Dom76
(Deiber)
May 8, 2023, 5:28am
21
hi, can you give me the link to download the working version of binding please. THANKS
Dom76
(Deiber)
May 8, 2023, 4:14pm
22
FYI, I updated OH with version 3.4.4 and the SmartHome/J Amazon Echo control Binding 3.2.16 binding for my Alexa equipment and I found the features of Last voice command, on the other hand I lost the functionality of TextCommand which no longer works!
jpalo
(Jussi Palo)
September 1, 2023, 5:51am
23
Should this work on OH 4.0.2 and amazonehocontrol binding 4.0.2? Sometime after updating to OH v4, lastVoiceCommand has stopped working, so a sanity-check type of question: should it work and is it just me?
Wolfgang_S
(Wolfgang_S)
September 1, 2023, 12:21pm
24
Amazon removed the undocumented feature.
There is an other thread with a potential workaround.
Cplant
(Cplant)
September 23, 2023, 8:04pm
26
Do you, by any chance, have the link to the workaround?
HALLO01
(Thomas)
September 23, 2023, 8:37pm
27
I think this is the thread
I have OH 3.4 and the solution I have given it for now has been the following:
You can use the api:
http://openhab:8080/amazonechocontrol/account1/PROXY/api/activities?startTime=&size=1&offset=1
which with size=1 returns the last command in JSON. In that command appears the serial number of the ECHO. Using a rule you extract that serial number and you know which ECHO has been used.
Through the Alexa app I created a routine (voice command: “Alexa, power”) that activates an OH item (Item power…
wawa79
(Yann)
December 2, 2023, 12:56pm
28
I implemented a workaround which principle is explained here:
Context
My OH setup strongly relies on AmazonEchoControl LastVoiceCommand (LVC) to locate where voice commands were issued and process them smartly depending on the location. This should be handled by Alexa server side but is so erratic and time-consuming to implement in the Alexa App that I preferred to implement my own logic.
I use 2 levels of proxied items which receive and forward command to items (indeed, there is also a 3rd level of functional proxy but this is not the topic here…
This is neither pythonic nor openhabic but at least it works
