Android APP not updating Icons
I am also having issues with the Android app not updating icons when states change. Wondering if I may be missing something, if you have any suggestions.
Default built-in icons - state changes with no issue
Custom SVG vector icons - state does not change in Android
  • Custom SVG Icons change state via WEB interface using Basic UI, remotely
  • Confirmed that “vector” is selected, not “bitmap”
  • Rebooted openhab2, issue persists.
  • Utilizing Android openHAB v2.5.0 - Nov 24 version
  • I do have a reverse proxy configured, and am connected directly to that, not via openhab cloud
Things
//This is the Alexa Items File
//Lights
Switch  Alexa_LIGHTS_OSf            "Outdoor Lights"              (Alexa) ["Lighting"]    {channel="zwave:device:512:node9:switch_binary"}
Switch  Alexa_LIGHTS_Garage         "Garage Lights"               (Alexa) ["Lighting"]    {channel="zwave:device:512:node5:switch_binary"}
Dimmer  Alexa_LIGHTS_MASTERBDRM     "Bedroom Lights"              (Alexa) ["Lighting"]    {channel="zwave:device:512:node22:switch_dimmer"}
Dimmer  Alexa_LIGHTS_MASTERBDRM     "Master Bedroom Lights"       (Alexa) ["Lighting"]    {channel="zwave:device:512:node22:switch_dimmer"}
Dimmer  Alexa_LIGHTS_MASTERBDRM     "My Bedroom Lights"           (Alexa) ["Lighting"]    {channel="zwave:device:512:node22:switch_dimmer"}
Number  Alexa_LIGHTS_MASTERBDRM_LVL "Bedroom Light Dimmer"        (Alexa) ["Lighting"]    {channel="zwave:device:512:node22:scene_number"}
Number  Alexa_LIGHTS_MASTERBDRM_LVL "Master Bedroom Light Dimmer" (Alexa) ["Lighting"]    {channel="zwave:device:512:node22:scene_number"}
//Garage Door Opener Power Outlett
Switch  Alexa_PSWITCH_GARAGE_OHDOOR "Garage Door Power"           (Alexa) ["Switchable"]  {channel="zwave:device:512:node10:switch_binary"}
//Light Switch Front Door Outside
//Switch LSWITCH_FRONT_OUTSIDE_LIGHTS "Outside Front Lights" {channel="zwave:device:512:node9:switch_binary"}
Number LSWITCH_FRONT_OUTSIDE_SCENE_ "Outside Front Lights Scene" {channel="zwave:device:512:node9:scene_number"}
//Light Switch Garage
//Switch LSWITCH_GARAGE_LIGHTS "Garage Lights" {channel="zwave:device:512:node5:switch_binary"}
Number LSWITCH_GARAGE_LIGHTS_SCENE "Garage Lights Scene" {channel="zwave:device:512:node5:scene_number"}
// Light Dimmer Master Bedroom
//Dimmer LSWITCH_MASTERBDRM_LIGHTS "Master Bedroom Lights" {channel="zwave:device:512:node22:switch_dimmer"}
//Number LSWITCH_MASTERBDRM_LIGHTS_SCENE "Master Bedroom Lights Scene" {channel="zwave:device:512:node22:scene_number"}
// Switch Garage Exterior Door
Contact DOOR_GARAGE_OS_CONTACT "Outside Garage Door Contact" {channel="zwave:device:512:node14:sensor_door"}
Contact DOOR_GARAGE_OS_ALARM "Outside Garage Door Alarm" {channel="zwave:device:512:node14:alarm_general"}
Number DOOR_GARAGE_OS_BATTERY "Outside Garage Door Battery [%d %%]" {channel="zwave:device:512:node14:battery-level" }   //e.g. "50 %"
// Switch Garage Interior Door
Contact DOOR_GARAGE_INSIDE_CONTACT "Inside Garage Door Contact" {channel="zwave:device:512:node13:sensor_door"}
Contact DOOR_GARAGE_INSIDE_ALARM "Inside Garage Door Alarm" {channel="zwave:device:512:node13:alarm_general"}
Number DOOR_GARAGE_INSIDE_BATTERY "Inside Garage Door Battery [%d %%]" {channel="zwave:device:512:node13:battery-level" }
// Switch Garage Overhead DOOR
Contact DOOR_GARAGE_OH_CONTACT "Overhead Garage Door Contact" {channel="zwave:device:512:node11:sensor_door"}
Contact DOOR_GARAGE_OH_ALARM "Overhead Garage Door Alarm" {channel="zwave:device:512:node11:alarm_general"}
Number DOOR_GARAGE_OH_BATTERY "Overhead Garage Door Battery" {channel="zwave:device:512:node11:battery-level"}
My Current Sitemap
sitemap home label="Our SmartHome" {
Frame label="Date" {
                Text item=Today
  Frame label="House Stuff"
      Switch item=DOOR_GARAGE_OS_CONTACT icon="lock1"
      Switch item=DOOR_GARAGE_OS_CONTACT icon=switch
      Text item=DOOR_GARAGE_OS_BATTERY icon=batterylevel
      Switch item=DOOR_GARAGE_INSIDE_CONTACT icon="lock1"
      Switch item=DOOR_GARAGE_INSIDE_CONTACT icon=switch
      Text item=DOOR_GARAGE_INSIDE_BATTERY icon=batterylevel
      Switch item=DOOR_F_LOCK icon="lock1"
      Switch item=DOOR_F_LOCK icon=switch
      Switch item=Alexa_LIGHTS_Garage icon=door
      Switch item=Alexa_LIGHTS_OSf icon=lock
      Switch item=Alexa_PSWITCH_GARAGE_OHDOOR
      Text item=SENSOR_GARAGE_TEMP icon=temperature
      Text item=SENSOR_BASEMENT_TEMP icon=temperature
      Text item=Bedrooms label="Bedrooms" icon="bedroom" {
        Frame label="Rooms" {
          Switch item=Alexa_LIGHTS_MASTERBDRM
          Slider item=Alexa_LIGHTS_MASTERBDRM
And here is a tree of my folder structure.
Z:.
│   events.log
├───sounds
│       doorbell.mp3
│       barking.mp3
├───items
│       alexa.items
│       home.items
│       readme.txt
│       network.items
│       astro.items
├───sitemaps
│       readme.txt
│       home.sitemap
├───persistence
│       readme.txt
├───scripts
│       readme.txt
├───services
│       jdbc.cfg
│       runtime.cfg.dpkg-old
│       readme.txt
│       runtime.cfg
│       addons.cfg
│       heatmiser.cfg
├───icons
│   └───classic
│       │   lamp_globe-on.svg
│       │   lock-on.svg
│       │   lamp_globe_light-on.svg
│       │   lamp_globe_light.svg
│       │   readme.txt
│       │   door-off.svg
│       │   lamp_globe-off.svg
│       │   lock-off.svg
│       │   lamp_globe_light-off.svg
│       │   lock.svg
│       │   error2-no_error.svg
│       │   lamp_globe.svg
│       │   error2-no_fault.svg
│       │   error2.svg
│       │   door.svg
│       │   door-on.svg
│       └───archive
│               lock-on - Copy.svg
│               lock-on.svg
│               door.svg
├───things
│       home.things
│       readme.txt
├───transform
│       de.map
│       readme.txt
│       en.map
├───rules
│       readme.txt
│       home.rules
└───html
        readme.txt
        index.html
It’s possible that the app requests the wrong state for an icon: When you have a slider, the app may request state=0, while the Basic UI requests state=OFF.
I have a commit in the pipeline that enabled reading the app log. I hope I get the commit online in the next few days. This will make it much easier to debug such issues.
@mueller-ma I found my issue. I didn’t realize the openhab Android App itself had a bitmap/vector option. I was setting up everything server side.
I can confirm it is working, now I just need to fix my graphics.
