Yes, no problem. I am interested in the gust channel too.
Since i’m playing with that binding a bit, I have some other questions ![]()
If i understood this right, these are the calls per minute… right? If so… we are limited for the hourly forecast to 5 calls.. isn’t it? so we can only choose five of the 3,6,9,12,15,18,21,24h things…
I’m not sure about this… so i’d better ask here
and another thing… regarding weather station location, my item:
Location owmCurrentStationLocation "Wetterstation Geokoordinaten [%s]" <text> (gOwmCurrent, gOwmCurrentStation) {channel="openweathermap:weather:api:local:station#location"}
My sitemap:
Text item=owmCurrentStationLocation
but in the BasicUI i dont see any entry… I also tried to use “String” instead of “Location” in the items file…
The value is set from the API… i’ve seen it in the log… any hint to display the geocords (text is just fine)?
Thanks, cheers
This is my defenition:
Location LocalWeather_StationLocation "Location" {channel="openweathermap:weather:api:local:station#location"}
And the returned value is: LocalWeather_StationLocation(52.53,-x.xx) redacted for privacy!
I am not sure. But it sounds correct. The binding requests the OWM API for each hourly forecast location once which will sum up to five calls for five different things / locations. But the minimum polling interval you are allowed to use with the binding is 10min. I assume we are on a save track.
Hm …, good question. The only way I can think of is using a Mapview element in the sitemap. Nothing else seem to work.
Mapview item=owmCurrentStationLocation height=5
I created an issue to clarify or introduce a solution:
https://github.com/eclipse/smarthome/issues/6110
I did a API call in the browser… and now i got it
the one API call “forecast” contains data for 5 days in steps of 3 hours…
Okay so yes we should be safe…
Okay i will give it a try… thanks
Open Weather Map - Examples
this is how i set up my openweather map items and sitemap… (since the readme only contains a few entries) I want to share this for user to simple can copy and paste… (sorry only in german right now…)
To save a lot of editing and writing… i used groups for the hourly forecast…
How it looks:
openweathermap.items
Group gOwmCurrent
Group gOwmCurrentStation (gOwmCurrent)
Group gOwmForecastHour <chart>
Group gOwmForecastHour03 (gOwmForecastHour)
Group gOwmForecastHour06 (gOwmForecastHour)
Group gOwmForecastHour09 (gOwmForecastHour)
Group gOwmForecastHour12 (gOwmForecastHour)
Group gOwmForecastHour15 (gOwmForecastHour)
Group gOwmForecastHour18 (gOwmForecastHour)
Group gOwmForecastHour21 (gOwmForecastHour)
Group gOwmForecastHour24 (gOwmForecastHour)
Group gOwmForecastHourStation (gOwmForecastHour)
String owmCurrentStationId "Wetterstation ID" <house> (gOwmCurrent, gOwmCurrentStation) {channel="openweathermap:weather:api:local:station#id"}
String owmCurrentStationName "Wetterstation Name" <house> (gOwmCurrent, gOwmCurrentStation) {channel="openweathermap:weather:api:local:station#name"}
Location owmCurrentStationLocation "Wetterstation Geokoordinaten [%2$s,%3$s]" <house> (gOwmCurrent, gOwmCurrentStation) {channel="openweathermap:weather:api:local:station#location"}
DateTime owmCurrentStationTimestamp "Letzte Messung [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]" <time> (gOwmCurrent, gOwmCurrentStation) {channel="openweathermap:weather:api:local:current#time-stamp"}
String owmCurrentCondition "Aktuelle Wetterlage [%s]" <sun_clouds> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#condition"}
String owmCurrentConditionId "Aktuelle Wetterlage ID [%s]" <sun_clouds> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#condition-id"}
Image owmCurrentIcon "Aktuelle Wetterlage Icon" <sun_clouds> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#icon"}
String owmCurrentIconId "Aktuelle Wetterlage Icon ID" <sun_clouds> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#icon-id"}
Number:Temperature owmCurrentTemperature "Aktuelle Temperatur [%.1f %unit%]" <temperature> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#temperature"}
Number:Pressure owmCurrentPressure "Aktueller Luftdruck [%.1f %unit%]" <pressure> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#pressure"}
Number:Dimensionless owmCurrentHumidity "Aktuelle Luftfeuchtigkeit [%.1f %unit%]" <humidity> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#humidity"}
Number:Speed owmCurrentWindSpeed "Aktuelle Windgeschwindigkeit [%.1f km/h]" <wind> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#wind-speed"}
Number:Dimensionless owmCurrentWindDirection "Aktuelle Windrichtung [SCALE(wind.scale):%s]" <wind> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#wind-direction"}
Number:Dimensionless owmCurrentCloudiness "Aktuelle Bewölkung [%.1f %unit%]" <sun_clouds> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#cloudiness"}
Number:Length owmCurrentRain "Aktueller Regen [%.1f %unit%]" <rain> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#rain"}
Number:Length owmCurrentSnow "Aktueller Schneefall [%.1f %unit%]" <snow> (gOwmCurrent) {channel="openweathermap:weather:api:local:current#snow"}
// Forecast Hour03
Image owmForecastHour03Icon "3h Vorhersage Wetterlage Icon" <sun_clouds> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#icon"}
String owmForecastHour03Condition "3h Vorhersage Wetterlage [%s]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#condition"}
String owmForecastHour03ConditionId "3h Vorhersage Wetterlage ID [%s]" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour03)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours03#condition-id"}
String owmForecastHour03IconId "3h Vorhersage Wetterlage Icon ID" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour03)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours03#icon-id"}
Number:Temperature owmForecastHour03Temperature "3h Vorhersage Temperatur [%.1f %unit%]" <temperature> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#temperature"}
Number:Pressure owmForecastHour03Pressure "3h Vorhersage Luftdruck [%.1f %unit%]" <pressure> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#pressure"}
Number:Dimensionless owmForecastHour03Humidity "3h Vorhersage Luftfeuchtigkeit [%.1f %unit%]" <humidity> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#humidity"}
Number:Speed owmForecastHour03WindSpeed "3h Vorhersage Windgeschwindigkeit [%.1f km/h]" <wind> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#wind-speed"}
Number:Dimensionless owmForecastHour03WindDirection "3h Vorhersage Windrichtung [SCALE(wind.scale):%s]" <wind> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#wind-direction"}
Number:Dimensionless owmForecastHour03Cloudiness "3h Vorhersage Bewölkung [%.1f %unit%]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#cloudiness"}
Number:Length owmForecastHour03Rain "3h Vorhersage Regen [%.1f %unit%]" <rain> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#rain"}
Number:Length owmForecastHour03Snow "3h Vorhersage Schneefall [%.1f %unit%]" <snow> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#snow"}
DateTime owmForecastHour03Timestamp "3h Vorhersage Zeit [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]" <time> (gOwmForecastHour,gOwmForecastHour03) {channel="openweathermap:hourly-forecast:api:local:forecastHours03#time-stamp"}
// Forecast Hour06
Image owmForecastHour06Icon "6h Vorhersage Wetterlage Icon" <sun_clouds> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#icon"}
String owmForecastHour06Condition "6h Vorhersage Wetterlage [%s]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#condition"}
String owmForecastHour06ConditionId "6h Vorhersage Wetterlage ID [%s]" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour06)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours06#condition-id"}
String owmForecastHour06IconId "6h Vorhersage Wetterlage Icon ID" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour06)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours06#icon-id"}
Number:Temperature owmForecastHour06Temperature "6h Vorhersage Temperatur [%.1f %unit%]" <temperature> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#temperature"}
Number:Pressure owmForecastHour06Pressure "6h Vorhersage Luftdruck [%.1f %unit%]" <pressure> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#pressure"}
Number:Dimensionless owmForecastHour06Humidity "6h Vorhersage Luftfeuchtigkeit [%.1f %unit%]" <humidity> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#humidity"}
Number:Speed owmForecastHour06WindSpeed "6h Vorhersage Windgeschwindigkeit [%.1f km/h]" <wind> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#wind-speed"}
Number:Dimensionless owmForecastHour06WindDirection "6h Vorhersage Windrichtung [SCALE(wind.scale):%s]" <wind> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#wind-direction"}
Number:Dimensionless owmForecastHour06Cloudiness "6h Vorhersage Bewölkung [%.1f %unit%]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#cloudiness"}
Number:Length owmForecastHour06Rain "6h Vorhersage Regen [%.1f %unit%]" <rain> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#rain"}
Number:Length owmForecastHour06Snow "6h Vorhersage Schneefall [%.1f %unit%]" <snow> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#snow"}
DateTime owmForecastHour06Timestamp "6h Vorhersage Zeit [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]" <time> (gOwmForecastHour,gOwmForecastHour06) {channel="openweathermap:hourly-forecast:api:local:forecastHours06#time-stamp"}
// Forecast Hour09
Image owmForecastHour09Icon "9h Vorhersage Wetterlage Icon" <sun_clouds> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#icon"}
String owmForecastHour09Condition "9h Vorhersage Wetterlage [%s]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#condition"}
String owmForecastHour09ConditionId "9h Vorhersage Wetterlage ID [%s]" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour09)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours09#condition-id"}
String owmForecastHour09IconId "9h Vorhersage Wetterlage Icon ID" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour09)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours09#icon-id"}
Number:Temperature owmForecastHour09Temperature "9h Vorhersage Temperatur [%.1f %unit%]" <temperature> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#temperature"}
Number:Pressure owmForecastHour09Pressure "9h Vorhersage Luftdruck [%.1f %unit%]" <pressure> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#pressure"}
Number:Dimensionless owmForecastHour09Humidity "9h Vorhersage Luftfeuchtigkeit [%.1f %unit%]" <humidity> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#humidity"}
Number:Speed owmForecastHour09WindSpeed "9h Vorhersage Windgeschwindigkeit [%.1f km/h]" <wind> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#wind-speed"}
Number:Dimensionless owmForecastHour09WindDirection "9h Vorhersage Windrichtung [SCALE(wind.scale):%s]" <wind> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#wind-direction"}
Number:Dimensionless owmForecastHour09Cloudiness "9h Vorhersage Bewölkung [%.1f %unit%]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#cloudiness"}
Number:Length owmForecastHour09Rain "9h Vorhersage Regen [%.1f %unit%]" <rain> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#rain"}
Number:Length owmForecastHour09Snow "9h Vorhersage Schneefall [%.1f %unit%]" <snow> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#snow"}
DateTime owmForecastHour09Timestamp "9h Vorhersage Zeit [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]" <time> (gOwmForecastHour,gOwmForecastHour09) {channel="openweathermap:hourly-forecast:api:local:forecastHours09#time-stamp"}
// Forecast Hour12
Image owmForecastHour12Icon "12h Vorhersage Wetterlage Icon" <sun_clouds> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#icon"}
String owmForecastHour12Condition "12h Vorhersage Wetterlage [%s]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#condition"}
String owmForecastHour12ConditionId "12h Vorhersage Wetterlage ID [%s]" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour12)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours12#condition-id"}
String owmForecastHour12IconId "12h Vorhersage Wetterlage Icon ID" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour12)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours12#icon-id"}
Number:Temperature owmForecastHour12Temperature "12h Vorhersage Temperatur [%.1f %unit%]" <temperature> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#temperature"}
Number:Pressure owmForecastHour12Pressure "12h Vorhersage Luftdruck [%.1f %unit%]" <pressure> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#pressure"}
Number:Dimensionless owmForecastHour12Humidity "12h Vorhersage Luftfeuchtigkeit [%.1f %unit%]" <humidity> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#humidity"}
Number:Speed owmForecastHour12WindSpeed "12h Vorhersage Windgeschwindigkeit [%.1f km/h]" <wind> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#wind-speed"}
Number:Dimensionless owmForecastHour12WindDirection "12h Vorhersage Windrichtung [SCALE(wind.scale):%s]" <wind> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#wind-direction"}
Number:Dimensionless owmForecastHour12Cloudiness "12h Vorhersage Bewölkung [%.1f %unit%]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#cloudiness"}
Number:Length owmForecastHour12Rain "12h Vorhersage Regen [%.1f %unit%]" <rain> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#rain"}
Number:Length owmForecastHour12Snow "12h Vorhersage Schneefall [%.1f %unit%]" <snow> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#snow"}
DateTime owmForecastHour12Timestamp "12h Vorhersage Zeit [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]" <time> (gOwmForecastHour,gOwmForecastHour12) {channel="openweathermap:hourly-forecast:api:local:forecastHours12#time-stamp"}
// Forecast Hour15
Image owmForecastHour15Icon "15h Vorhersage Wetterlage Icon" <sun_clouds> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#icon"}
String owmForecastHour15Condition "15h Vorhersage Wetterlage [%s]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#condition"}
String owmForecastHour15ConditionId "15h Vorhersage Wetterlage ID [%s]" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour15)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours15#condition-id"}
String owmForecastHour15IconId "15h Vorhersage Wetterlage Icon ID" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour15)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours15#icon-id"}
Number:Temperature owmForecastHour15Temperature "15h Vorhersage Temperatur [%.1f %unit%]" <temperature> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#temperature"}
Number:Pressure owmForecastHour15Pressure "15h Vorhersage Luftdruck [%.1f %unit%]" <pressure> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#pressure"}
Number:Dimensionless owmForecastHour15Humidity "15h Vorhersage Luftfeuchtigkeit [%.1f %unit%]" <humidity> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#humidity"}
Number:Speed owmForecastHour15WindSpeed "15h Vorhersage Windgeschwindigkeit [%.1f km/h]" <wind> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#wind-speed"}
Number:Dimensionless owmForecastHour15WindDirection "15h Vorhersage Windrichtung [SCALE(wind.scale):%s]" <wind> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#wind-direction"}
Number:Dimensionless owmForecastHour15Cloudiness "15h Vorhersage Bewölkung [%.1f %unit%]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#cloudiness"}
Number:Length owmForecastHour15Rain "15h Vorhersage Regen [%.1f %unit%]" <rain> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#rain"}
Number:Length owmForecastHour15Snow "15h Vorhersage Schneefall [%.1f %unit%]" <snow> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#snow"}
DateTime owmForecastHour15Timestamp "15h Vorhersage Zeit [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]" <time> (gOwmForecastHour,gOwmForecastHour15) {channel="openweathermap:hourly-forecast:api:local:forecastHours15#time-stamp"}
// Forecast Hour18
Image owmForecastHour18Icon "18h Vorhersage Wetterlage Icon" <sun_clouds> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#icon"}
String owmForecastHour18Condition "18h Vorhersage Wetterlage [%s]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#condition"}
String owmForecastHour18ConditionId "18h Vorhersage Wetterlage ID [%s]" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour18)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours18#condition-id"}
String owmForecastHour18IconId "18h Vorhersage Wetterlage Icon ID" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour18)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours18#icon-id"}
Number:Temperature owmForecastHour18Temperature "18h Vorhersage Temperatur [%.1f %unit%]" <temperature> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#temperature"}
Number:Pressure owmForecastHour18Pressure "18h Vorhersage Luftdruck [%.1f %unit%]" <pressure> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#pressure"}
Number:Dimensionless owmForecastHour18Humidity "18h Vorhersage Luftfeuchtigkeit [%.1f %unit%]" <humidity> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#humidity"}
Number:Speed owmForecastHour18WindSpeed "18h Vorhersage Windgeschwindigkeit [%.1f km/h]" <wind> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#wind-speed"}
Number:Dimensionless owmForecastHour18WindDirection "18h Vorhersage Windrichtung [SCALE(wind.scale):%s]" <wind> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#wind-direction"}
Number:Dimensionless owmForecastHour18Cloudiness "18h Vorhersage Bewölkung [%.1f %unit%]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#cloudiness"}
Number:Length owmForecastHour18Rain "18h Vorhersage Regen [%.1f %unit%]" <rain> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#rain"}
Number:Length owmForecastHour18Snow "18h Vorhersage Schneefall [%.1f %unit%]" <snow> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#snow"}
DateTime owmForecastHour18Timestamp "18h Vorhersage Zeit [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]" <time> (gOwmForecastHour,gOwmForecastHour18) {channel="openweathermap:hourly-forecast:api:local:forecastHours18#time-stamp"}
// Forecast Hour21
Image owmForecastHour21Icon "21h Vorhersage Wetterlage Icon" <sun_clouds> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#icon"}
String owmForecastHour21Condition "21h Vorhersage Wetterlage [%s]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#condition"}
String owmForecastHour21ConditionId "21h Vorhersage Wetterlage ID [%s]" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour21)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours21#condition-id"}
String owmForecastHour21IconId "21h Vorhersage Wetterlage Icon ID" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour21)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours21#icon-id"}
Number:Temperature owmForecastHour21Temperature "21h Vorhersage Temperatur [%.1f %unit%]" <temperature> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#temperature"}
Number:Pressure owmForecastHour21Pressure "21h Vorhersage Luftdruck [%.1f %unit%]" <pressure> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#pressure"}
Number:Dimensionless owmForecastHour21Humidity "21h Vorhersage Luftfeuchtigkeit [%.1f %unit%]" <humidity> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#humidity"}
Number:Speed owmForecastHour21WindSpeed "21h Vorhersage Windgeschwindigkeit [%.1f km/h]" <wind> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#wind-speed"}
Number:Dimensionless owmForecastHour21WindDirection "21h Vorhersage Windrichtung [SCALE(wind.scale):%s]" <wind> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#wind-direction"}
Number:Dimensionless owmForecastHour21Cloudiness "21h Vorhersage Bewölkung [%.1f %unit%]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#cloudiness"}
Number:Length owmForecastHour21Rain "21h Vorhersage Regen [%.1f %unit%]" <rain> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#rain"}
Number:Length owmForecastHour21Snow "21h Vorhersage Schneefall [%.1f %unit%]" <snow> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#snow"}
DateTime owmForecastHour21Timestamp "21h Vorhersage Zeit [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]" <time> (gOwmForecastHour,gOwmForecastHour21) {channel="openweathermap:hourly-forecast:api:local:forecastHours21#time-stamp"}
// Forecast Hour24
Image owmForecastHour24Icon "24h Vorhersage Wetterlage Icon" <sun_clouds> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#icon"}
String owmForecastHour24Condition "24h Vorhersage Wetterlage [%s]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#condition"}
String owmForecastHour24ConditionId "24h Vorhersage Wetterlage ID [%s]" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour24)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours24#condition-id"}
String owmForecastHour24IconId "24h Vorhersage Wetterlage Icon ID" <sun_clouds> /*(gOwmForecastHour,gOwmForecastHour24)*/ {channel="openweathermap:hourly-forecast:api:local:forecastHours24#icon-id"}
Number:Temperature owmForecastHour24Temperature "24h Vorhersage Temperatur [%.1f %unit%]" <temperature> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#temperature"}
Number:Pressure owmForecastHour24Pressure "24h Vorhersage Luftdruck [%.1f %unit%]" <pressure> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#pressure"}
Number:Dimensionless owmForecastHour24Humidity "24h Vorhersage Luftfeuchtigkeit [%.1f %unit%]" <humidity> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#humidity"}
Number:Speed owmForecastHour24WindSpeed "24h Vorhersage Windgeschwindigkeit [%.1f km/h]" <wind> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#wind-speed"}
Number:Dimensionless owmForecastHour24WindDirection "24h Vorhersage Windrichtung [SCALE(wind.scale):%s]" <wind> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#wind-direction"}
Number:Dimensionless owmForecastHour24Cloudiness "24h Vorhersage Bewölkung [%.1f %unit%]" <sun_clouds> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#cloudiness"}
Number:Length owmForecastHour24Rain "24h Vorhersage Regen [%.1f %unit%]" <rain> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#rain"}
Number:Length owmForecastHour24Snow "24h Vorhersage Schneefall [%.1f %unit%]" <snow> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#snow"}
DateTime owmForecastHour24Timestamp "24h Vorhersage Zeit [%1$tA, %1$td.%1$tm.%1$tY %1$tH:%1$tM]" <time> (gOwmForecastHour,gOwmForecastHour24) {channel="openweathermap:hourly-forecast:api:local:forecastHours24#time-stamp"}
// Forecast Hourly Station Details
String owmForecastHourStationId "Wetterstation ID" <house> (gOwmForecastHour,gOwmForecastHourStation) {channel="openweathermap:hourly-forecast:api:local:station#id"}
String owmForecastHourStationName "Wetterstation Name" <house> (gOwmForecastHour,gOwmForecastHourStation) {channel="openweathermap:hourly-forecast:api:local:station#name"}
Location owmForecastHourStationLocation "Wetterstation Geokoordinaten [%2$s,%3$s]" <house> (gOwmForecastHour,gOwmForecastHourStation) {channel="openweathermap:hourly-forecast:api:local:station#location"}
wind.scale in transform folder (be sure you have the transformation service activated in PaperUI
[0..11.25[ = N - Nord
[11.25..33.75[ = NNE - NordNordOst
[33.75..56.25[ = NE - NordOst
[56.25..78.75[ = ENE - OstNordOst
[78.75..101.25[ = E - Ost
[101.25..123.75[ = ESE - OstSüdOst
[123.75..146.25[ = SE - SüdOst
[146.25..168.75[ = SSE - SüdSüdOst
[168.75..191.25[ = S - Süd
[191.25..213.75[ = SSW - SüdSüdWest
[213.75..236.25[ = SW - SüdWest
[236.25..258.75[ = WSW - WestSüdWest
[258.75..281.25[ = W - West
[281.25..303.75[ = WNW - WestNordWest
[303.75..326.25[ = NW - NordWest
[326.25..348.75[ = NNW - NordNordWest
[348.75..360] = N - Nord
YOUR_SITEMAP.sitemap
Frame label="Lokales Wetter" {
Image item=owmCurrentIcon
Text item=owmCurrentCondition
/*Text item=owmCurrentConditionId
Text item=owmCurrentIconId*/
Text item=owmCurrentTemperature
Text item=owmCurrentPressure
Text item=owmCurrentHumidity
Text item=owmCurrentWindSpeed
Text item=owmCurrentWindDirection
Text item=owmCurrentCloudiness
Text item=owmCurrentRain
Text item=owmCurrentSnow
Group item=gOwmCurrentStation label="Lokales Wetter Station Details"
Group item=gOwmForecastHour label="Wetter Vorhersage" {
Frame label="3h Wetter Vorhersage" {
Image item=owmForecastHour03Icon
Text item=owmForecastHour03Condition
//Text item=owmForecastHour03ConditionId
//Text item=owmForecastHour03IconId
Text item=owmForecastHour03Temperature
Text item=owmForecastHour03Pressure
Text item=owmForecastHour03Humidity
Text item=owmForecastHour03WindSpeed
Text item=owmForecastHour03WindDirection
Text item=owmForecastHour03Cloudiness
Text item=owmForecastHour03Rain
Text item=owmForecastHour03Snow
Text item=owmForecastHour03Timestamp
Group item=gOwmForecastHour03 label="3h Wetter Vorhersage"
Group item=gOwmForecastHour06 label="6h Wetter Vorhersage"
Group item=gOwmForecastHour09 label="9h Wetter Vorhersage"
Group item=gOwmForecastHour12 label="12h Wetter Vorhersage"
Group item=gOwmForecastHour15 label="15h Wetter Vorhersage"
Group item=gOwmForecastHour18 label="18h Wetter Vorhersage"
Group item=gOwmForecastHour21 label="21h Wetter Vorhersage"
Group item=gOwmForecastHour24 label="24h Wetter Vorhersage"
Group item=gOwmForecastHourStation label="Wetter Vorhersage Station Details"
Have Fun! Cheers…
item definition e.g.
Location owmStationGeolocation "Wetterstation (Koordinaten)" <zoom> {
channel="openweathermap:weather:api:local:station#geolocation"
sitemap e.g.
// display map
Mapview item=owmStationGeolocation
// display text
Text item=owmStationGeolocation label="Koordinaten [Lat %2$s Long %3$s]"
@kugelsicha
That is working fine in my enviroment - does it work for you? ![]()
Awesome… never used those vars and never thought they exist… Yes that works for me aswell! Thank You!
I’m using it this way in my .items file:
Hi
I have problems with the channel for icon, I have no images and cant see any error in log.
Anyone have an example I can verify mine with?
Hi @Nanna_Agesen,
Did you see the post of @kugelsicha? It contains a working configuration for the icon.
Hi ![]()
Im using that example, everything works, except icons.
@Nanna_Agesen Okay. I have the slight feeling that you do not have the latest version of the OWMbinding installed. The channel for the icon has been introduced one month ago. Can you please verify your binding version?
Hi
I think you’re right i’m using this version 0.10.0.201806190707-SNAPSHOT, from the Eclipse Marked Place.
Do you have a link to a newer version?
Best
Nanna
Yes, of course. Here you are.
Thanks ![]()
I updated the binding, but there is no icon showing up - And I can’t any errors in log.
Do you have any other ideas?
Please try to recreate your weather and forecast things. New channels are not added automatically to an existing thing.
as Christoph already wrote:
and i noticed… if you change something in your items file… you sometimes need to wait for the binding to update those (new) items to receive a update from the api… up to half an hour…
I managed to get the Icons for Local Weather to work, as you wrote the channels were not updated.
However I can’t get the forecast to work, can you explain the best way recreate the weather and forecast thing?
in PaperUI OWM API thing make sure the 3 day forecast is active (should be by default):
then you need to add the new Thing and make sure its online:
