- Platform information:
- Hardware: RPi
- OH: OH 4.0.4
First Hue Bridge is connected to a router directly connected to the Frontier router.
New Hue Bridge is connected to a ‘bridge’ in another room.
I’ve added a second Hue bridge after hitting the max of 62 bulbs. The two bridges appear in the iOS app and I’m able to control lights on both bridges.
I added the second bridge to OH and I get a configuration error and have a missing application key. I’ve tried to press the button on the new Hue Bridge to populate the app key with no luck.
I tried going to the cli console without any luck and I’ve tried a curl command that I found on the search bar with no luck.
Is there any way to look up or manually assign an application key for a second Hue Bridge?
