Gexle
(Gexle)
August 22, 2022, 9:02am
1
Hi
I’m looking for a Yaml code to allow my Piko 5.5 to display the values graphically on OB3.
Unfortunately I can’t build one myself, I know far too little about it.
(Вася Пупкин)
August 22, 2022, 10:18am
2
If you’ll press “Analyze” button on any of your Pico items, you’ll get a chart of that item’s values. There will be a “Controls” button, which will allow you to add more items you want to show in your graph, then you can press Save button to save this chart as a page, and you can check the yaml code of that page, copypaste the code to your widget.
And there are a lot of energy widgets in community marketplace:
[Screenshot_20220213-104729]
Inspired by the new SMA Energy App and some tips from this topic I created a animated Energy or PV widget. For sure, one or the other can be solved in a simpler and more generic way. But I am not an expert and had to work out a lot of things by trial and error.
Screenshots
[Screenshot_20220213-104749]
On this screenshot you can see all used items. Depending on the input parameters, these are then shown or hidden.
[Bild1]
Changelog
Version 0.1
initial relea…
[LinkyListItemScreenShot]
This is an UI List Item Widget to view the consumption of your home from the Linky electric meter by Enedis(French), use with the Linky Binding and zigbee2mqtt with Lixee ZLinky_TIC or Teleinfo Binding .
Linky electric meter with TIC mode: Historical, electricity connection: single phase and pricing mode: HCHP.
Only use with List Card with accordion and rich list items option set to true.
Support to use a light and a dark background.
Configuration parameters:
All…
