- Platform information:
- Hardware: Raspberry Pi 4
- openHAB version: 2.5
Hi all, I just wanted to share some insight I had regarding the use of the LG WebOS binding.
Specifically, how to figure out if the TV is ON or OFF.
You need to use to different methods to turn the TV ON and OFF.
To turn ON the TV you need to send a WOL packet via the WOL binding.
After the TV is ON you can use the power channel of the LG WebOS binding to turn it OFF.
However this power channel doesn’t seem to reliably represent the correct state of the TV. For example when I turned the TV OFF from the remote control, this item stayed in an ON state.
The way I decided to resolve this is to detect the state of the TV from the App ID channel (Application channel). It’s a string channel that contains the id of the app the TV is currently running. I noticed that when the TV is OFF the string gets cleared out.
So I used this item to detect whether the TV is ON or OFF and updated a virtual switch to represent the TV state. This switch is what I exposed to the UI and when the user interacts with it the rules activate the WOL and WebOS binding behind the scenes.
my items configuration:
Switch LR_TV_PowerWOL "Living Room TV WoL" <switch> {wol="255.255.255.255#??-??-??-??-??-??" } // replace ?? with the relevant mac address of the TV
Switch LR_TV_PowerBinding "Living Room TV OFF from binding" <switch> {channel="lgwebos:WebOSTV:e529500c-e871-8022-3bb1-d8cb828f5da1:power"}
Switch LR_TV_PowerMain "TV" <screen> {ga="Switch"}
String LR_TV_App "Living Room TV App Launcher" {channel="lgwebos:WebOSTV:e529500c-e871-8022-3bb1-d8cb828f5da1:appLauncher"}
my rules:
val String filename = "devices.rules"
rule "Turn ON TV from openhab UI"
Item LR_TV_PowerMain changed from OFF to ON
logInfo(filename, "Turned ON TV from openHAB UI")
if (LR_TV_PowerWOL.state != OFF) { LR_TV_PowerWOL.sendCommand(OFF) }
LR_TV_PowerWOL.sendCommand(ON)
rule "Turn OFF TV from openhab UI"
Item LR_TV_PowerMain changed from ON to OFF
logInfo(filename, "Turned OFF TV from openHAB UI")
if (LR_TV_PowerBinding.state != ON) { LR_TV_PowerBinding.sendCommand(ON) }
LR_TV_PowerBinding.sendCommand(OFF)
rule "Detect TV State from App ID"
Item LR_TV_App changed
logInfo(filename, "LR_TV_App changed to " + LR_TV_App.state)
if (LR_TV_App.state == "") {
logInfo(filename, "TV is OFF") // no App ID means the TV is OFF
LR_TV_PowerMain.sendCommand(OFF) // update UI power switch
} else {
logInfo(filename, "TV is ON") // any App ID means the TV is ON
LR_TV_PowerMain.sendCommand(ON) // update UI power switch
and that’s it, simple as that.
Hope it helps, and I’d be happy to here any responses, remarks or suggestions.
Thank you,
Chenta
