I‘m using the openHAB Android App. The app is running in kiosk mode through the app FULLY SINGLE APP KIOSK. Unfortunately in this combination is always the default view loading and not the openHAB 3 ui.
Is it possible to modify the openHAB url and start directly with the UI3 interface?
The default view is called Sitemaps. Switching to main ui is working until next refresh or reboot.
My idea is to change the start URL and start directly to the main UI, if this is possible.
On my Tablet the openHAB App is running in kiosk mode through the app FULLY SINGLE APP KIOSK.
Running the openHAB without the app FULLY SINGLE APP KIOSK works as configured with openhab3 UI.
To fix this problem with the kiosk app I want to change the URL in the settings to launch the openhab3 UI directly.
So, is this possible or not?
So your issue is not with openhab but with your kiosk app.
You can also try to open openhab ui through any browser and don’t need the app at all, maybe that’s a workaround for you.
Otherwise please reach out to the kiosk app support…
