@hmerk Power is working, no other channels listed, minor issue with the setup recognising the default port value.
In detail the binding initially would not read the default port number from the setup going OFFLINE while in the background still attempting to keep alive.
2020-09-23 00:39:20.151 [WARN ] [me.config.core.internal.ConfigMapper] - Could not set field value for field 'port': Can not set java.lang.String field org.openhab.binding.intesis.internal.config.IntesisConfiguration.port to java.math.BigDecimal
java.lang.IllegalArgumentException: Can not set java.lang.String field org.openhab.binding.intesis.internal.config.IntesisConfiguration.port to java.math.BigDecimal
2020-09-23 00:39:20.183 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from UNKNOWN to ONLINE
2020-09-23 00:39:23.185 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from ONLINE to OFFLINE
2020-09-23 00:39:23.185 [ERROR] [s.internal.handler.IntesisBoxHandler] - openConnection(): Unable to open a connection: For input string: ""
java.lang.NumberFormatException: For input string: ""
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:1.8.0_222]
at java.lang.Integer.parseInt(Integer.java:592) ~[?:1.8.0_222]
2020-09-23 00:39:23.194 [ERROR] [s.internal.handler.IntesisBoxHandler] - write(): Unable to write to socket: null
2020-09-23 00:39:23.200 [INFO ] [s.internal.handler.IntesisBoxHandler] - keep alive sent
2020-09-23 00:39:23.203 [ERROR] [s.internal.handler.IntesisBoxHandler] - write(): Unable to write to socket: null
I typed in the PORT value and saved to overwrite the default and the binding came online (maybe a save was sufficient, don’t know)
2020-09-23 00:45:22.294 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from OFFLINE to UNKNOWN
2020-09-23 00:45:22.297 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from UNKNOWN to ONLINE
2020-09-23 00:45:25.296 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from ONLINE to OFFLINE
2020-09-23 00:45:25.312 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from OFFLINE to ONLINE
2020-09-23 00:45:25.311 [INFO ] [s.internal.handler.IntesisBoxHandler] - keep alive sent
2020-09-23 00:45:25.329 [INFO ] [s.internal.handler.IntesisBoxHandler] - LIMITS:ONOFF,[OFF,ON]
2020-09-23 00:45:25.331 [INFO ] [s.internal.handler.IntesisBoxHandler] - LIMITS:MODE,[AUTO,HEAT,DRY,FAN,COOL]
2020-09-23 00:45:25.333 [INFO ] [s.internal.handler.IntesisBoxHandler] - LIMITS:FANSP,[AUTO,1,2,3,4]
2020-09-23 00:45:25.335 [INFO ] [s.internal.handler.IntesisBoxHandler] - LIMITS:VANEUD,[1,2,3,4,SWING]
2020-09-23 00:45:25.339 [INFO ] [s.internal.handler.IntesisBoxHandler] - LIMITS:SETPTEMP,[180,300]
2020-09-23 00:45:25.347 [vent.ItemStateChangedEvent] - intesis_intesisBox_FJACWMP01_power changed from NULL to OFF
Just the Power channel is showing, disabled an re-enabled the binding in an attempt to refresh it.
2020-09-23 00:53:40.353 [INFO ] [s.internal.handler.IntesisBoxHandler] - keep alive sent
2020-09-23 00:53:47.269 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from ONLINE to UNINITIALIZED
2020-09-23 00:53:47.294 [ERROR] [s.internal.handler.IntesisBoxHandler] - read(): IO Exception: Socket closed
2020-09-23 00:53:47.299 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from UNINITIALIZED to OFFLINE
2020-09-23 00:53:47.353 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from OFFLINE to UNINITIALIZED (DISABLED)
2020-09-23 00:53:53.062 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2020-09-23 00:53:53.086 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from INITIALIZING to UNKNOWN
2020-09-23 00:53:53.101 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from UNKNOWN to ONLINE
2020-09-23 00:53:56.089 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from ONLINE to OFFLINE
2020-09-23 00:53:56.094 [INFO ] [s.internal.handler.IntesisBoxHandler] - keep alive sent
2020-09-23 00:53:56.095 [hingStatusInfoChangedEvent] - 'intesis:intesisBox:FJACWMP01' changed from OFFLINE to ONLINE
2020-09-23 00:53:56.111 [INFO ] [s.internal.handler.IntesisBoxHandler] - LIMITS:ONOFF,[OFF,ON]
2020-09-23 00:53:56.113 [INFO ] [s.internal.handler.IntesisBoxHandler] - LIMITS:MODE,[AUTO,HEAT,DRY,FAN,COOL]
2020-09-23 00:53:56.115 [INFO ] [s.internal.handler.IntesisBoxHandler] - LIMITS:FANSP,[AUTO,1,2,3,4]
2020-09-23 00:53:56.117 [INFO ] [s.internal.handler.IntesisBoxHandler] - LIMITS:VANEUD,[1,2,3,4,SWING]
2020-09-23 00:53:56.119 [INFO ] [s.internal.handler.IntesisBoxHandler] - LIMITS:SETPTEMP,[180,300]
After this just the keep alive every 45 sec.
The AC unit does respond the the power command
2020-09-23 00:57:39.362 [temChannelLinkRemovedEvent] - Link 'intesis_intesisBox_FJACWMP01_power => intesis:intesisBox:FJACWMP01:power' has been removed.
2020-09-23 00:57:41.113 [INFO ] [s.internal.handler.IntesisBoxHandler] - keep alive sent
2020-09-23 00:57:41.245 [WARN ] [s.internal.handler.IntesisBoxHandler] - Refresh channel power
2020-09-23 00:57:41.253 [.ItemChannelLinkAddedEvent] - Link 'intesis_intesisBox_FJACWMP01_power-intesis:intesisBox:FJACWMP01:power' has been added.
2020-09-23 00:57:53.254 [ome.event.ItemCommandEvent] - Item 'intesis_intesisBox_FJACWMP01_power' received command ON
2020-09-23 00:57:53.260 [nt.ItemStatePredictedEvent] - intesis_intesisBox_FJACWMP01_power predicted to become ON
2020-09-23 00:57:53.274 [vent.ItemStateChangedEvent] - intesis_intesisBox_FJACWMP01_power changed from NULL to ON
2020-09-23 00:59:44.474 [ome.event.ItemCommandEvent] - Item 'intesis_intesisBox_FJACWMP01_power' received command OFF
2020-09-23 00:59:44.479 [nt.ItemStatePredictedEvent] - intesis_intesisBox_FJACWMP01_power predicted to become OFF
2020-09-23 00:59:44.495 [vent.ItemStateChangedEvent] - intesis_intesisBox_FJACWMP01_power changed from ON to OFF
