I have a simple rule controlling the Mysensors dimmer. It was working fine in OH1 but after moving to OH2 throws an exception
2016-06-08 22:48:06.739 [INFO ] [marthome.event.ItemStateChangedEvent] - s_RGB_light changed from 140.0,100.0,100 to 0.0,0.0,0.0
2016-06-08 22:48:06.743 [ERROR] [.script.engine.ScriptExecutionThread] - Error during the execution of rule 'Set s_RGB_light value': An error occured during the script execution: The name '<XCastedExpressionImpl>.toColor()' cannot be resolved to an item or type.
Wonder what did i miss
rule "Set s_RGB_light value"
Item s_RGB_light changed
val Color color = (s_RGB_light.state as HSBType).toColor()
val String rgb = String::format("%1$02x%2$02x%3$02x", color.red, color.green, color.blue)
publish("mqt", "mygateway1-in/36/0/1/0/40", rgb)
Ok. Installed all the transormations
transformation = exec,javascript,jsonpath,map,regex,scale,xpath,xslt
Moved the rule to its own file rgb.rule. SO the only code in the file is (no comments nothing)
Still the same
2016-06-09 20:40:28.721 [INFO ] [marthome.event.ItemStateChangedEvent] - s_RGB_light changed from 315,36,100 to 319,52,100
2016-06-09 20:40:28.723 [ERROR] [.script.engine.ScriptExecutionThread] - Error during the execution of rule 'Set s_RGB_light value': An error occured during the script execution: The name '<XCastedExpressionImpl>.toColor()' cannot be resolved to an item or type.
