Apache Aries SPI Fly NPE
During testing on a Karaf test installation, when going through the logs, I found a NPE during “OSGi startup” that looks like a bug in SPI Fly:
2025-12-05 05:15:05.670 [DEBUG] [rg.apache.aries.spifly.BaseActivator] - Could not load provider org.apache.aries.jax.rs.whiteboard.internal.client.ClientBuilderImpl of service javax.ws.rs.client.ClientBuilder
java.lang.NullPointerException: Cannot invoke "java.util.Map.size()" because "m" is null
	at java.util.HashMap.putMapEntries(HashMap.java:503) ~[?:?]
	at java.util.HashMap.putAll(HashMap.java:791) ~[?:?]
	at org.apache.aries.spifly.BaseActivator.lambda$registerProviderBundle$3(BaseActivator.java:271) ~[bundleFile:1.3.7]
	at java.util.TreeMap.callRemappingFunctionWithCheck(TreeMap.java:792) ~[?:?]
	at java.util.TreeMap.remapValue(TreeMap.java:868) ~[?:?]
	at java.util.TreeMap.compute(TreeMap.java:719) ~[?:?]
	at java.util.Collections$SynchronizedMap.compute(Collections.java:2990) ~[?:?]
	at org.apache.aries.spifly.BaseActivator.registerProviderBundle(BaseActivator.java:264) ~[bundleFile:1.3.7]
	at org.apache.aries.spifly.ProviderBundleTrackerCustomizer.addingBundle(ProviderBundleTrackerCustomizer.java:173) [bundleFile:1.3.7]
	at org.apache.aries.spifly.ProviderBundleTrackerCustomizer.addingBundle(ProviderBundleTrackerCustomizer.java:64) [bundleFile:1.3.7]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:475) [osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:420) [osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [osgi.core-8.0.0.jar:?]
	at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450) [osgi.core-8.0.0.jar:?]
	at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:949) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.Module.publishEvent(Module.java:499) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.Module.doStart(Module.java:602) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.Module.start(Module.java:468) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [org.eclipse.osgi-3.18.0.jar:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345) [org.eclipse.osgi-3.18.0.jar:?]
I can’t really tell whether this has consequences for OH or not, but I would think that something isn’t working as a consequence.
Posting it here probably isn’t very useful, except in the off chance that somebody knows what’s causing this, but Apache have made registering for a Jira discouraging enough that I’m not going to do that just so it can stay around untouched for years or be autoclosed for inactivity after a while.
This way, it at least “exists out there” and can be found when searching.
