Hi guys,
I am using two Danfoss LC13 thermostats in my living room. Currently they are controlled by some simple rules (set temperature up in the morning and down in the evening, weekdays and weekend separated). Additionally I am using a temperature sensor to get the current temperature.
This morning according to the rule the set temperature was correctly set to 21°C. Before it was 18°C. But as it’s quite warm outside, the current temperature already is 22.5°C in the room. So the radiators heat up, but because of the current temperature they didn’t need to.
What should help is some kind of intelligent control which regulates the set temperature based on the current temperature. Is this a logical approach or isn’t this possible? Is there anyone here with similar “problems”?
Thanks,
Stefan
