Hi Patrick,
1000 thanks!!
I was able to add 3 HUT’s without any issues, except that I had to restart openhab each time before the new HUT would become online.
From 4th up to 8th HUT I tried to add, there are always max 3-4 HUT’s online. (and the rest gives ERROR:COM)
Even those that were OK before. (HUT 1-3)
17:18:36.082 [INFO ] [inding.anel.internal.AnelUdpConnector] - Anel NET-PwrCtrl listener started for: ‘192.168.5.246:7677’
17:18:36.098 [INFO ] [inding.anel.internal.AnelUdpConnector] - Anel NET-PwrCtrl listener started for: ‘192.168.5.245:7577’
17:18:38.149 [INFO ] [re.automation.internal.RuleEngineImpl] - Rule engine started.
17:18:42.089 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel6’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=192.168.5.246,user=admin,password=XXXX,udpSendPort=7675,udpReceiverPort=7677]
17:18:42.089 [INFO ] [inding.anel.internal.AnelUdpConnector] - Anel NET-PwrCtrl listener started for: ‘192.168.5.248:7877’
17:18:42.106 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel5’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=192.168.5.245,user=admin,password=XXXX,udpSendPort=7575,udpReceiverPort=7577]
17:18:42.122 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel8’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=192.168.5.248,user=admin,password=XXXX,udpSendPort=7875,udpReceiverPort=7877]
17:18:48.127 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel2’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=192.168.5.242,user=admin,password=XXXX,udpSendPort=7275,udpReceiverPort=7277]
17:18:48.143 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel6’ changed from OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=192.168.5.246,user=admin,password=XXXX,udpSendPort=7675,udpReceiverPort=7677] to ONLINE
17:18:48.156 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel7’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=net-control,user=admin,password=XXXX,udpSendPort=7775,udpReceiverPort=7777]
17:18:48.161 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel5’ changed from OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=192.168.5.245,user=admin,password=XXXX,udpSendPort=7575,udpReceiverPort=7577] to ONLINE
17:18:54.150 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel1’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=192.168.5.241,user=admin,password=XXXX,udpSendPort=7175,udpReceiverPort=7177]
17:18:54.167 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel4’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=192.168.5.244,user=admin,password=XXXX,udpSendPort=7475,udpReceiverPort=7477]
17:18:54.178 [INFO ] [inding.anel.internal.AnelUdpConnector] - Anel NET-PwrCtrl listener started for: ‘net-control:7777’
17:18:54.181 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel8’ changed from OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=192.168.5.248,user=admin,password=XXXX,udpSendPort=7875,udpReceiverPort=7877] to ONLINE
17:19:00.154 [INFO ] [inding.anel.internal.AnelUdpConnector] - Anel NET-PwrCtrl listener started for: ‘192.168.5.242:7277’
17:19:00.154 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing ‘anel:advanced-firmware:anel3’ changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): Device does not respond (check IP, ports, and network connection): AnelConfiguration[hostname=192.168.5.243,user=admin,password=XXXX,udpSendPort=7375,udpReceiverPort=7377]
For those offline I see:
17:30:54.360 [DEBUG] [inding.anel.internal.AnelUdpConnector] - Sending message ‘wer da?’ to 192.168.5.241:7175
17:30:54.364 [DEBUG] [inding.anel.internal.AnelUdpConnector] - Sending successful.
But no response …
When I disable the 3 HUT’s that are OK, 3 other HUT’s will become OK
eg HUT 1 now is OK:
17:35:34.332 [DEBUG] [inding.anel.internal.AnelUdpConnector] - Sending message ‘wer da?’ to 192.168.5.241:7175
17:35:34.336 [DEBUG] [inding.anel.internal.AnelUdpConnector] - Sending successful.
And the response is there:
17:35:34.338 [DEBUG] [inding.anel.internal.AnelUdpConnector] - Received data: NET-PwrCtrl:NET-CONTROL 01 :192.168.5.241:255.255.255.0:192.168.5.1:0.4.163.18.5.33:Nr.1,1:Nr.2,1:Nr.3,1:Nr.4,1:Nr.5,1:Nr.6,0:Nr.7,0:Nr.8,0:0:80:IO-1,1,1:IO-2,1,1:IO-3,1,1:IO-4,1,1:IO-5,1,1:IO-6,1,1:IO-7,1,1:IO-8,1,1:25.5�C:NET-PWRCTRL_06.5:h:n:xor:
And the same again when I disable again those OK/Online … the last HUTs will become OK.
So all individual configs are ok. But looks like there’s an issue when there are more than 3 HUT’s enabled?
8x NET-PwrCtrl HUT Ver.: 6.5
Openhab 3.0.2
BR,
Peter
