After installing the newest Openhab app using Testflight, I get this error. Resyncing or force quiting does not change anything. Watch-sitemap, loads perfectly fine on iPhone.
Any suggestions?
Did you sync when you were connected to your home network or through your mobile network ? I had a similar problem when I updated the OpenHAB app (testflight) connected to the mobile network. The syncing process did not allow me to use my sitemap. I switched on the VPN on my iphone, and suddenly the sitemap appeared. But I am not sure this was causality or just correlation ;-). Did you visit the parameters menu on the OpenHAB app iphone and select the sitemap for the apple watch ? Hope it helps.
I am on mobile indeed. You are right. When switching on the VPN it works. But only then!
Switching off the VPN and after resyncing, the problem persists.
And I reselected the sitemap in the IOS app. Did not solve the issue.
It still is a bug I think, which should be resolved. Thanks anyway.
