I (openHAB 4.3.4) have been having a problem with the android app for some time now. As soon as I connect remotely, I only see a white screen. I have already cleared the app’s cache and also called up the app using the TAB ||| function in Android. I can access my dashborad remotely in myopenhab.
Android App Log
Android App Log
Device information
Model: SM-A336B
Manufacturer: samsung
Brand: samsung
Device: a33x
Product: a33xnseea
OS: 14
Display: 1080x2185, 2.8125 density
Data usage policy: DataUsagePolicy(canDoLargeTransfers=true, loadIconsWithState=true, autoPlayVideos=true, canDoRefreshes=true), data saver: 1, battery saver: false
--------- beginning of main
05-30 07:22:09.974 10954 10954 I penhab.habdroid: Using CollectorTypeCMC GC.
05-30 07:22:09.977 10954 10954 E penhab.habdroid: Not starting debugger since process cannot load the jdwp agent.
05-30 07:22:09.980 10954 10954 D nativeloader: Load libframework-connectivity-tiramisu-jni.so using APEX ns com_android_tethering for caller /apex/com.android.tethering/javalib/framework-connectivity-t.jar: ok
05-30 07:22:09.982 10954 10954 D ActivityThread: setConscryptValidator
05-30 07:22:09.982 10954 10954 D ActivityThread: setConscryptValidator - put
05-30 07:22:09.991 10954 10954 D CompatibilityChangeReporter: Compat change id reported: 171979766; UID 10391; state: ENABLED
05-30 07:22:09.991 10954 10954 D CompatibilityChangeReporter: Compat change id reported: 242716250; UID 10391; state: ENABLED
05-30 07:22:10.002 10954 10954 D nativeloader: Configuring clns-4 for other apk /system/framework/org.apache.http.legacy.jar. target_sdk_version=34, uses_libraries=ALL, library_path=/data/app/~~z4HZXRgj37pOR3ZOFJ6lfA==/org.openhab.habdroid-WkhJuWnMc2PlxVBITW815w==/lib/arm64, permitted_path=/data:/mnt/expand:/data/user/0/org.openhab.habdroid
05-30 07:22:10.002 10954 10954 D nativeloader: Extending system_exposed_libraries: libhumantracking.arcsoft.so:libPortraitDistortionCorrection.arcsoft.so:libPortraitDistortionCorrectionCali.arcsoft.so:libface_landmark.arcsoft.so:libFacialStickerEngine.arcsoft.so:libveengine.arcsoft.so:liblow_light_hdr.arcsoft.so:libhigh_dynamic_range.arcsoft.so:libsuperresolution_raw.arcsoft.so:libobjectcapture_jni.arcsoft.so:libFacialAttributeDetection.arcsoft.so:libobjectcapture.arcsoft.so:libaudiomirroring_jni.audiomirroring.samsung.so:libBeauty_v4.camera.samsung.so:libexifa.camera.samsung.so:libjpega.camera.samsung.so:libOpenCv.camera.samsung.so:libImageScreener.camera.samsung.so:libMyFilter.camera.samsung.so:libtensorflowLite.myfilter.camera.samsung.so:libtensorflowlite_inference_api.myfilter.camera.samsung.so:libHIDTSnapJNI.camera.samsung.so:libSmartScan.camera.samsung.so:libRectify.camera.samsung.so:libDocRectifyWrapper.camera.samsung.so:libUltraWideDistortionCorrection.camera.samsung.so:libFace_Landmark_API.camera.samsung.so:libHpr_RecGAE_cvFeature_v1.0.camera.sa
05-30 07:22:10.018 10954 10954 W ziparchive: Unable to open '/data/app/~~z4HZXRgj37pOR3ZOFJ6lfA==/org.openhab.habdroid-WkhJuWnMc2PlxVBITW815w==/split_config.de.dm': No such file or directory
05-30 07:22:10.018 10954 10954 W penhab.habdroid: Entry not found
05-30 07:22:10.019 10954 10954 W ziparchive: Unable to open '/data/app/~~z4HZXRgj37pOR3ZOFJ6lfA==/org.openhab.habdroid-WkhJuWnMc2PlxVBITW815w==/split_config.en.dm': No such file or directory
05-30 07:22:10.019 10954 10954 W penhab.habdroid: Entry not found
05-30 07:22:10.020 10954 10954 W ziparchive: Unable to open '/data/app/~~z4HZXRgj37pOR3ZOFJ6lfA==/org.openhab.habdroid-WkhJuWnMc2PlxVBITW815w==/split_config.xxhdpi.dm': No such file or directory
05-30 07:22:10.020 10954 10954 W penhab.habdroid: Entry not found
05-30 07:22:10.020 10954 10954 D nativeloader: Configuring clns-5 for other apk /data/app/~~z4HZXRgj37pOR3ZOFJ6lfA==/org.openhab.habdroid-WkhJuWnMc2PlxVBITW815w==/base.apk:/data/app/~~z4HZXRgj37pOR3ZOFJ6lfA==/org.openhab.habdroid-WkhJuWnMc2PlxVBITW815w==/split_config.de.apk:/data/app/~~z4HZXRgj37pOR3ZOFJ6lfA==/org.openhab.habdroid-WkhJuWnMc2PlxVBITW815w==/split_config.en.apk:/data/app/~~z4HZXRgj37pOR3ZOFJ6lfA==/org.openhab.habdroid-WkhJuWnMc2PlxVBITW815w==/split_config.xxhdpi.apk. target_sdk_version=34, uses_libraries=, library_path=/data/app/~~z4HZXRgj37pOR3ZOFJ6lfA==/org.openhab.habdroid-WkhJuWnMc2PlxVBITW815w==/lib/arm64, permitted_path=/data:/mnt/expand:/data/user/0/org.openhab.habdroid
05-30 07:22:10.028 10954 10954 D nativeloader: Load libframework-connectivity-jni.so using APEX ns com_android_tethering for caller /apex/com.android.tethering/javalib/framework-connectivity.jar: ok
05-30 07:22:10.034 10954 10954 V GraphicsEnvironment: Currently set values for:
05-30 07:22:10.034 10954 10954 V GraphicsEnvironment: angle_gl_driver_selection_pkgs=[]
05-30 07:22:10.034 10954 10954 V GraphicsEnvironment: angle_gl_driver_selection_values=[]
05-30 07:22:10.035 10954 10954 V GraphicsEnvironment: ANGLE GameManagerService for org.openhab.habdroid: false
05-30 07:22:10.035 10954 10954 V GraphicsEnvironment: org.openhab.habdroid is not listed in per-application setting
05-30 07:22:10.035 10954 10954 V GraphicsEnvironment: Neither updatable production driver nor prerelease driver is supported.
05-30 07:22:10.041 10954 10954 I MultiDex: VM with version 2.1.0 has multidex support
05-30 07:22:10.041 10954 10954 I MultiDex: Installing application
05-30 07:22:10.041 10954 10954 I MultiDex: VM has multidex support, MultiDex support library is disabled.
05-30 07:22:10.049 10954 10954 D CompatibilityChangeReporter: Compat change id reported: 183155436; UID 10391; state: ENABLED
05-30 07:22:10.052 10954 10954 D SessionsDependencies: Dependency to CRASHLYTICS added.
05-30 07:22:10.053 10954 10954 I FirebaseApp: Device unlocked: initializing all Firebase APIs for app [DEFAULT]
05-30 07:22:10.059 10954 10954 D FirebaseSessions: Initializing Firebase Sessions SDK.
05-30 07:22:10.062 10954 10954 I FirebaseCrashlytics: Initializing Firebase Crashlytics 19.0.3 for org.openhab.habdroid
05-30 07:22:10.068 10954 10954 D SessionsDependencies: Subscriber CRASHLYTICS registered.
05-30 07:22:10.086 10954 10954 I FirebaseInitProvider: FirebaseApp initialization successful
05-30 07:22:10.091 10954 10954 D WM-WrkMgrInitializer: Initializing WorkManager with default configuration.
05-30 07:22:10.097 10954 10954 D WM-PackageManagerHelper: Skipping component enablement for androidx.work.impl.background.systemjob.SystemJobService
05-30 07:22:10.097 10954 10954 D WM-Schedulers: Created SystemJobScheduler and enabled SystemJobService
05-30 07:22:10.102 10954 10976 D CompatibilityChangeReporter: Compat change id reported: 247079863; UID 10391; state: ENABLED
05-30 07:22:10.103 10954 10976 D SessionConfigFetcher: Fetching settings from server.
05-30 07:22:10.119 10954 10954 D CrashReportingHelper: Crashlytics status: isDebug false, isOutdated false, isUserEnabled true
05-30 07:22:10.144 10954 10977 I FirebaseCrashlytics: Saved version control info
05-30 07:22:10.155 10954 10993 D CompatibilityChangeReporter: Compat change id reported: 160794467; UID 10391; state: ENABLED
05-30 07:22:10.216 10954 10954 I EngineFactory: Provider GmsCore_OpenSSL not available
05-30 07:22:10.218 10954 10954 D ConnectivityManager: StackLog: [android.net.ConnectivityManager.sendRequestForNetwork(ConnectivityManager.java:4709)] [android.net.ConnectivityManager.registerDefaultNetworkCallbackForUid(ConnectivityManager.java:5433)] [android.net.ConnectivityManager.registerDefaultNetworkCallback(ConnectivityManager.java:5400)] [android.net.ConnectivityManager.registerDefaultNetworkCallback(ConnectivityManager.java:5374)] [androidx.work.impl.utils.NetworkApi24$$ExternalSyntheticApiModelOutline0.m(SourceFile:0)] [org.openhab.habdroid.core.connection.ConnectionManagerHelper$ChangeCallbackHelperApi26.<init>(SourceFile:125)] [org.openhab.habdroid.core.connection.ConnectionManagerHelper$HelperApi26.<init>(SourceFile:86)] [org.openhab.habdroid.core.connection.ConnectionManagerHelper$Companion.create(SourceFile:73)] [org.openhab.habdroid.core.connection.ConnectionFactory$Companion.initialize(SourceFile:574)] [org.openhab.habdroid.core.OpenHabApplication.onCreate(SourceFile:96)] [android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1316)] [android.app.ActivityThread.handleBindApplication(ActivityThread.java:7711)] [android.app.ActivityThread.-$$Nest$mhandleBindApplication(Unknown Source:0)] [android.app.ActivityThread$H.handleMessage(ActivityThread.java:2478)]
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: getAppKeyStore(/data/user/0/org.openhab.habdroid/app_KeyStore/KeyStore.bks) - exception loading file key store
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: java.io.FileNotFoundException: /data/user/0/org.openhab.habdroid/app_KeyStore/KeyStore.bks: open failed: ENOENT (No such file or directory)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at libcore.io.IoBridge.open(IoBridge.java:574)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at java.io.FileInputStream.<init>(FileInputStream.java:179)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at de.duenndns.ssl.MemorizingTrustManager.loadAppKeyStore(SourceFile:341)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at de.duenndns.ssl.MemorizingTrustManager.init(SourceFile:167)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at de.duenndns.ssl.MemorizingTrustManager.<init>(SourceFile:145)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at org.openhab.habdroid.core.connection.ConnectionFactory.<init>(SourceFile:131)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at org.openhab.habdroid.core.connection.ConnectionFactory$Companion.initialize(SourceFile:574)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at org.openhab.habdroid.core.OpenHabApplication.onCreate(SourceFile:96)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1316)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread.handleBindApplication(ActivityThread.java:7711)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread.-$$Nest$mhandleBindApplication(Unknown Source:0)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2478)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at android.os.Handler.dispatchMessage(Handler.java:106)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at android.os.Looper.loopOnce(Looper.java:230)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at android.os.Looper.loop(Looper.java:319)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread.main(ActivityThread.java:8919)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at java.lang.reflect.Method.invoke(Native Method)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:578)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1103)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: Caused by: android.system.ErrnoException: open failed: ENOENT (No such file or directory)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at libcore.io.Linux.open(Native Method)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at libcore.io.ForwardingOs.open(ForwardingOs.java:563)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at libcore.io.BlockGuardOs.open(BlockGuardOs.java:274)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread$AndroidOs.open(ActivityThread.java:8782)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: at libcore.io.IoBridge.open(IoBridge.java:560)
05-30 07:22:10.224 10954 10954 I MemorizingTrustManager: ... 18 more
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: getAppKeyStore(/data/user/0/org.openhab.habdroid/app_KeyStore/KeyStore.bks) - exception loading file key store
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: java.io.FileNotFoundException: /data/user/0/org.openhab.habdroid/app_KeyStore/KeyStore.bks: open failed: ENOENT (No such file or directory)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at libcore.io.IoBridge.open(IoBridge.java:574)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at java.io.FileInputStream.<init>(FileInputStream.java:179)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at de.duenndns.ssl.MemorizingTrustManager.loadAppKeyStore(SourceFile:341)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at de.duenndns.ssl.MemorizingTrustManager.init(SourceFile:167)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at de.duenndns.ssl.MemorizingTrustManager.<init>(SourceFile:145)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at de.duenndns.ssl.MemorizingTrustManager.getInstanceList(SourceFile:186)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at org.openhab.habdroid.core.connection.ConnectionFactory.<init>(SourceFile:141)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at org.openhab.habdroid.core.connection.ConnectionFactory$Companion.initialize(SourceFile:574)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at org.openhab.habdroid.core.OpenHabApplication.onCreate(SourceFile:96)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1316)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread.handleBindApplication(ActivityThread.java:7711)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread.-$$Nest$mhandleBindApplication(Unknown Source:0)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2478)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at android.os.Handler.dispatchMessage(Handler.java:106)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at android.os.Looper.loopOnce(Looper.java:230)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at android.os.Looper.loop(Looper.java:319)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread.main(ActivityThread.java:8919)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at java.lang.reflect.Method.invoke(Native Method)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:578)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1103)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: Caused by: android.system.ErrnoException: open failed: ENOENT (No such file or directory)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at libcore.io.Linux.open(Native Method)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at libcore.io.ForwardingOs.open(ForwardingOs.java:563)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at libcore.io.BlockGuardOs.open(BlockGuardOs.java:274)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread$AndroidOs.open(ActivityThread.java:8782)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: at libcore.io.IoBridge.open(IoBridge.java:560)
05-30 07:22:10.437 10954 10954 I MemorizingTrustManager: ... 19 more
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: getAppKeyStore(/data/user/0/org.openhab.habdroid/app_KeyStore/KeyStore.bks) - exception loading file key store
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: java.io.FileNotFoundException: /data/user/0/org.openhab.habdroid/app_KeyStore/KeyStore.bks: open failed: ENOENT (No such file or directory)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at libcore.io.IoBridge.open(IoBridge.java:574)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at java.io.FileInputStream.<init>(FileInputStream.java:179)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at de.duenndns.ssl.MemorizingTrustManager.loadAppKeyStore(SourceFile:341)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at de.duenndns.ssl.MemorizingTrustManager.init(SourceFile:167)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at de.duenndns.ssl.MemorizingTrustManager.<init>(SourceFile:145)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at org.openhab.habdroid.core.connection.ConnectionFactory.<init>(SourceFile:143)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at org.openhab.habdroid.core.connection.ConnectionFactory$Companion.initialize(SourceFile:574)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at org.openhab.habdroid.core.OpenHabApplication.onCreate(SourceFile:96)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1316)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread.handleBindApplication(ActivityThread.java:7711)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread.-$$Nest$mhandleBindApplication(Unknown Source:0)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2478)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at android.os.Handler.dispatchMessage(Handler.java:106)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at android.os.Looper.loopOnce(Looper.java:230)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at android.os.Looper.loop(Looper.java:319)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread.main(ActivityThread.java:8919)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at java.lang.reflect.Method.invoke(Native Method)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:578)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1103)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: Caused by: android.system.ErrnoException: open failed: ENOENT (No such file or directory)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at libcore.io.Linux.open(Native Method)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at libcore.io.ForwardingOs.open(ForwardingOs.java:563)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at libcore.io.BlockGuardOs.open(BlockGuardOs.java:274)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at android.app.ActivityThread$AndroidOs.open(ActivityThread.java:8782)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: at libcore.io.IoBridge.open(IoBridge.java:560)
05-30 07:22:10.438 10954 10954 I MemorizingTrustManager: ... 18 more
05-30 07:22:10.448 10954 10954 D OpenGLRenderer: HWUI - treat SMPTE_170M as sRGB
05-30 07:22:10.465 10954 10954 D AppCompatDelegate: Checking for metadata for AppLocalesMetadataHolderService : Service not found
05-30 07:22:10.471 10954 10954 D MainActivity: onCreate()
05-30 07:22:10.492 10954 10954 I DecorView: setWindowBackground: isPopOver=false color=fffffbff d=android.graphics.drawable.ColorDrawable@e7fff1
05-30 07:22:10.522 10954 10954 D CompatibilityChangeReporter: Compat change id reported: 210923482; UID 10391; state: ENABLED
05-30 07:22:10.528 10954 10954 D PhoneWindow: forceLight changed to false [] from com.android.internal.policy.PhoneWindow.updateForceLightNavigationBar:4373 com.android.internal.policy.PhoneWindow.setNavigationBarColor:4064 com.google.android.material.internal.EdgeToEdgeUtils.applyEdgeToEdge:103 com.google.android.material.internal.EdgeToEdgeUtils.applyEdgeToEdge:56 org.openhab.habdroid.ui.AbstractBaseActivity.enableDrawingBehindStatusBar:150
05-30 07:22:10.535 10954 10954 D MainActivity: Got intent: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=org.openhab.habdroid/.ui.MainActivity bnds=[540,1524][791,1860] }
--------- beginning of events
05-30 07:22:10.537 10954 10954 I wm_on_create_called: [263756211,org.openhab.habdroid.ui.MainActivity,performCreate,66]
05-30 07:22:10.538 10954 10954 D MainActivity: onStart()
05-30 07:22:10.539 10954 10954 D PageConnectionHolderFragment: onStart(), started false
05-30 07:22:10.542 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:10.543 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:10.544 10954 10954 D MainActivity: onActiveConnectionChanged()
05-30 07:22:10.548 10954 10954 D ContentController: Indicate no network (message Netzwerk nicht verfügbar)
05-30 07:22:10.548 10954 10954 D PageConnectionHolderFragment: updateActiveConnections: URL list [], connection null
05-30 07:22:10.550 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:10.552 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:10.553 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:10.555 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:10.559 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:10.559 10954 10954 D MainActivity: Cannot auto select server: No server with configured wifi
05-30 07:22:10.560 10954 10954 I wm_on_start_called: [263756211,org.openhab.habdroid.ui.MainActivity,handleStartActivity,22]
05-30 07:22:10.561 10954 10954 D MainActivity: onPostCreate()
05-30 07:22:10.562 10954 10954 D MainActivity: onResume()
05-30 07:22:10.564 10954 10954 D CompatibilityChangeReporter: Compat change id reported: 171228096; UID 10391; state: ENABLED
05-30 07:22:10.564 10954 10954 D ScrollView: initGoToTop
05-30 07:22:10.579 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:10.580 10954 10954 I wm_on_resume_called: [263756211,org.openhab.habdroid.ui.MainActivity,RESUME_ACTIVITY,17]
05-30 07:22:10.583 10954 10954 D CompatibilityChangeReporter: Compat change id reported: 237531167; UID 10391; state: DISABLED
05-30 07:22:10.585 10954 11009 D NativeCustomFrequencyManager: [NativeCFMS] BpCustomFrequencyManager::BpCustomFrequencyManager()
05-30 07:22:10.591 10954 10954 I InsetsController: onStateChanged: host=org.openhab.habdroid/org.openhab.habdroid.ui.MainActivity, from=android.view.ViewRootImpl.setView:1753, state=InsetsState: {mDisplayFrame=Rect(0, 0 - 1080, 2400), mDisplayCutout=DisplayCutout{insets=Rect(0, 80 - 0, 0) waterfall=Insets{left=0, top=0, right=0, bottom=0} boundingRect={Bounds=[Rect(0, 0 - 0, 0), Rect(468, 0 - 612, 80), Rect(0, 0 - 0, 0), Rect(0, 0 - 0, 0)]} cutoutPathParserInfo={CutoutPathParserInfo{displayWidth=1080 displayHeight=2400 physicalDisplayWidth=1080 physicalDisplayHeight=2400 density={2.8125} cutoutSpec={M 0,0 H -25.6 V 28.44444444444444 H 25.6 V 0 H 0 Z @dp} rotation={0} scale={1.0} physicalPixelDisplaySizeRatio={1.0}}}}, mRoundedCorners=RoundedCorners{[RoundedCorner{position=TopLeft, radius=0, center=Point(0, 0)}, RoundedCorner{position=TopRight, radius=0, center=Point(0, 0)}, RoundedCorner{position=BottomRight, radius=0, center=Point(0, 0)}, RoundedCorner{position=BottomLeft, radius=0, center=Point(0, 0)}]} mRoundedCornerFrame=Rect(0, 0 - 1080, 2400), mPrivacyIndicatorBounds=PrivacyIndicatorBounds {static bounds=Rect(956, 0 - 1080, 80) rotation=0}, mDisplayShape=DisplayShape{ spec=-311912193 displayWidth=1080 displayHeight=2400 physicalPixelDisplaySizeRatio=1.0 rotation=0 offsetX=0 offsetY=0 scale=1.0}, mSources= { InsetsSource: {aaf30000 mType=statusBars mFrame=[0,0][1080,80] mVisible=true mFlags=[]}, InsetsSource: {aaf30005 mType=mandatorySystemGestures mFrame=[0,0][1080,114] mVisible=true mFlags=[]}, InsetsSource: {aaf30006 mType=tappableElement mFrame=[0,0][1080,80] mVisible=true mFlags=[]}, InsetsSource: {de3c0001 mType=navigationBars mFrame=[0,2265][1080,2400] mVisible=true mFlags=[]}, InsetsSource: {de3c0004 mType=systemGestures mFrame=[0,0][0,0] mVisible=true mFlags=[]}, InsetsSource: {de3c0005 mType=mandatorySystemGestures mFrame=[0,2265][1080,2400] mVisible=true mFlags=[]}, InsetsSource: {de3c0006 mType=tappableElement mFrame=[0,2265][1080,2400] mVisible=true mFlags=[]}, InsetsSource: {de3c0024 mType=systemGestures mFrame=[0,0][0,0] mVisible=true mFlags=[]}, InsetsSource: {27 mType=displayCutout mFrame=[0,0][1080,80] mVisible=true mFlags=[]} }
05-30 07:22:10.592 10954 10954 I ViewRootImpl@f7c0f41[MainActivity]: synced displayState. AttachInfo displayState=2
05-30 07:22:10.592 10954 10954 I ViewRootImpl@f7c0f41[MainActivity]: setView = com.android.internal.policy.DecorView@2b95e7d TM=true
05-30 07:22:10.592 10954 10954 I IDS_TAG : Starting IDS observe window
05-30 07:22:10.592 10954 10954 I IDS_TAG : Getting Shared Preference for org.openhab.habdroid.core.OpenHabApplication@9c432f2 uid = 10391
05-30 07:22:10.594 10954 10954 I IDS_TAG : App org.openhab.habdroid.core.OpenHabApplication@9c432f2 in NO_IDS list
05-30 07:22:10.595 10954 10954 I wm_on_top_resumed_gained_called: [263756211,org.openhab.habdroid.ui.MainActivity,topStateChangedWhenResumed]
05-30 07:22:10.595 10954 10954 I IDS_TAG : Closing IDS observe window
05-30 07:22:10.595 10954 10954 I IDS_TAG : Getting Shared Preference for org.openhab.habdroid.core.OpenHabApplication@9c432f2 uid = 10391
05-30 07:22:10.598 10954 10954 D AnimatorSet: mReversing is false. Don't call initChildren.
05-30 07:22:10.610 10954 10954 I BLASTBufferQueue_Java: new BLASTBufferQueue, mName= ViewRootImpl@f7c0f41[MainActivity] mNativeObject= 0xb40000770cfb2670 sc.mNativeObject= 0xb4000077acf95910 caller= android.view.ViewRootImpl.updateBlastSurfaceIfNeeded:3028 android.view.ViewRootImpl.relayoutWindow:10131 android.view.ViewRootImpl.performTraversals:4110 android.view.ViewRootImpl.doTraversal:3288 android.view.ViewRootImpl$TraversalRunnable.run:11344 android.view.Choreographer$CallbackRecord.run:1689 android.view.Choreographer$CallbackRecord.run:1698 android.view.Choreographer.doCallbacks:1153 android.view.Choreographer.doFrame:1079 android.view.Choreographer$FrameDisplayEventReceiver.run:1646
05-30 07:22:10.610 10954 10954 I BLASTBufferQueue_Java: update, w= 1080 h= 2400 mName = ViewRootImpl@f7c0f41[MainActivity] mNativeObject= 0xb40000770cfb2670 sc.mNativeObject= 0xb4000077acf95910 format= -1 caller= android.graphics.BLASTBufferQueue.<init>:89 android.view.ViewRootImpl.updateBlastSurfaceIfNeeded:3028 android.view.ViewRootImpl.relayoutWindow:10131 android.view.ViewRootImpl.performTraversals:4110 android.view.ViewRootImpl.doTraversal:3288 android.view.ViewRootImpl$TraversalRunnable.run:11344
05-30 07:22:10.611 10954 10954 I ViewRootImpl@f7c0f41[MainActivity]: Relayout returned: old=(0,0,1080,2400) new=(0,0,1080,2400) relayoutAsync=false req=(1080,2400)0 dur=7 res=0x403 s={true 0xb40000760cfcbdf0} ch=true seqId=0
05-30 07:22:10.612 10954 10954 I ViewRootImpl@f7c0f41[MainActivity]: performConfigurationChange setNightDimText nightDimLevel=0
05-30 07:22:10.612 10954 10954 D ViewRootImpl@f7c0f41[MainActivity]: mThreadedRenderer.initialize() mSurface={isValid=true 0xb40000760cfcbdf0} hwInitialized=true
05-30 07:22:10.614 10954 10954 D ScrollView: onsize change changed
05-30 07:22:10.614 10954 10987 D SessionConfigFetcher: Fetched settings: {"settings_version":3,"cache_duration":162358,"features":{"collect_logged_exceptions":true,"collect_reports":true,"collect_analytics":false,"prompt_enabled":false,"push_enabled":false,"firebase_crashlytics_enabled":false,"collect_anrs":true,"collect_metric_kit":false,"collect_build_ids":true},"app":{"status":"activated","update_required":false,"report_upload_variant":2,"native_report_upload_variant":2},"fabric":{"org_id":"5a1ef663b2409560bc0001dd","bundle_id":"org.openhab.habdroid"},"on_demand_upload_rate_per_minute":10,"on_demand_backoff_base":1.2,"on_demand_backoff_step_duration_seconds":60,"app_quality":{"sessions_enabled":true,"sampling_rate":1,"session_timeout_seconds":1800},"on_demand_thread_recording_suspension_enabled":true}
05-30 07:22:10.623 10954 10954 D ViewRootImpl@f7c0f41[MainActivity]: reportNextDraw android.view.ViewRootImpl.performTraversals:4718 android.view.ViewRootImpl.doTraversal:3288 android.view.ViewRootImpl$TraversalRunnable.run:11344 android.view.Choreographer$CallbackRecord.run:1689 android.view.Choreographer$CallbackRecord.run:1698
05-30 07:22:10.624 10954 10954 I ViewRootImpl@f7c0f41[MainActivity]: Setup new sync=wmsSync-ViewRootImpl@f7c0f41[MainActivity]#0
05-30 07:22:10.624 10954 10954 I ViewRootImpl@f7c0f41[MainActivity]: Creating new active sync group ViewRootImpl@f7c0f41[MainActivity]#1
05-30 07:22:10.625 10954 10954 I ViewRootImpl@f7c0f41[MainActivity]: registerCallbacksForSync syncBuffer=false
05-30 07:22:10.627 10954 10969 D LifecycleServiceBinder: Binding service to application.
05-30 07:22:10.629 10954 11026 I ViewRootImpl@f7c0f41[MainActivity]: Received frameDrawingCallback syncResult=0 frameNum=1.
05-30 07:22:10.630 10954 11026 I ViewRootImpl@f7c0f41[MainActivity]: mWNT: t=0xb4000077dcfb13f0 mBlastBufferQueue=0xb40000770cfb2670 fn= 1 mRenderHdrSdrRatio=1.0 caller= android.view.ViewRootImpl$8.onFrameDraw:13841 android.view.ThreadedRenderer$1.onFrameDraw:792 <bottom of call stack>
05-30 07:22:10.630 10954 11026 I ViewRootImpl@f7c0f41[MainActivity]: Setting up sync and frameCommitCallback
05-30 07:22:10.630 10954 10969 D SessionLifecycleClient: Queued message 1. Queue size 1
05-30 07:22:10.654 10954 11009 I BLASTBufferQueue: [ViewRootImpl@f7c0f41[MainActivity]#0](f:0,a:0,s:0) onFrameAvailable the first frame is available
05-30 07:22:10.654 10954 11009 I ViewRootImpl@f7c0f41[MainActivity]: Received frameCommittedCallback lastAttemptedDrawFrameNum=1 didProduceBuffer=true
05-30 07:22:10.655 10954 11009 D OpenGLRenderer: CFMS:: SetUp Pid : 10954 Tid : 11009
05-30 07:22:10.655 10954 10954 I ViewRootImpl@f7c0f41[MainActivity]: reportDrawFinished seqId=0
05-30 07:22:10.657 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:10.659 10954 11009 D OpenGLRenderer: HWUI - treat SMPTE_170M as sRGB
05-30 07:22:10.662 10954 10954 D MainActivity: onCreateOptionsMenu()
05-30 07:22:10.663 10954 10954 D MainActivity: onPrepareOptionsMenu()
05-30 07:22:10.666 10954 10954 I InsetsSourceConsumer: applyRequestedVisibilityToControl: visible=true, type=navigationBars, host=org.openhab.habdroid/org.openhab.habdroid.ui.MainActivity
05-30 07:22:10.666 10954 10954 I InsetsSourceConsumer: applyRequestedVisibilityToControl: visible=true, type=statusBars, host=org.openhab.habdroid/org.openhab.habdroid.ui.MainActivity
05-30 07:22:10.668 10954 10954 D SessionLifecycleService: Service bound to new client on process 10954
05-30 07:22:10.669 10954 11028 D SessionLifecycleService: App has not yet foregrounded. Using previously stored session: null
05-30 07:22:10.669 10954 11028 D SessionLifecycleService: Client android.os.Messenger@5462534 bound at 33371666. Clients: 1
05-30 07:22:10.671 10954 10954 D SessionLifecycleClient: Connected to SessionLifecycleService. Queue size 1
05-30 07:22:10.671 10954 10954 I wm_on_idle_called: {org.openhab.habdroid/org.openhab.habdroid.ui.MainActivity}
05-30 07:22:10.672 10954 10976 D SessionLifecycleClient: Sending lifecycle 1 to service
05-30 07:22:10.672 10954 11028 D SessionLifecycleService: Activity foregrounding at 33371670.
05-30 07:22:10.672 10954 11028 D SessionLifecycleService: Cold start detected.
05-30 07:22:10.672 10954 10978 D ConnectionFactory: checkAvailableConnection: found types [ConnectionType(type = Wifi, network=124), ConnectionType(type = Mobile, network=123)]
05-30 07:22:10.675 10954 11028 D SessionLifecycleService: Generated new session b10df781fa5f477bb02cfc5ce3992b41
05-30 07:22:10.675 10954 10978 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:10.675 10954 10978 D ConnectionFactory: Server openHAB isn't restricted to Wi-Fis
05-30 07:22:10.675 10954 10978 D AbstractConnection: Checking reachability of http://<openhab-local-address-openHAB>:8080/ (via 124)
05-30 07:22:10.676 10954 11028 D SessionLifecycleService: Broadcasting new session: SessionDetails(sessionId=b10df781fa5f477bb02cfc5ce3992b41, firstSessionId=b10df781fa5f477bb02cfc5ce3992b41, sessionIndex=0, sessionStartTimestampUs=1748582530674000)
05-30 07:22:10.678 10954 10954 I ViewRootImpl@f7c0f41[MainActivity]: handleWindowFocusChanged: 1 0 call from android.view.ViewRootImpl.-$$Nest$mhandleWindowFocusChanged:0
05-30 07:22:10.678 10954 10954 D ViewRootImpl@f7c0f41[MainActivity]: mThreadedRenderer.initializeIfNeeded()#2 mSurface={isValid=true 0xb40000760cfcbdf0}
05-30 07:22:10.679 10954 10954 D InputMethodManagerUtils: startInputInner - Id : 0
05-30 07:22:10.679 10954 10954 I InputMethodManager: startInputInner - IInputMethodManagerGlobalInvoker.startInputOrWindowGainedFocus
05-30 07:22:10.680 10954 10983 D SessionFirelogPublisher: Data Collection is enabled for at least one Subscriber
05-30 07:22:10.691 10954 10954 D SessionLifecycleClient: Session update received: b10df781fa5f477bb02cfc5ce3992b41
05-30 07:22:10.693 10954 10988 D SessionLifecycleClient: Notified CRASHLYTICS of new session b10df781fa5f477bb02cfc5ce3992b41
05-30 07:22:10.715 10954 10954 D InputMethodManagerUtils: startInputInner - Id : 0
05-30 07:22:10.728 10954 10954 I InsetsController: onStateChanged: host=org.openhab.habdroid/org.openhab.habdroid.ui.MainActivity, from=android.view.ViewRootImpl$ViewRootHandler.handleMessageImpl:7209, state=InsetsState: {mDisplayFrame=Rect(0, 0 - 1080, 2400), mDisplayCutout=DisplayCutout{insets=Rect(0, 80 - 0, 0) waterfall=Insets{left=0, top=0, right=0, bottom=0} boundingRect={Bounds=[Rect(0, 0 - 0, 0), Rect(468, 0 - 612, 80), Rect(0, 0 - 0, 0), Rect(0, 0 - 0, 0)]} cutoutPathParserInfo={CutoutPathParserInfo{displayWidth=1080 displayHeight=2400 physicalDisplayWidth=1080 physicalDisplayHeight=2400 density={2.8125} cutoutSpec={M 0,0 H -25.6 V 28.44444444444444 H 25.6 V 0 H 0 Z @dp} rotation={0} scale={1.0} physicalPixelDisplaySizeRatio={1.0}}}}, mRoundedCorners=RoundedCorners{[RoundedCorner{position=TopLeft, radius=0, center=Point(0, 0)}, RoundedCorner{position=TopRight, radius=0, center=Point(0, 0)}, RoundedCorner{position=BottomRight, radius=0, center=Point(0, 0)}, RoundedCorner{position=BottomLeft, radius=0, center=Point(0, 0)}]} mRoundedCornerFrame=Rect(0, 0 - 1080, 2400), mPrivacyIndicatorBounds=PrivacyIndicatorBounds {static bounds=Rect(956, 0 - 1080, 80) rotation=0}, mDisplayShape=DisplayShape{ spec=-311912193 displayWidth=1080 displayHeight=2400 physicalPixelDisplaySizeRatio=1.0 rotation=0 offsetX=0 offsetY=0 scale=1.0}, mSources= { InsetsSource: {aaf30000 mType=statusBars mFrame=[0,0][1080,80] mVisible=true mFlags=[]}, InsetsSource: {aaf30005 mType=mandatorySystemGestures mFrame=[0,0][1080,114] mVisible=true mFlags=[]}, InsetsSource: {aaf30006 mType=tappableElement mFrame=[0,0][1080,80] mVisible=true mFlags=[]}, InsetsSource: {de3c0001 mType=navigationBars mFrame=[0,2265][1080,2400] mVisible=true mFlags=[]}, InsetsSource: {de3c0004 mType=systemGestures mFrame=[0,0][0,0] mVisible=true mFlags=[]}, InsetsSource: {de3c0005 mType=mandatorySystemGestures mFrame=[0,2265][1080,2400] mVisible=true mFlags=[]}, InsetsSource: {de3c0006 mType=tappableElement mFrame=[0,2265][1080,2400] mVisible=true mFlags=[]}, InsetsSource: {de3c0024 mType=systemGestures mFrame=[0,0][0,0] mVisible=true mFlags=[]}, InsetsSource: {3 mType=ime mFrame=[0,0][0,0] mVisible=false mFlags=[]}, InsetsSource: {27 mType=displayCutout mFrame=[0,0][1080,80] mVisible=true mFlags=[]} }
05-30 07:22:10.728 10954 10954 I InsetsSourceConsumer: applyRequestedVisibilityToControl: visible=false, type=ime, host=org.openhab.habdroid/org.openhab.habdroid.ui.MainActivity
05-30 07:22:10.737 10954 10969 D EventGDTLogger: Session Event: {"eventType":1,"sessionData":{"sessionId":"b10df781fa5f477bb02cfc5ce3992b41","firstSessionId":"b10df781fa5f477bb02cfc5ce3992b41","sessionIndex":0,"eventTimestampUs":1748582530674000,"dataCollectionStatus":{"performance":1,"crashlytics":2,"sessionSamplingRate":1.0},"firebaseInstallationId":"e_f7OQmnR2yhU2US-TKBHW","firebaseAuthenticationToken":"eyJhbGciOiJFUzI1NiIsInR5cCI6IkpXVCJ9.eyJhcHBJZCI6IjE6ODQ5MDU4NDk4NzYyOmFuZHJvaWQ6OWZjYjI4ZjkxZTFiNGFiYiIsImV4cCI6MTc0ODkzMjI2MSwiZmlkIjoiZV9mN09RbW5SMnloVTJVUy1US0JIVyIsInByb2plY3ROdW1iZXIiOjg0OTA1ODQ5ODc2Mn0.AB2LPV8wRgIhAN3rbbTGOdEklSfcTRgucm6n4W3bRFNAR0-LJ3JB8-1gAiEAlNUskbKoVb8o0FQHCMtE6qFgefh2yoBizZU_6sWCDts"},"applicationInfo":{"appId":"1:849058498762:android:9fcb28f91e1b4abb","deviceModel":"SM-A336B","sessionSdkVersion":"2.0.3","osVersion":"14","logEnvironment":3,"androidAppInfo":{"packageName":"org.openhab.habdroid","versionName":"3.17.2","appBuildVersion":"565","deviceManufacturer":"samsung","currentProcessDetails":{"processName":"org.openhab.habdroid","pid":10954,"importance":100,"defaultProcess":true},"appProcessDetails":[{"processName":"org.openhab.habdroid","pid":10954,"importance":100,"defaultProcess":true}]}}}
05-30 07:22:10.737 10954 10969 D SessionFirelogPublisher: Successfully logged Session Start event: b10df781fa5f477bb02cfc5ce3992b41
05-30 07:22:10.766 10954 10978 D AbstractConnection: Socket creation failed (attempt 0)
05-30 07:22:10.788 10954 10989 D CompatibilityChangeReporter: Compat change id reported: 194532703; UID 10391; state: ENABLED
05-30 07:22:10.788 10954 10989 D CompatibilityChangeReporter: Compat change id reported: 253665015; UID 10391; state: ENABLED
05-30 07:22:10.967 10954 10978 D AbstractConnection: Socket creation failed (attempt 1)
05-30 07:22:11.054 10954 10954 D MainActivity: onActiveCloudConnectionChanged()
05-30 07:22:11.056 10954 10954 D MainActivity: onPrimaryCloudConnectionChanged()
05-30 07:22:11.095 10954 11004 D ConnectivityManager: StackLog: [android.net.ConnectivityManager.sendRequestForNetwork(ConnectivityManager.java:4709)] [android.net.ConnectivityManager.registerDefaultNetworkCallbackForUid(ConnectivityManager.java:5433)] [android.net.ConnectivityManager.registerDefaultNetworkCallback(ConnectivityManager.java:5400)] [android.net.ConnectivityManager.registerDefaultNetworkCallback(ConnectivityManager.java:5374)] [androidx.work.impl.utils.NetworkApi24$$ExternalSyntheticApiModelOutline0.m(SourceFile:0)] [androidx.work.impl.utils.NetworkApi24.registerDefaultNetworkCallbackCompat(SourceFile:28)] [androidx.work.impl.constraints.trackers.NetworkStateTracker24.startTracking(SourceFile:138)] [androidx.work.impl.constraints.trackers.ConstraintTracker.addListener(SourceFile:56)] [androidx.work.impl.constraints.controllers.ConstraintController$track$1.invokeSuspend(SourceFile:54)] [androidx.work.impl.constraints.controllers.ConstraintController$track$1.invoke(SourceFile:0)] [androidx.work.impl.constraints.controllers.ConstraintController$track$1.invoke(SourceFile:0)] [kotlinx.coroutines.flow.ChannelFlowBuilder.collectTo$suspendImpl(SourceFile:316)] [kotlinx.coroutines.flow.ChannelFlowBuilder.collectTo(Unknown Source:0)] [kotlinx.coroutines.flow.CallbackFlowBuilder.collectTo(SourceFile:330)] [kotlinx.coroutines.flow.internal.ChannelFlow$collectToFun$1.invokeSuspend(SourceFile:56)] [kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(SourceFile:33)] [kotlinx.coroutines.DispatchedTask.run(SourceFile:104)] [androidx.work.impl.utils.SerialExecutorImpl$Task.run(SourceFile:96)] [java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)] [java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)] [java.lang.Thread.run(Thread.java:1012)]
05-30 07:22:11.102 10954 11004 D CompatibilityChangeReporter: Compat change id reported: 263076149; UID 10391; state: ENABLED
05-30 07:22:11.107 10954 10978 D FcmRegistrationWorker: Run with action org.openhab.habdroid.action.REGISTER_GCM
05-30 07:22:11.159 10954 10978 D ConnectionFactory: checkAvailableConnection: found types [ConnectionType(type = Wifi, network=124), ConnectionType(type = Mobile, network=123)]
05-30 07:22:11.160 10954 10978 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:11.160 10954 10978 D ConnectionFactory: Server openHAB isn't restricted to Wi-Fis
05-30 07:22:11.160 10954 10978 D AbstractConnection: Checking reachability of http://<openhab-local-address-openHAB>:8080/ (via 124)
05-30 07:22:11.366 10954 10954 D MainActivity: onActiveCloudConnectionChanged()
05-30 07:22:11.367 10954 10954 D MainActivity: onPrimaryCloudConnectionChanged()
05-30 07:22:11.395 10954 10993 I WM-WorkerWrapper: Work [ id=119db5c6-7e4e-4494-ad18-3f802b603dc1, tags={ org.openhab.habdroid.core.FcmRegistrationWorker } ] was cancelled
05-30 07:22:11.395 10954 10993 I WM-WorkerWrapper: java.util.concurrent.CancellationException: Task was cancelled.
05-30 07:22:11.395 10954 10993 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.cancellationExceptionWithCause(SourceFile:1183)
05-30 07:22:11.395 10954 10993 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.getDoneValue(SourceFile:513)
05-30 07:22:11.395 10954 10993 I WM-WorkerWrapper: at androidx.work.impl.utils.futures.AbstractFuture.get(SourceFile:474)
05-30 07:22:11.395 10954 10993 I WM-WorkerWrapper: at androidx.work.impl.WorkerWrapper$2.run(SourceFile:316)
05-30 07:22:11.395 10954 10993 I WM-WorkerWrapper: at androidx.work.impl.utils.SerialExecutorImpl$Task.run(SourceFile:96)
05-30 07:22:11.395 10954 10993 I WM-WorkerWrapper: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
05-30 07:22:11.395 10954 10993 I WM-WorkerWrapper: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)
05-30 07:22:11.395 10954 10993 I WM-WorkerWrapper: at java.lang.Thread.run(Thread.java:1012)
05-30 07:22:11.399 10954 10993 D ConnectivityManager: StackLog: [android.net.ConnectivityManager.unregisterNetworkCallback(ConnectivityManager.java:5543)] [androidx.work.impl.utils.NetworkApi21.unregisterNetworkCallbackCompat(SourceFile:31)] [androidx.work.impl.constraints.trackers.NetworkStateTracker24.stopTracking(SourceFile:153)] [androidx.work.impl.constraints.trackers.ConstraintTracker.removeListener(SourceFile:72)] [androidx.work.impl.constraints.controllers.ConstraintController$track$1$1.invoke(SourceFile:56)] [androidx.work.impl.constraints.controllers.ConstraintController$track$1$1.invoke(SourceFile:55)] [kotlinx.coroutines.channels.ProduceKt.awaitClose(SourceFile:51)] [kotlinx.coroutines.channels.ProduceKt$awaitClose$1.invokeSuspend(Unknown Source:10)] [kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(SourceFile:33)] [kotlinx.coroutines.DispatchedTask.run(SourceFile:102)] [androidx.work.impl.utils.SerialExecutorImpl$Task.run(SourceFile:96)] [java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)] [java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)] [java.lang.Thread.run(Thread.java:1012)]
05-30 07:22:11.406 10954 11113 D FcmRegistrationWorker: Run with action org.openhab.habdroid.action.REGISTER_GCM
05-30 07:22:11.409 10954 11004 D ConnectivityManager: StackLog: [android.net.ConnectivityManager.sendRequestForNetwork(ConnectivityManager.java:4709)] [android.net.ConnectivityManager.registerDefaultNetworkCallbackForUid(ConnectivityManager.java:5433)] [android.net.ConnectivityManager.registerDefaultNetworkCallback(ConnectivityManager.java:5400)] [android.net.ConnectivityManager.registerDefaultNetworkCallback(ConnectivityManager.java:5374)] [androidx.work.impl.utils.NetworkApi24$$ExternalSyntheticApiModelOutline0.m(SourceFile:0)] [androidx.work.impl.utils.NetworkApi24.registerDefaultNetworkCallbackCompat(SourceFile:28)] [androidx.work.impl.constraints.trackers.NetworkStateTracker24.startTracking(SourceFile:138)] [androidx.work.impl.constraints.trackers.ConstraintTracker.addListener(SourceFile:56)] [androidx.work.impl.constraints.controllers.ConstraintController$track$1.invokeSuspend(SourceFile:54)] [androidx.work.impl.constraints.controllers.ConstraintController$track$1.invoke(SourceFile:0)] [androidx.work.impl.constraints.controllers.ConstraintController$track$1.invoke(SourceFile:0)] [kotlinx.coroutines.flow.ChannelFlowBuilder.collectTo$suspendImpl(SourceFile:316)] [kotlinx.coroutines.flow.ChannelFlowBuilder.collectTo(Unknown Source:0)] [kotlinx.coroutines.flow.CallbackFlowBuilder.collectTo(SourceFile:330)] [kotlinx.coroutines.flow.internal.ChannelFlow$collectToFun$1.invokeSuspend(SourceFile:56)] [kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(SourceFile:33)] [kotlinx.coroutines.DispatchedTask.run(SourceFile:104)] [androidx.work.impl.utils.SerialExecutorImpl$Task.run(SourceFile:96)] [java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)] [java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:644)] [java.lang.Thread.run(Thread.java:1012)]
05-30 07:22:12.163 10954 10978 D AbstractConnection: Socket timeout after 0 retries
05-30 07:22:12.163 10954 10978 D AbstractConnection: Socket creation failed (attempt 6)
05-30 07:22:12.364 10954 10978 D AbstractConnection: Socket creation failed (attempt 7)
05-30 07:22:12.567 10954 10978 D AbstractConnection: Socket creation failed (attempt 8)
05-30 07:22:12.769 10954 10978 D AbstractConnection: Socket creation failed (attempt 9)
05-30 07:22:12.971 10954 10978 D ConnectionFactory: Connecting to remote URL
05-30 07:22:12.976 10954 11019 I WM-WorkerWrapper: Worker result SUCCESS for Work [ id=219cb3ac-4c99-4a60-9f34-81a4d6cd8e05, tags={ org.openhab.habdroid.core.FcmRegistrationWorker } ]
05-30 07:22:12.992 10954 10954 D MainActivity: onActiveConnectionChanged()
05-30 07:22:13.008 10954 10954 D AbstractBaseActivity: Queue snackbar with tag connectionEstablished
05-30 07:22:13.009 10954 10954 D ContentController: Update to connection org.openhab.habdroid.core.connection.DefaultConnection@64b7523 (message null)
05-30 07:22:13.009 10954 10954 D PageConnectionHolderFragment: updateActiveConnections: URL list [], connection org.openhab.habdroid.core.connection.DefaultConnection@64b7523
05-30 07:22:13.009 10954 10978 D PeriodicItemUpdateWorker: doPeriodicWork()
05-30 07:22:13.009 10954 10978 D BackgroundTasksManager: scheduleUpdatesForAllKeys()
05-30 07:22:13.016 10954 10978 D BackgroundTasksManager: Periodic workers are not needed, canceling...
05-30 07:22:13.026 10954 10978 D BackgroundTasksManager: Periodic workers are not needed, canceling...
05-30 07:22:13.027 10954 10978 D BackgroundTasksManager: Periodic workers are not needed, canceling...
05-30 07:22:13.028 10954 10978 D BackgroundTasksManager: Periodic workers are not needed, canceling...
05-30 07:22:13.050 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:13.051 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:13.053 10954 10954 D ServerConfiguration: load: ServerConfiguration(id=1, name=openHAB, localPath=ServerPath(url=http://<openhab-local-address-openHAB>:8080/, userName=<none>, password=<none>), remotePath=ServerPath(url=https://myopenhab.org/, userName=<redacted>, password=<redacted>), sslClientCert=null, defaultSitemap=null, wifiSsids=[], restrictToWifiSsids=false, frontailUrl=null, mainUiStartPage=null)
05-30 07:22:13.055 10954 10954 D FcmRegistrationWorker: Register device at openHAB cloud with URL: addAndroidRegistration<redacted>
