Animated Energy Widget
Inspired by the new SMA Energy App and some tips from this topic I created a animated Energy or PV widget. For sure, one or the other can be solved in a simpler and more generic way. But I am not an expert and had to work out a lot of things by trial and error.
Screenshots
On this screenshot you can see all used items. Depending on the input parameters, these are then shown or hidden.
Changelog
Version 0.1
  • initial release
Resources
uid: SMA_widget
tags: []
props:
  parameters:
    - context: item
      label: Netzeinspeisung
      required: true
      type: TEXT
    - context: item
      label: Netzbezug
      required: true
      type: TEXT
    - context: item
      label: Gesamtverbrauch
      required: true
      type: TEXT
    - context: item
      label: PV Leistung
      required: true
      type: TEXT
    - context: item
      label: Batterieleistung
      required: true
      type: TEXT
    - context: item
      label: Batterie Ladezustand
      required: true
      type: TEXT
  parameterGroups: []
timestamp: Feb 20, 2022, 4:29:01 PM
component: f7-card
  class:
    - display-flex
    - flex-direction-column
    - align-items-center
  style:
    height: 383px
slots:
  content:
    - component: f7-block
        style:
          --f7-theme-color: var(--f7-text-color)
          display: flex
          justify-content: space-between
          padding: 0
      slots:
        default:
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      flex-direction: column
                      height: 110px
                      justify-content: center
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                      - component: oh-icon
                          height: 110px
                          icon: sma_grid_2
                      - component: Label
                          style:
                            color: red
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                          text: =items[props.netzbezug].displayState
                          visible: '=(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) == 0) ? true : false'
                      - component: Label
                          style:
                            color: green
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                          text: =items[props.netzeinspeisung].displayState
                          visible: '=(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) > 0) ? true : false'
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-grow: 1
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 25px
                            font-weight: bold
                            text-align: center
                            width: 100px
                          text: =items[props.pv_leistung].displayState
                          height: 110px
                          icon: sma_pv_2
                          style:
                            margin-top: -20px
                    style:
                      display: flex
                      margin: 0
                      padding: 0
                      width: 100%
                  slots:
                    default:
                      - component: f7-row
                          preserveAspectRatio: xMidYMid slice
                          style:
                            height: auto
                            width: auto
                          tag: svg
                          viewBox: 0 0 100 100
                          xmlns: http://www.w3.org/2000/svg
                        slots:
                          default:
                            - component: f7-row
                                d: M60 -5 v10 c0 30 10 35 30 35 h20
                                fill: none
                                stroke: rgba(100, 150, 200, 0.8)
                                stroke-width: 2
                                tag: path
                                vector-effect: non-scaling-stroke
                                visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) < 0) ? true : false'
                            - component: f7-row
                                fill: rgba(100, 150, 200, 0.8)
                                r: 6
                                style:
                                  stroke-width: 4
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      repeatCount: indefinite
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                                            xlink:href: "#path1"
                            - component: f7-row
                                d: M40 -5 v10 c0 40 -10 35 -30 35 h-20
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) > 0 && Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) == 0) ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                                vectorEffect: non-scaling-stroke
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                                            xlink:href: "#path2"
                            - component: f7-row
                                d: M50, 0 v100
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.pv_leistung].state.split(" ")[0]) - (Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) + Math.abs(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]))) > 0) ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                                            xlink:href: "#path3"
                            - component: f7-row
                                d: M-5 50 l10 0 c40 0 35 10 35 50 l 0 20
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.netzbezug].state.split(" ")[0]) > 0) ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                                            xlink:href: "#path4"
                            - component: f7-row
                                d: M 105 50 l -10 0 c -40 0 -35 10 -35 50 l 0 20
                                fill: none
                                stroke-width: 2
                                tag: path
                                visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) > 0) ? true : false'
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                                            xlink:href: "#path5"
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -10px
                      width: 110px
                  slots:
                    default:
                          color: orange
                          height: 110px
                          icon: sma_consumption_2
                      - component: Label
                          style:
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                          text: =items[props.gesamtverbrauch].displayState
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -40px
                      width: 110px
                  slots:
                    default:
                      - component: oh-link
                          iconColor: red
                          iconF7: battery_0
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          text: =items[props.batterylevel].state
                          visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 10) ? true : false'
                          iconColor: orange
                          iconF7: battery_25
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 10 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 75) ? true : false'
                          iconColor: green
                          iconF7: battery_100
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 75) ? true : false'
                          height: 110px
                          icon: sma_battery_2
                          style:
                            margin-top: -20px
                      - component: Label
                          style:
                            color: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) > 0) ? "red" : "green"'
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            white-space: nowrap
                            width: 100px
                          text: =Math.abs(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0])) + ' ᵂ'
                          visible: '=(Number.parseFloat(items[props.batterieleistung].state.split(" ")[0]) !== 0) ? true : false'
Unfortunately, the parameters are in German. All values have the unit W. Only battery level is in %. I have a rule that recalculates these values on a regular basis.
Here are the icons you need:
Please save them as *.png under conf/icons/classic. If you don’t have your own icons yet, just create a classic folder.
This looks really cool. I’m not yet in a position to add this widget to my OH pages because I still have quite a few issues with my hardware (e.g. expecting to replace my PV inverter with a new one). I have also looked at the other widget in this topic.
Looks nice. But (as there is always a but) Arrows doesn’t show actual directions, right? They are “just” animated?
Cheers
Here are arrows with directions E3DC Solar Widget 1.2 with animated arrows
The direction is displayed and only the active ones.
energie
Ahh, OK. Currently I didn’t get an values displayed. How are your items configured? I already tried to rename mine to the names from Widget as well as I changed Widget to reflect my Item Names.
You dont have to rename anything. Go to settings/pages. Click to the setting symbol of the wiget and choose configure cell. There are boxes to pick your items.
OK, missed the option to “Set_Props” :wink:
But … I configured all of them and most are shown right away. Once I saved it I did get confirmation “Widget updated”. Once I left widget and go back into it, configuration is lost and nothing is shown up :frowning:
Changes to other widgets are working, and also if I add tags to this widget, it’s working as well. just not to “set” Props.
I dont realy know the problem, but you have to save at two different points. I mean this was my problem, too.
My widget on the overview page shows the input power from net and the power of the PV panels but all the animated arrows are missing. In the Set widget props page the parameters are in German so I wonder whether anybody could translate what they mean. I tried with Google translator but translations are really bad so I’m not quite sure what they mean.
Netzeinspeisung = the electricity that goes from your house to the energy supplier
Netzbezug = the electricity you get from the energy supplier
Gesamtverbrauch = the total consumption of your house
Batterieleistung = the current flowing to/from the battery (charging/discharging)
Battery state of charge in percent
Great, this helps a lot. I have an electricity meter (ABB) which measures electricity flow in both directions so when it gives negative power it means that I’m exporting electricity. Now I’m wondering whether I would need a new Item for Netzeinspeisung which would be 0 when importing electricity and positive value when exporting. I guess Gesamtverbrauch is the sum of Netzbezug and PV Leistung.
As I mentioned in my previous post the animated arrows are missing. I don’t have batteries so I didn’t put anything for Batterieleistung but the widget on my overview page shows NaN for the battery so I wonder how to eliminate this. I guess I could delete the code for batterie.
Network reference can also be negative, at least that’s how it works for me. All values that you do not use should be assigned a dummy item which has the value 0.
Simply removing values is not so easy because there are some dependencies.
I also had to adjust the widget because I don’t have a total consumption and it’s just too big for my tablet
OK, many thanks for the info. I’ll need to do more testing then.
I have to say this widget is really awesome. Only small issue is the battery icon which I would like to get rid of. I have cropped the original icons so now the arrows are closer to the icons. Animations for the arrows are working for me but they don’t show up in the static screen capture. PV power is still pretty low because it is early morning here.
Then simply delete this area, it’s pretty much at the end
                          iconColor: red
                          iconF7: battery_0
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          iconColor: orange
                          iconF7: battery_25
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
                          iconColor: green
                          iconF7: battery_100
                          iconSize: 33px
                          style:
                            font-size: 25px
                            font-weight: bold
                            white-space: nowrap
OK, many thanks. Yes, now the battery icon disappeared from the widget.
A note for use with Safari:
Safari needs a defined width and height for the SVG animation. auto does not work.
like this:
- component: f7-row
      style:
           height: 100px
           width: 100px
       tag: svg
wow, very good icons. Is it possible to create a windmill-icon in the same style? That would be great!
Very cool widget!
I also don’t have a battery and thus I changed the code to:
uid: SMA_widget
tags: []
props:
  parameters:
    - context: item
      required: true
      type: TEXT
    - context: item
      label: Netzbezug
      required: true
      type: TEXT
    - context: item
      required: true
      type: TEXT
    - context: item
      label: PV Leistung
      required: true
      type: TEXT
  parameterGroups: []
timestamp: Apr 22, 2022, 6:08:33 PM
component: f7-card
  class:
    - display-flex
  style:
    height: 383px
slots:
  content:
        style:
          display: flex
          padding: 0
      slots:
        default:
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-direction: row
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                          height: 110px
                          icon: sma_grid_2
                      - component: Label
                          style:
                            color: red
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
                      - component: Label
                          style:
                            color: green
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
          - component: f7-col
              style:
                align-items: center
                display: flex
                flex-grow: 1
            slots:
              default:
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: 0
                      width: 110px
                  slots:
                    default:
                      - component: Label
                          style:
                            font-size: 25px
                            font-weight: bold
                            text-align: center
                            width: 100px
                          height: 110px
                          icon: sma_pv_2
                          style:
                            margin-top: -20px
                    style:
                      display: flex
                      margin: 0
                      padding: 0
                      width: 100%
                  slots:
                    default:
                      - component: f7-row
                          style:
                            height: auto
                            width: auto
                          tag: svg
                        slots:
                          default:
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                style:
                                  stroke-width: 4
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                d: M50, 0 v100
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                            - component: f7-row
                                fill: none
                                stroke-width: 2
                                tag: path
                            - component: f7-row
                                r: 6
                                strokeWidth: 10
                                tag: circle
                              slots:
                                default:
                                  - component: f7-row
                                      calcMode: linear
                                      dur: 4s
                                      tag: animateMotion
                                    slots:
                                      default:
                                        - component: f7-row
                                            tag: mpath
                    style:
                      align-items: center
                      display: flex
                      height: 110px
                      margin-top: -10px
                      width: 110px
                  slots:
                    default:
                          color: orange
                          height: 110px
                      - component: Label
                          style:
                            font-size: 25px
                            font-weight: bold
                            margin-top: -10px
                            text-align: center
                            width: 100px
On my setup the energy flow from PV to consumers is not shown:
Should that work on setups with battery?
Marco
