I think it’s because of a (more restictive) rate limit for more sensitive data as “lastVoiceCommand”. And as you also said, all the other channels work just fine.
at least I get these after someone speaks to alexa:
2025-07-01 11:38:11.191 [INFO ] [ntrol.internal.connection.Connection] - getting activities failed
org.smarthomej.binding.amazonechocontrol.internal.ConnectionException: https://www.amazon.de/alexa-privacy/apd/rvh/customer-history-records?startTime=1751362557463&endTime=1751362707463&maxRecordSize=1 failed with code 429: Too Many Requests
at org.smarthomej.binding.amazonechocontrol.internal.util.HttpRequestBuilder$HttpResponseListener.onComplete(HttpRequestBuilder.java:385) ~[?:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:218) ~[?:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:210) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:481) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:461) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.responseSuccess(HttpReceiver.java:424) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.messageComplete(HttpReceiverOverHTTP.java:374) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseFields(HttpParser.java:1188) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1560) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:208) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:148) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:80) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) ~[?:?]
at java.lang.Thread.run(Thread.java:840) [?:?]
my use case is to catch a “Alexa, put XY on the shopping list” and then add it to our Microsoft ToDo shopping list (Alexa and Microsoft ToDo). Perhaps I’ll have to move that on to a non-openHAB script and run that only every 30mins with not only the lastVoiceCommand but all of them, to avoid hitting the rate limit.
