710, session-id-time=2359097771l, ubid-main=135-7816253-4117326, session-token=ytcy00+u+A4WCr0fVidQHt+WWireGl1ogsmnf5GoNz4uqWF0K12iPkBx8QvjY0zj1ombEsPvHC0Y7ApSctjLVdxyP3pGourJboerHjMvMBLGeg0lENArOXpQyrF1QEJRb4CG1U1mCxn62jPWDJQFYddSgNhRdwKT6iGFjskDc+kSuiSA4GNs3NcbUSEPDoNqRdHe4a62v2vt8imcqnjxsCwj137qqY44eRXPXlAUyoFtDK50srJiBbLsWdhyzU0sARSDTl5UWRZFsWK6zJymEyDql56I/v2jUi2IA77Ss/ruWZMqHen3JmND1tG0Bp9BJHOd1+7SGD7jvSftc3jPX0kpbomrJ/kpFB7alKoZEbIx8mDRYNQ==], content = null
2024-10-08 11:52:22.284 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/np/list-media-sessions?deviceSerialNumber=zzz&deviceType=aaa: 200, headers = [Content-Type=application/json,Content-Length=2245,Connection=keep-alive,Server=Server,Date=Tue, 08 Oct 2024 09:52:25 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=N7XSAQ64Q641CD7GRX0S,x-amzn-RequestId=598e0ab4-2672-4451-bd56-bdc6a395e173,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Miss from cloudfront,Via=1.1 3f7bbc22c659b2b7470c819d073f58b6.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P3,X-Amz-Cf-Id=xXvAZLp8AmoVzGHDKlCJZz8xpMi3gI35nkA60WycsEvpR9_xcOibpw==], content = {"mediaSessionList":[{"castEligibility":{"isEligible":true,"reasonCode":"UNCONSTRAINED"},"endpointList":[{"__type":"NPSingletonEndpoint:http://internal.amazon.com/coral/com.amazon.dee.web.coral.model/","encryptedFriendlyName":"AAAAAAAAAQCASn4OOWdKk/lnPcyYmI3hKQAAAAAAAACJRFCgdNuFDK6Akctx0055fSrtdFNdtCfiOE4kI1e1eaCcUvMgOBsppA==","id":{"deviceSerialNumber":"zzz","deviceType":"aaa","softwareVersion":null}}],"nowPlayingData":{"__type":"MusicNowPlayingData:http://internal.amazon.com/coral/com.amazon.alexa.media.access.shared.model/","infoText":{"multiLineMode":false,"subText1":"Frank Sinatra","subText2":"Jazz Classics","title":"Fly Me To The Moon"},"mainArt":{"altText":null,"contentType":"image/jpeg","fullUrl":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae","largeUrl":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae","mediumUrl":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae","smallUrl":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae","tinyUrl":"https://i.scdn.co/image/ab67616d0000b273b19cb81319fbfd9ed54baeae"},"mediaId":"spotify:track:2dR5WkrpwylTuT3jRWNufa","mediaReference":{"name":"item","namespace":"Alexa.Media.ExternalMediaPlayer","value":"{\"contentId\":\"spotify:playlist:37i9dQZF1DXbITWG1ZJKYt\",\"externalItemId\":\"spotify:track:2dR5WkrpwylTuT3jRWNufa\"}"},"playerState":"PLAYING","progress":{"allowScrubbing":true,"mediaLength":147147,"mediaProgress":921,"showTiming":true,"visible":true},"provider":{"providerLogo":{"altText":"Spotify","contentType":"image/*","url":"https://music-service-provider-logos.s3.amazonaws.com/dms-gui-logos/wordmark-logos/Spotify.png"},"providerName":"Spotify"},"quality":{"badge":{"altText":null,"contentType":null,"url":""},"name":"Default Quality"},"queueId":"spotify:playlist:37i9dQZF1DXbITWG1ZJKYt","transport":{"__type":"MusicTransportLayout:http://internal.amazon.com/coral/com.amazon.alexa.media.access.shared.model/","next":"ENABLED","playPause":"ENABLED","previous":"ENABLED","repeat":"ENABLED","seekBackward":"HIDDEN","seekForward":"HIDDEN","shuffle":"ENABLED","thumbsDown":"HIDDEN","thumbsUp":"HIDDEN"}},"taskSessionId":"amzn1.echo-api.session.1b4238b2-5009-4779-8098-45c584e60509"}]}
Did another test on a vanilla openHAB 4.2.2 with my amazon account deactivated on my “original” openHAB.
Same thing here though. I did only activate one Echo device.
I just updated the textCommand channel with “lights on”, which should turn on the lights.
2024-10-13 14:10:56.785 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Echo_Schlafzimmer_Befehl' changed from Licht aus to Licht an
nothing happens - except this (those three lines repeat every 1 to 2 seconds!) - and I don’t even have alexa-notifications active presently?
2024-10-13 14:10:55.660 [TRACE] [pRequestBuilder$HttpResponseListener] - < GET to https://eu-api-alexa.amazon.com/api/notifications: 200, headers = [Content-Type=application/json,Content-Length=48744,Connection=keep-alive,Server=Server,Date=Sun, 13 Oct 2024 12:10:55 GMT,Strict-Transport-Security=max-age=0; includeSubDomains;,x-amz-rid=YQ8X95T62P1B9VDAR5XB,x-amzn-RequestId=21d9a80a-9ca9-45bf-b319-641b22de656e,X-Amz-Date=Sun, 13 Oct 2024 12:10:55 GMT,Vary=Content-Type,Accept-Encoding,User-Agent,X-Cache=Miss from cloudfront,Via=1.1 18d0e038a55eccdc9f0ad716edf64962.cloudfront.net (CloudFront),X-Amz-Cf-Pop=MUC50-P3,X-Amz-Cf-Id=T_T8KYq1PK2GJgMc4WLkJFA0_-bvJ-pfE5BvQHoJKCg_nE7PmKAc1A==], content = {"notifications":[{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":"amzn1.alexa.automation.978e66a7-e2d4-4cb5-924a-18d2bc622272","createdDate":1716919902699,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":null,"deviceType":null,"extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"amzn1.alexa.automation.978e66a7-e2d4-4cb5-924a-18d2bc622272_TMWAutomation","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":0,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"amzn1.alexa.automation.978e66a7-e2d4-4cb5-924a-18d2bc622272_TMWAutomation","originalDate":null,"originalDurationInMillis":0,"originalTime":null,"personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":true,"recurringPattern":"P1D","remainingTime":0,"reminderAppLabel":"Rain or Snow Forecast for Gersthofen","reminderLabel":"Rain or Snow Forecast for Gersthofen","reminderSubLabel":"AAAAAAAAAQBD9ZZVB1gsAKj8NN7ZjNhoQAAAAAAAAADmMQ3XDizg0GLITKuavPMMDYQQAqSsdG63exlK6Jzal8Im2FrloHD7FYmJ3sS8FxPq93E6vlETj56ZLVf3kF/K","showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":null,"snoozedToTime":null,"sound":null,"status":"ON","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":{"deliveryStyle":"STANDARD","pushEnabled":true,"recurrenceEligibility":null,"scheduledEventType":"INDETERMINATE","scheduledOffsetInMillis":0},"triggerTime":0,"type":"TMWNotification","version":"1"},{"alarmLabel":null,"alarmTime":1728813600000,"assigner":null,"automationId":null,"createdDate":1651930432104,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G091AA07042716SV","deviceType":"A2U21SRK4QGSE1","extensibleAttribute":null,"followUpMetadata":{"followUpStatus":null,"requiresFollowUp":false},"geoLocationTriggerData":null,"id":"A2U21SRK4QGSE1-G091AA07042716SV-664b4edc-a8da-359c-89f1-c53e88a96110_REMINDER","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":"2024-10-13T10:00:14.093Z","lastUpdatedDate":1728654682628,"loopCount":null,"mrmGroupContext":{"groupId":null,"groupType":null},"musicAlarmId":null,"musicEntity":null,"notificationIndex":"664b4edc-a8da-359c-89f1-c53e88a96110","originalDate":"2024-10-13","originalDurationInMillis":0,"originalTime":null,"personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":{"byMonthDays":[],"byMonths":[],"byWeekDays":[],"flexibleRecurringPatternType":"EVERY_X_DAYS","frequency":null,"intervals":[2],"nextTriggerTimes":["2024-10-15T12:00:00.000+02:00"],"notificationTimes":["12:00:00.000"],"offset":[],"recurEndDate":null,"recurEndTime":null,"recurStartDate":"2021-08-18","recurStartTime":"00:00:00.000","recurrenceRules":["FREQ=DAILY;BYHOUR=12;BYMINUTE=0;BYSECOND=0;INTERVAL=2;"]},"recurrenceEligibility":false,"recurringPattern":"P2D","remainingTime":0,"reminderAppLabel":null,"reminderLabel":"Pflanzen gießen","reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":null,"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"ON","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Reminder","version":"2384"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1637032370479,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090XG11047605EC","deviceType":"A1RABVCI4QCIKC","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A1RABVCI4QCIKC-G090XG11047605EC-464be373-192b-30f9-9cc5-fa381ea1ae87","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1658549481338,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"464be373-192b-30f9-9cc5-fa381ea1ae87","originalDate":"2022-07-23","originalDurationInMillis":0,"originalTime":"06:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"9"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1684632812082,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090XG11047506V4","deviceType":"A1RABVCI4QCIKC","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A1RABVCI4QCIKC-G090XG11047506V4-0f12701b-7cc0-3fee-9efa-6c8467e54c99","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1685692807257,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"0f12701b-7cc0-3fee-9efa-6c8467e54c99","originalDate":"2023-06-02","originalDurationInMillis":0,"originalTime":"10:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"6"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1635645278368,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090XG11047605EC","deviceType":"A1RABVCI4QCIKC","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A1RABVCI4QCIKC-G090XG11047605EC-2e7df3b5-c179-359d-85b9-c9f0e04e5913","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1653813028099,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"2e7df3b5-c179-359d-85b9-c9f0e04e5913","originalDate":"2022-05-29","originalDurationInMillis":0,"originalTime":"10:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"6"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1695251370463,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090U50784453MQ7","deviceType":"A32DOYMUN6DTXA","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A32DOYMUN6DTXA-G090U50784453MQ7-d87adc1c-a5ba-377c-aa6c-36b506d65cdf","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1695274466607,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"d87adc1c-a5ba-377c-aa6c-36b506d65cdf","originalDate":"2023-09-21","originalDurationInMillis":0,"originalTime":"07:30:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Glimmer","folder":null,"id":"system_alerts_melodic_06","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_06.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1727467284362,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G0922K0724770KP6","deviceType":"A4ZXE0RM7LQ7A","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A4ZXE0RM7LQ7A-G0922K0724770KP6-27e59fd8-2295-392c-8897-af15fbd6bb62","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1727503224714,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"27e59fd8-2295-392c-8897-af15fbd6bb62","originalDate":"2024-09-28","originalDurationInMillis":0,"originalTime":"08:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Pulsar","folder":null,"id":"system_alerts_rhythmic_02","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_rhythmic_02.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1651866668396,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090XG11047605EC","deviceType":"A1RABVCI4QCIKC","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A1RABVCI4QCIKC-G090XG11047605EC-40975f99-abc2-366d-a873-b637ba557a96","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1651874447572,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"40975f99-abc2-366d-a873-b637ba557a96","originalDate":"2022-05-07","originalDurationInMillis":0,"originalTime":"00:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1651516635329,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090XG11047605EC","deviceType":"A1RABVCI4QCIKC","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A1RABVCI4QCIKC-G090XG11047605EC-08702920-cf88-3e29-b1be-3993ca7b9091","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1651521875118,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"08702920-cf88-3e29-b1be-3993ca7b9091","originalDate":"2022-05-02","originalDurationInMillis":0,"originalTime":"22:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1673393173070,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090XG11047506V4","deviceType":"A1RABVCI4QCIKC","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A1RABVCI4QCIKC-G090XG11047506V4-7d5c4d5e-e81d-363b-b5c2-35b5eaf581c4","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1673413613740,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"7d5c4d5e-e81d-363b-b5c2-35b5eaf581c4","originalDate":"2023-01-11","originalDurationInMillis":0,"originalTime":"06:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1669352499024,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"e67631b7fbf440b4b0fec0a9e94df32f","deviceType":"A2OSP3UA4VC85F","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A2OSP3UA4VC85F-e67631b7fbf440b4b0fec0a9e94df32f-04bec95e-b9c4-3298-9c15-354973913170","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1675232502663,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"04bec95e-b9c4-3298-9c15-354973913170","originalDate":"2023-02-01","originalDurationInMillis":0,"originalTime":"07:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"9"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1716150433158,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G0922K0724770KP6","deviceType":"A4ZXE0RM7LQ7A","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A4ZXE0RM7LQ7A-G0922K0724770KP6-2e637cb6-9387-3538-8fd4-c8621c55b25f","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1726549222727,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"2e637cb6-9387-3538-8fd4-c8621c55b25f","originalDate":"2024-09-17","originalDurationInMillis":0,"originalTime":"07:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Pulsar","folder":null,"id":"system_alerts_rhythmic_02","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_rhythmic_02.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"21"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1708969857280,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G091AA07042716SV","deviceType":"A2U21SRK4QGSE1","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A2U21SRK4QGSE1-G091AA07042716SV-8a376fba-0a1b-3bb0-b70d-11901f0fa41c","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1708974782401,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"8a376fba-0a1b-3bb0-b70d-11901f0fa41c","originalDate":"2024-02-26","originalDurationInMillis":0,"originalTime":"20:10:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1663264697130,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G091AA07042716SV","deviceType":"A2U21SRK4QGSE1","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A2U21SRK4QGSE1-G091AA07042716SV-7f4aaad1-4a10-3347-a218-c7e0a65c8002","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1663264746253,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"7f4aaad1-4a10-3347-a218-c7e0a65c8002","originalDate":"2022-09-15","originalDurationInMillis":0,"originalTime":"19:59:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1707451258316,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G2A1A605226302UT","deviceType":"A3RMGO6LYLH7YN","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A3RMGO6LYLH7YN-G2A1A605226302UT-324e0c5e-defe-386d-b9c2-c23496651529","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1707462298060,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"324e0c5e-defe-386d-b9c2-c23496651529","originalDate":"2024-02-09","originalDurationInMillis":0,"originalTime":"08:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1717650932405,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G0922K0724770KP6","deviceType":"A4ZXE0RM7LQ7A","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A4ZXE0RM7LQ7A-G0922K0724770KP6-e4ea6b31-8c19-3a84-9c33-01ce94c1cd4a","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1717651812745,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"e4ea6b31-8c19-3a84-9c33-01ce94c1cd4a","originalDate":"2024-06-06","originalDurationInMillis":0,"originalTime":"07:30:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Pulsar","folder":null,"id":"system_alerts_rhythmic_02","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_rhythmic_02.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1636744933152,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090XG11047605EC","deviceType":"A1RABVCI4QCIKC","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A1RABVCI4QCIKC-G090XG11047605EC-de55fc15-9b41-34b8-8cb1-2fe755a50622","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1636751933485,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"de55fc15-9b41-34b8-8cb1-2fe755a50622","originalDate":"2021-11-12","originalDurationInMillis":0,"originalTime":"23:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"4"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1695251377848,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090U50784453MQ7","deviceType":"A32DOYMUN6DTXA","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A32DOYMUN6DTXA-G090U50784453MQ7-3d70e912-0205-3eb0-b215-5ea7ec5a8888","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1695272451812,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"3d70e912-0205-3eb0-b215-5ea7ec5a8888","originalDate":"2023-09-21","originalDurationInMillis":0,"originalTime":"07:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Glimmer","folder":null,"id":"system_alerts_melodic_06","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_06.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1605202454250,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090U50784453MQ7","deviceType":"A32DOYMUN6DTXA","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A32DOYMUN6DTXA-G090U50784453MQ7-022bf199-c7b0-30b9-a7e9-e57b11c17889","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1605204027883,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"022bf199-c7b0-30b9-a7e9-e57b11c17889","originalDate":"2020-11-12","originalDurationInMillis":0,"originalTime":"19:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Glimmer","folder":null,"id":"system_alerts_melodic_06","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_06.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1719702372676,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G0922K0724770KP6","deviceType":"A4ZXE0RM7LQ7A","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A4ZXE0RM7LQ7A-G0922K0724770KP6-18c090b4-8fe2-38da-b3bd-a5a5e731f7e0","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1719716426526,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"18c090b4-8fe2-38da-b3bd-a5a5e731f7e0","originalDate":"2024-06-30","originalDurationInMillis":0,"originalTime":"05:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Pulsar","folder":null,"id":"system_alerts_rhythmic_02","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_rhythmic_02.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1663264754842,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G091AA07042716SV","deviceType":"A2U21SRK4QGSE1","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A2U21SRK4QGSE1-G091AA07042716SV-c83c8701-70e1-3a2d-ad61-db7f38afea34","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1663264805541,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"c83c8701-70e1-3a2d-ad61-db7f38afea34","originalDate":"2022-09-15","originalDurationInMillis":0,"originalTime":"20:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1663264478483,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G091AA07042716SV","deviceType":"A2U21SRK4QGSE1","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A2U21SRK4QGSE1-G091AA07042716SV-2dac20fc-9bdf-3967-bca5-d9f628c61fdc","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1663264705921,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"2dac20fc-9bdf-3967-bca5-d9f628c61fdc","originalDate":"2022-09-15","originalDurationInMillis":0,"originalTime":"19:58:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1684718009385,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090XG11047506V4","deviceType":"A1RABVCI4QCIKC","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A1RABVCI4QCIKC-G090XG11047506V4-f484cdaa-db21-3269-8779-c6e2b5a4d47b","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1684741515260,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"f484cdaa-db21-3269-8779-c6e2b5a4d47b","originalDate":"2023-05-22","originalDurationInMillis":0,"originalTime":"09:45:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1684372299043,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090XG11047506V4","deviceType":"A1RABVCI4QCIKC","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A1RABVCI4QCIKC-G090XG11047506V4-3f778cb2-86ca-3431-b04b-47ae956b8f65","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1684393233366,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"3f778cb2-86ca-3431-b04b-47ae956b8f65","originalDate":"2023-05-18","originalDurationInMillis":0,"originalTime":"09:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1717620316582,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G0922K0724770KP6","deviceType":"A4ZXE0RM7LQ7A","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A4ZXE0RM7LQ7A-G0922K0724770KP6-ae403d8a-727c-3a03-8d42-05048e0739bd","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1721449826566,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"ae403d8a-727c-3a03-8d42-05048e0739bd","originalDate":"2024-07-20","originalDurationInMillis":0,"originalTime":"06:30:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Pulsar","folder":null,"id":"system_alerts_rhythmic_02","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_rhythmic_02.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"6"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1670706637857,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G091AA07042716SV","deviceType":"A2U21SRK4QGSE1","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A2U21SRK4QGSE1-G091AA07042716SV-0f430186-dbe7-3ad9-a875-5a1e9e22e567","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1670814000887,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"0f430186-dbe7-3ad9-a875-5a1e9e22e567","originalDate":"2022-12-12","originalDurationInMillis":0,"originalTime":"03:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1719433739952,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G0922K0724770KP6","deviceType":"A4ZXE0RM7LQ7A","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A4ZXE0RM7LQ7A-G0922K0724770KP6-d21a367f-1081-3ab8-a2f2-ef3c79ae7094","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1728705621640,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"d21a367f-1081-3ab8-a2f2-ef3c79ae7094","originalDate":"2024-10-12","originalDurationInMillis":0,"originalTime":"06:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Pulsar","folder":null,"id":"system_alerts_rhythmic_02","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_rhythmic_02.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"15"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1723244319500,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G091AA07042716SV","deviceType":"A2U21SRK4QGSE1","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A2U21SRK4QGSE1-G091AA07042716SV-4ddd7415-276e-36fb-8a7e-92a0c453d166","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1723247407058,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"4ddd7415-276e-36fb-8a7e-92a0c453d166","originalDate":"2024-08-10","originalDurationInMillis":0,"originalTime":"01:50:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1653445160483,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090XG11047605EC","deviceType":"A1RABVCI4QCIKC","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A1RABVCI4QCIKC-G090XG11047605EC-6d8c947b-6407-35d8-8dd7-248859d6784d","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1655791224974,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"6d8c947b-6407-35d8-8dd7-248859d6784d","originalDate":"2022-06-21","originalDurationInMillis":0,"originalTime":"08:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"6"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1707451264700,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G2A1A605226302UT","deviceType":"A3RMGO6LYLH7YN","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A3RMGO6LYLH7YN-G2A1A605226302UT-49dff459-2a5b-3fcc-a05a-db765963e687","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1707465610535,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"49dff459-2a5b-3fcc-a05a-db765963e687","originalDate":"2024-02-09","originalDurationInMillis":0,"originalTime":"09:00:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Simple Alarm","folder":null,"id":"system_alerts_melodic_01","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_01.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"},{"alarmLabel":null,"alarmTime":0,"assigner":null,"automationId":null,"createdDate":1605202438174,"deferredAtTime":null,"deliveryMetadata":null,"deliveryType":null,"deviceName":null,"deviceSerialNumber":"G090U50784453MQ7","deviceType":"A32DOYMUN6DTXA","extensibleAttribute":null,"followUpMetadata":null,"geoLocationTriggerData":null,"id":"A32DOYMUN6DTXA-G090U50784453MQ7-32deefca-ae53-3414-95d2-23f5cbbf3d0d","lastOccurrenceTimeInMilli":0,"lastTriggerTimeInUtc":null,"lastUpdatedDate":1605203131773,"loopCount":null,"mrmGroupContext":null,"musicAlarmId":null,"musicEntity":null,"notificationIndex":"32deefca-ae53-3414-95d2-23f5cbbf3d0d","originalDate":"2020-11-12","originalDurationInMillis":0,"originalTime":"18:45:00.000","personProfile":null,"primaryDeviceState":null,"provider":null,"rRuleData":null,"recurrenceEligibility":false,"recurringPattern":null,"remainingTime":0,"reminderAppLabel":null,"reminderLabel":null,"reminderSubLabel":null,"showDeregisteredWarning":null,"skillInfo":null,"sleepTrackingAlarmProperties":{"sleepTrackingEnabled":false},"snoozedToTime":null,"sound":{"displayName":"Glimmer","folder":null,"id":"system_alerts_melodic_06","isChildDirected":false,"numAssets":0,"pricing":null,"providerId":"ECHO","sampleUrl":"https://s3.amazonaws.com/deeappservice.prod.notificationtones/system_alerts_melodic_06.mp3","sampleVideoUrl":null,"skillUrl":null},"status":"OFF","targetPersonProfiles":null,"taskMetadata":null,"timeZoneId":null,"timerLabel":null,"tmwNotificationProperties":null,"triggerTime":0,"type":"Alarm","version":"3"}]}
2024-10-13 14:10:56.666 [DEBUG] [rol.internal.util.HttpRequestBuilder] - > GET: https://eu-api-alexa.amazon.com/api/notifications (available: 2)
2024-10-13 14:10:56.667 [TRACE] [rol.internal.util.HttpRequestBuilder] - > GET to https://eu-api-alexa.amazon.com/api/notifications, headers = [Accept-Encoding=gzip,User-Agent=AmazonWebView/Amazon Alexa/2.2.556530.0/iOS/16.6/iPhone,Accept-Language=en-US,DNT=1,Upgrade-Insecure-Requests=1,csrf=1169092153], cookies = [sid=+ZmxjvWtQWqqSLCrKw+1Gw==|ga8Lt/4KmPBtJFcJfRTKkBxWmv9nC55KVLMsDdCW96M=, csrf=1169092153, session-id-time=2359540719l, session-token=yS4Ozd2T0SQdq1nnQLVktJNOySdrVuifr9hwf0e6uEXCb2YHBQq43CYXWXtwQH/BSP3ZfXrH8QSEjoSGkB0shfNATrDcg5UPXwdyBfeM4uFNtRSwcITXLeYVZ17m18bmOMTf/Ix/ZhLGEXYX2fiqtbyhRh/hGDTo5MJToQW68K07NY/vpySoNtBqqQSw2Aglp3ILXWbp1UTkLjN48ArvP9DiGnoubvZvRnrWvplE3Zu9rmoiCw04og2zzoBGtbRBSSM+V4HavRm84MYZ7CKgW1lUdUbdYmLW8224IH5IOpQ06gH/37jidtUxFMRJcO4Cdob23WY6cGFWMXkCxmlPZLUkojDQ+DFu4JaOPfpdZ6xEEeu1dGmc/A==, session-id="144-9778434-0010100";$Path="/";$Domain=".amazon.com", ubid-main="133-2128688-5231555";$Path="/";$Domain=".amazon.com", x-main=""z6Q77In4FC42GefwvOd63JDnSWnhbzUX"";$Path="/";$Domain=".amazon.com", at-main=""Atza|IwEBIOBGKiWJKWTMRQoeh0WxDg_gmjIiYgs2MnblZtnHiCPxCCzpYCoiaMDlNohPCtcqjArStF3VoWspcviuKv2UTd13v0M1rjmp8iyb_ttD4-4gNlHv0CrhiqjykuQVhHI3waz-Dj7lZyWUrcWF0O1wB9E_cEh4u49qs9U28MIUyPlaQNeVtySRrvmVNteVPrcxfNBjYg0YwFCX8LdIDtse4iKfPi2bmmTHyie-khfY_Y8moOlHN0XLKK0sT_Ja8P_Z4rIT8K6zcSmY6NjQJGE7iUA4P1KlPavrv7JWe5CHyEPNKrkMdcNSSYkjZg9K9U3sr5rroUsRaat1LLFYFEvsc4VUqq7Hl_DRBWfAijKAnjAlB0FQbXPPOEflJQDpW-csf-qSenqF1tswlhSjdn5w1B_O"";$Path="/";$Domain=".amazon.com", sess-at-main=""TfuVjhmW8Prlum9zZvZe0id98btZiH6yExBiLGqiLn4="";$Path="/";$Domain=".amazon.com"], content = null
again some news! :wink:
Working now (at least the channels I use):
  • lastVoiceCommand
  • title
  • imageURL
still not working (at least the challens I use):
  • textToSpeech (even if textToSpeechVolume is at >0)
  • textCommand
  • announcement
What I did get was this WARN log-entry (again with a 401-error)
see above (Amazon Echo SmartJ Binding Too Many Requests - 429 error - #9 by binderth), where the URL was https://www.amazon.de/alexa-privacy/apd/rvh/customer-history-records, its now https://eu-api-alexa.amazon.com/api/behaviors/preview. This happened from yesterday to today. Don’t know, if it had something to do with changes I did, or amazon…?
2024-10-14 10:02:09.484 [WARN ] [ntrol.internal.connection.Connection] - execute sequence node fails with unexpected error
org.smarthomej.binding.amazonechocontrol.internal.ConnectionException: https://eu-api-alexa.amazon.com/api/behaviors/preview failed with code 401: Unauthorized
	at org.smarthomej.binding.amazonechocontrol.internal.util.HttpRequestBuilder$HttpResponseListener.onComplete(HttpRequestBuilder.java:385) ~[?:?]
	at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:218) ~[?:?]
	at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:210) ~[?:?]
	at org.eclipse.jetty.client.AuthenticationProtocolHandler$AuthenticationListener.forwardFailureComplete(AuthenticationProtocolHandler.java:297) ~[?:?]
	at org.eclipse.jetty.client.AuthenticationProtocolHandler$AuthenticationListener.onComplete(AuthenticationProtocolHandler.java:164) ~[?:?]
	at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:481) ~[?:?]
	at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:461) ~[?:?]
	at org.eclipse.jetty.client.HttpReceiver.responseSuccess(HttpReceiver.java:424) ~[?:?]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.messageComplete(HttpReceiverOverHTTP.java:374) ~[?:?]
	at org.eclipse.jetty.http.HttpParser.handleContentMessage(HttpParser.java:596) ~[?:?]
	at org.eclipse.jetty.http.HttpParser.parseContent(HttpParser.java:1669) ~[?:?]
	at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1552) ~[?:?]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:208) ~[?:?]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:148) ~[?:?]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:80) ~[?:?]
	at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
	at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) ~[?:?]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) ~[?:?]
	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) ~[?:?]
	at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) ~[?:?]
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) ~[?:?]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) ~[?:?]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) ~[?:?]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) ~[?:?]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) ~[?:?]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) ~[?:?]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) ~[?:?]
Since my modification I no longer have any disconnections and all my commands work perfectly.
  • player
  • textCommand
  • startroutine
  • textToSpeech
  • announcement
  • lastVoiceCommand
as long as it lasts !
your “modification” was this as described above?
Or did you change something else? and we’re still talking the SmartJ-variant of the binding?
Yes
Envoyé de mon iPhone
Thanks. I did change to “no discovery” and even tested it with a vanilla openHAB.
Still only get
  • lastVoiceCommand
  • title
  • imageURL
If I try one of the “write”-channels, I don’t even get anything in the logs, there’s just nothing happening?:
  • textToSpeech
  • textCommand
  • announcement
Have you restarted your Raspberry ?
| binderth Thomas Binder
October 18 |
Still only get
  • lastVoiceCommand
  • title
  • imageURL
  • textToSpeech
  • textCommand
  • announcement
