Issue of the topic: please be detailed explaining your issue
I have OpenHabian 2.4 with the 2.5 SNAPSHOT ZWave binding installed:
openhab> list -s | grep zwave
216 │ Active │ 80 │ 2.5.0.201905250657 │ org.openhab.binding.zwave
Trying to get my Aotec NanoMote Quad recongized.
When I include it in the network, all seems to go well with the binding process, and the OEM/ID comes through clean: 0371:0102:0003:1.2)
When I check the online device database, that device isin the database however, the logs show it can’t be resolved:
2019-05-25 10:02:20.881 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 13: Device discovery could not resolve to a thingType! 0371:0102:0003::1.2
I was able to get some time @mhilbush and @chris to grab the debug logs for this device during inclusion and discovery. I did not need to exclude the device prior as I had reset the controller and then factory reset the device.
Line 415 seems to show it clearly
2019-05-28 20:02:21.468 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 16: Device discovery could not resolve to a thingType! 0371:0102:0003::1.2
I’m realizing in my debug logs I didn’t actuall yhave the 2.5 snapshot addon installed. I updated to that, but after a few minutes I get errors about a queue being full:
22:07:10.335 [ERROR] [ZWaveSerialHandler$ZWaveReceiveThread] - Exception during ZWave thread.
java.lang.IllegalStateException: Queue full
at java.util.AbstractQueue.add(AbstractQueue.java:98) ~[?:?]
at java.util.concurrent.ArrayBlockingQueue.add(ArrayBlockingQueue.java:312) ~[?:?]
at org.openhab.binding.zwave.internal.protocol.ZWaveTransactionManager.processReceiveMessage(ZWaveTransactionManager.java:404) ~[221:org.openhab.binding.zwave:2.5.0.201905250657]
at org.openhab.binding.zwave.internal.protocol.ZWaveController.incomingPacket(ZWaveController.java:1064) ~[221:org.openhab.binding.zwave:2.5.0.201905250657]
at org.openhab.binding.zwave.handler.ZWaveControllerHandler.incomingMessage(ZWaveControllerHandler.java:643) ~[221:org.openhab.binding.zwave:2.5.0.201905250657]
at org.openhab.binding.zwave.handler.ZWaveSerialHandler$ZWaveReceiveThread.run(ZWaveSerialHandler.java:323) [221:org.openhab.binding.zwave:2.5.0.201905250657]
I think I’ll just wait on using the button until 2.5 is baked.
Hi Criss, I wanted to ask you for advice on the products to buy to make the following function.
I have to adjust the dimming of a kitchen with a z-wave luxometer. As a dimmer I have a Bticino legrand 1-10v art F413N system that already works in Openhab. Depending on the lux I have to dim the light according to my taste.
I thank you in advance.
Hi, did you ever find a fix for this? I’m having the same issue and from what I can tell the device is in the database and it matches my XML file, but I’m new to this so I could be missing something. I’ve tried waking up the device and I see in the logs that it is reporting battery level so it is communicating somewhat.
