sorry, you are right. the communication is from home app to OH.
basically this line
says “0” (=Off) was sent from home app to OpenHAB for accessory with ID 1189018796 (you can check accessories IDs in karaf with “homekit listAccesories”)
this line
is the response from openHAB to home app saying “the change was successful”
there is nothing more in the log.
I’ve checked the aid, it’s the same as in listAccessoires. I also checked the difference between the working switch and the other one. The working is sending true and false value, the non-working 0 and 1.
It is identical.
Sorry for the screenshot. I’ve found no way to copy text on my iPad from ssh…
Edit: seem I was wrong. Here is the complete tracelog from the working switch. It also sends 0/1 and later there is another entry with true/false witch is missing in the other case.
ok. so, both ways - single line and group have created identical HomeKit items. communication seems to be ok as well. i would really check the other side - items -> things. maybe device does not accept “On” event and set it back to “off”.
Can anyone give me some hints how to use the name property?
Is it used to set the name how the item is presented on the iphone or am I not understanding this correctly?
Are you sure? The compiler says: The item of CurrentDoorState has to be CLOSE instead of CLOSED. On the official site Homekit Addon it is also mentioned as CLOSED. Could that be an error?
it was a bug/typo in the implementation. it was fixed 3 days with this commit
depending on which version you have you need to use “CLOSE” or “CLOSED”.
however, this mapping is configurable.
you can add this line to homekit.cfg to make your mapping, e.g. to “CL” instead of “CLOSE/CLOSED” doorCurrentStateClosed="CL"
Hi eugen @yfre,
I’ve got the On Characteristic working. I’ve found the solution in another thread. I completly commented the thing (Group and all Items) out and in, than it works.
Now I have the next problem, hope you can help.
My device I want to include into homekit is an Aeotec LED Stripe ZW121.
I have a
Dimmer for Brightness (0-100%)
Switch for On/Off
Color
Dimmer for White Color (0 (cold) - 100% (warm))
I can create a rule to convert the temperature Item from dimmer (0-100) to number (-50 - 400). But the documentation says, I should never use color and color temperatur in combination with hsb.
What is the best way to bring the device into homekit?
Edit: not tested, but I think I need a proxy Item (Color) and expose this to homekit. In a rule I need to split it into the temperature dimmer in case it is white and color in other cases.
the limitation is from Apple. apple writes in the spec
Color Temperature
This characteristic describes color temperature which is represented in reciprocal megaKelvin (MK-1) or mirek scale. (M = 1,000,000 / K where M is the desired mirek value and K is temperature in Kelvin). If this characteristic is included in the ”8.23 Light Bulb” (page 147), ”9.44 Hue” (page 179) and ”9.82 Saturation” (page 197) must not be included as optional characteristics in ”8.23 Light Bulb” (page 147). This characteristic must
not be used for lamps which support color.
this limitation is however not enforced by homekit binding, i.e. you can try it out and add Color Temperature, Hue and Brightness to the same accessory. Maybe it will work in home app. if not, i would split this one device in 2 different “lighting” accessories: one with Hue and brightness and another one with Color Temperature.
Group ledStripe "Aeotec LED Stripe" {homekit="Lighting"}
Switch ledStripeSwitch "Schalter" (ledStripe) {homekit="Lighting.OnState"}
Color ledStripeProxyColor (ledStripe) {homekit="Lighting.Hue, Lighting.Brightness, Lighting.Saturation"}
openhab> homekit printAccessory 1189018796
1189018796 Aeotec LED Stripe
Services:
Service Type: 00000043-0000-1000-8000-0026BB765291
Characteristics:
: class io.github.hapjava.characteristics.impl.common.OnCharacteristic
: class io.github.hapjava.characteristics.impl.lightbulb.HueCharacteristic
: class io.github.hapjava.characteristics.impl.lightbulb.BrightnessCharacteristic
: class io.github.hapjava.characteristics.impl.lightbulb.SaturationCharacteristic
This seems to be ok.
I’ve no linking to any “real” thing. On/Off and Dimming works as aspected. But choosing color is strange.
If I choose a color, the Item in background change also. But when I pull up my finger from the color chooser, the “bubble” jumps to an other position (the fullcolor position).
According to the documentation I tried also 3 Dimmer-Items, each for Hue, Saturation und Brightness, but it throws a error message, it is not supported.
i can confirm: your configuration is correct and i could reproduce your issue. it does not happen always but time to time.
it is an issue in the implementation of the binding. i have an idea to fix it but not sure whether it is a correct fix. so, opened a question in the developer channel.
thank you
it works with your sitemap,
but how do i do it when i have two items in openhab
open and close garage door
and one item for the state open and closed
it depends on your setup. i have a garage motor, which get “targetState”, and i have “contactSensor”, which is the current state.
if you dont have contact sensor that reports the door status, then you can have a rule which get triggered by TargetState changes sets currentState = CLOSING/OPENING and after sometime currentState=CLOSED/OPEN
