Sorry Hans-Joerg, I thought this is a reply to the member only, didn’t realize its going out to all. Next time I’ll do all in English.
Hi gents,
this animated widget is great. After fiddling around with positve an negative values and creation of some calculation-only-items, it works perfect for me. Btw,is there a copyright on the icons / images?
Kind regards
Thomas
I have now replaced my animated energy widget with Florian’s great one.I copied the code from Github and I haven’t made changes to the original code. I have one question. For some reason there seems to be no energy flow from grid to the house even though the screen copy below shows that the power our house takes from the grid is 1876W.
Second screen copy shows that no arrows for energy transfer are shown. Energy is taken mainly from the batteries and only some power from the grid.
So what I’m missing here?
An update. Below is a screen copy of two animated energy widgets.
The upper one is florian-h05’s widget and the lower one is DrRSatzteil’s (post #79). As you can see the animated arrows are missing in the upper widget but the lower one shows correct arrows.
Are you running latest OH? Read Florian’s posts, the part on oh-context.
Sorry, I forgot to mention that I’m running OH4.3.3.
English version below picture
Hallo,
ich mag das Widget. Mir werden aber leider nicht alle Werte richtig angezeigt.
- Die PV Leistung wird gar nicht angezeigt, obwohl angegeben
- Die Watt beim Netzbezug werden nur angezeigt, wenn ich bei Netzbezug und Netzeinspeisung das gleiche Item setze, den Netzbezug.
- Die Ladung der Batterie wird nie angezeigt.
Ich habe schon viele Optionen, welches Item ich wo setze, ausprobiert. Das Einzige, was ich Sinnvoll hinbekomme ist die Ladung des Speichers, die Netzeinspeisung und die Entladung der Batterie.
Hat jemand eine Idee woran das liegen könnte?
English version
I like the widget. Unfortunately, not all values are displayed correctly.
- The PV power is not displayed at all, although it is specified
- The watts for grid consumption are only displayed if I set the same item for grid consumption and grid feed-in, the grid consumption.
- The battery charge is never displayed.
I have already tried many options as to which item I set where. The only thing that makes sense to me is charging the storage tank, feeding into the grid and discharging the battery.
Does anyone have any idea what the problem could be?
There is no general advice we can give you: all depends heavily on the data you are feeding into the widget.
Is grid feeding power plus or minus? Is the load power generator plus and the consumer minus? Or vica versa?
Here is my code to compare your existing widget code, which I adapted mostly to a Fronius Inverter.
widget code
uid: PV_widget1
tags: []
props:
parameters:
- context: item
label: Grid power
required: true
type: TEXT
- context: item
label: Load
required: true
type: TEXT
- context: item
label: Solar power
required: true
type: TEXT
- context: item
label: Battery power
required: true
type: TEXT
- context: item
label: Battery level
required: true
type: TEXT
parameterGroups: []
timestamp: Aug 16, 2024, 10:19:56 AM
component: f7-card
class:
- display-flex
- flex-direction-column
- align-items-center
style:
height: 383px
slots:
content:
- component: f7-block
style:
--f7-theme-color: var(--f7-text-color)
display: flex
justify-content: space-between
padding: 0
slots:
default:
- component: f7-col
style:
align-items: center
display: flex
flex-direction: row
slots:
default:
style:
align-items: center
display: flex
flex-direction: column
height: 110px
justify-content: center
width: 110px
slots:
default:
- component: oh-icon
height: 110px
icon: sma_grid_2
- component: Label
style:
color: '=items[props.gridpower].state.split(" ")[0] > 0 ? "red" :
items[props.gridpower].state.split(" ")[0] == 0 ?
"white" : "green"'
font-size: 25px
font-weight: bold
margin-top: -10px
text-align: center
width: 100px
text: =Math.abs(items[props.gridpower].state.split(" ")[0]).toFixed(0) + ' W'
- component: f7-col
style:
align-items: center
display: flex
flex-grow: 1
slots:
default:
style:
align-items: center
display: flex
height: 110px
margin-top: 0
width: 110px
slots:
default:
- component: Label
style:
font-size: 25px
font-weight: bold
text-align: center
width: 100px
text: =items[props.solarpower].displayState
height: 110px
icon: sma_pv_2
style:
margin-top: -20px
style:
display: flex
margin: 0
padding: 0
width: 100%
slots:
default:
- component: f7-row
preserveAspectRatio: xMidYMid slice
style:
height: 100px
width: 100px
tag: svg
viewBox: 0 0 100 100
xmlns: http://www.w3.org/2000/svg
slots:
default:
- component: f7-row
d: M60 -10 v10 c0 40 10 35 30 35 h20
fill: none
stroke: rgba(100, 150, 200, 0.8)
stroke-width: 2
tag: path
vector-effect: non-scaling-stroke
visible: =items[props.batterypower].state.split(" ")[0] < 0 &&
items[props.solarpower].state.split(" ")[0] >
0
- component: f7-row
fill: rgba(100, 150, 200, 0.8)
r: 6
style:
stroke-width: 4
tag: circle
0
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
repeatCount: indefinite
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#topright"
- component: f7-row
d: M40 -10 v10 c0 40 -10 35 -30 35 h-20
fill: none
stroke-width: 2
tag: path
visible: =items[props.solarpower].state.split(" ")[0] > 0 &&
items[props.gridpower].state.split(" ")[0] < 0
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
vectorEffect: non-scaling-stroke
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#topleft"
- component: f7-row
d: M50, 0 v100
fill: none
stroke-width: 2
tag: path
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#vertical"
- component: f7-row
d: M-5 55 l10 0 c40 0 35 10 35 50 l0 20
fill: none
stroke-width: 2
tag: path
visible: =items[props.gridpower].state.split(" ")[0] > 0
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#botleft"
- component: f7-row
d: '=items[props.gridpower].state.split(" ")[0] > 0 ? "M0, 45 h100" : "M100, 45
h-100"'
fill: none
stroke-width: 2
tag: path
visible: =(items[props.gridpower].state.split(" ")[0] > 0 &&
items[props.solarpower].state.split(" ")[0] <
Math.abs(Math.min(0,
")[0]))) ||
(items[props.batterypower].state.split(" ")[0]
> 0 && items[props.gridpower].state.split("
")[0] < 0 &&
items[props.solarpower].state.split(" ")[0] <=
0)
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
")[0]))) ||
")[0] < 0 &&
0)
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#horizontal"
- component: f7-row
d: M 105 55 l-10 0 c-40 0 -35 10 -35 50 l0 20
fill: none
stroke-width: 2
tag: path
visible: =items[props.batterypower].state.split(" ")[0] > 0
- component: f7-row
r: 6
strokeWidth: 10
tag: circle
slots:
default:
- component: f7-row
calcMode: linear
dur: 4s
tag: animateMotion
slots:
default:
- component: f7-row
tag: mpath
xlink:href: "#botright"
style:
align-items: center
display: flex
height: 110px
margin-top: -10px
width: 110px
slots:
default:
height: 110px
icon: sma_consumption_2
- component: Label
style:
font-size: 25px
font-weight: bold
margin-top: -10px
text-align: center
width: 100px
text: =Math.abs(items[props.load].state.split(" ")[0]).toFixed(0) + ' W'
- component: f7-col
style:
align-items: center
display: flex
flex-direction: row
slots:
default:
style:
align-items: center
display: flex
height: 110px
width: 110px
slots:
default:
- component: oh-link
action: analyzer
actionAnalyzerCoordSystem: time
actionAnalyzerItems: =[props.batterylevel]
iconColor: '=items[props.batterylevel].state.split(" ")[0] < 75 ?
items[props.batterylevel].state.split(" ")[0] < 10 ?
"red" : "orange" : "green"'
iconF7: '=items[props.batterylevel].state.split(" ")[0] < 75 ?
"battery_0" : "battery_25" : "battery_100"'
iconSize: 33px
style:
font-size: 25px
font-weight: bold
position: absolute
top: -25px
white-space: nowrap
text: =Math.abs(items[props.batterylevel].state.split(" ")[0]).toFixed(0) + ' %'
height: 110px
icon: sma_battery_2
- component: Label
style:
color: '=items[props.batterypower].state.split(" ")[0] > 0 ? "red" :
items[props.batterypower].state.split(" ")[0] == 0
? "white" : "green"'
font-size: 25px
font-weight: bold
margin-top: -10px
text-align: center
white-space: nowrap
width: 100px
text: =Math.abs(items[props.batterypower].state.split(" ")[0]).toFixed(0) + ' W'
Please don’t do that, only write in English, this is an international forum.
Imagine all non native English speakers would post their own French, Italian, Spanish, Russian, Polish, … language in addition to English: it would clutter the forum to no availabilty.
Oh, sorry. You’re right that it would get out of hand if everyone did that. I hadn’t considered that. I’ll leave that out in future.
Thank you for your code. It fits better. I just had to change the value for load to Kwh, as my smart meter can’t give the actual consumption values, only what comes in.
But it does not show the solar power value, as you do in watts. I only get a display there if I take the daily value or the total output in Kwh as an item. It also does not show the current flow to the battery for charging. Am I setting the wrong items?
My solar modules charge a battery (solar farm). The battery charges itself or passes the electricity on to the inverter (AP_Systems_EZ1), which feeds it into the house. Which item should go where?
For my version of that widget I am using:
Grid power: negative values = drawing from grid, positive values = feeding into grid
Load: total electricity consumption
Solar power: total solar power generated
Battery power: negative values = drawing from battery, positive values charging the battery
Battery level: SoC of battery
If you have different items, you need to adapt your widget code.
What would I have to change if I wanted to display the current output of the solar modules instead of the total solar energy generated?
I’m terrible at this kind of programming. I have tried to make the changes myself. But I can’t get through.
You need to put the item carrying the current solar output value in the “Solar power” field.
Here is a screenshot of my variant of the base widget. Purpose is to provide ideas to other users. The content is as following:
- The 2 head lines represent 2 balcony generators, their energy generation at the left (daily und grand total), their amortisation in the middle (earnings, getting green if the initial investment is rectified) and their power at the very right.
- Below this, we have the roof PV generator at the left (daily und grand total) and PV battery voltage and current at the right.
- At the lower left corner we have power consumption from grid (red arrow) and feed power to grid (green arrow) with related costs/earnings.
- At the lower right corner we have the weather. Clouds (31%), outside temperature and daily sunshine duration. Below these figures are the main power consumers, two 10kW heat pumps, one for the heating/warm water and one for cooling (summer).
The energy flow lines show the following interesting situation:
The PV battery is charged through two pathes, one from the roof PV modules (currently 3387 W) and one from the balcony generators (see upper right corner, 200 W plus 396 W) using the grid path (currently additional 156 W charge power). The grid path is usually used to prevent the battery from deep discharge below a minimum SoC level.
