Hello all,
I have been struggling to get a semblance of a remote control (the buttons) with the UI. As you can’t mix HTML/Images with sitemaps (or am I missing something?) I came up with the following, but it is not ideal due to the font alignment. Does anyone have a better idea?
Sitemap:
Frame label='Controller Roku'
Switch item=rokunavigate mappings=['1'='__↰__','2'='___⬆___','3'='_HOME_']
Switch item=rokunavigate mappings=['4'='__⬅__','5'='__OK__','6'='___➨___']
Switch item=rokunavigate mappings=['7'='_PORN_','8'='___⬇___','9'='_PLEX__']
Switch item=rokunavigate mappings=['10'='___❮❮__','11'='_|| ❯_','12'='___❯❯___']
Item File:
Number rokunavigate
Switch Roku_home "Home" <video> (Roku_navigation, Dev) {http=">[*:POST:http://192.168.0.38:8060/keypress/home]", autoupdate="False"}
Switch Roku_plex "Plex" <plex> (Roku_navigation, Dev) {http=">[*:POST:http://192.168.0.38:8060/launch/dev?contentID=1]",autoupdate="False"}
Switch Roku_back "back" <control_return> (Roku_navigation, Dev) {http=">[*:POST:http://192.168.0.38:8060/keypress/back]",autoupdate="False"}
Switch Roku_up "Up" <arrow_up> (Roku_navigation, Dev) {http=">[*:POST:http://192.168.0.38:8060/keypress/up]", autoupdate="False"}
Switch Roku_down "down" <arrow_down> (Roku_navigation, Dev) {http=">[*:POST:http://192.168.0.38:8060/keypress/down]", autoupdate="False"}
Switch Roku_left "left" <arrow_left> (Roku_navigation, Dev) {http=">[*:POST:http://192.168.0.38:8060/keypress/left]", autoupdate="False"}
Switch Roku_right "right" <arrow_right> (Roku_navigation, Dev) {http=">[*:POST:http://192.168.0.38:8060/keypress/right]", autoupdate="False"}
Switch Roku_ok "select" <control_ok> (Roku_navigation, Dev) {http=">[*:POST:http://192.168.0.38:8060/keypress/select]", autoupdate="False"}
Switch Roku_playpause "Play/Pause" <arrow_pause> (Roku_controls, Dev) {http=">[*:POST:http://192.168.0.38:8060/keypress/play]", autoupdate="False"}
Switch Roku_ff "Fast Forward" <video> (Roku_controls, Dev) {http=">[*:POST:http://192.168.0.38:8060/keypress/fwd]", autoupdate="False"}
Switch Roku_fw "Rewind" <video> (Roku_controls, Dev) {http=">[*:POST:http://192.168.0.38:8060/keypress/rev]", autoupdate="False"}
Rule File:
rule "Remote Control Roku" when Item rokunavigate received command then if (receivedCommand==1) { sendCommand(Roku_back, ON)} else if (receivedCommand==2) { sendCommand(Roku_up, ON)} else if (receivedCommand==3) { sendCommand(Roku_home, ON)} else if (receivedCommand==4) { sendCommand(Roku_left, ON)} else if (receivedCommand==5) { sendCommand(Roku_ok, ON)} else if (receivedCommand==6) { sendCommand(Roku_right, ON)} else if (receivedCommand==7) {sendCommand(Roku_plex, ON) } else if (receivedCommand==8) { sendCommand(Roku_down, ON)} else if (receivedCommand==9) {sendCommand(Roku_porn, ON)} end
