Apt-get doesn't pull latest nightly, stuck on #456 Aug, 3
Hi guys,
I installed OH2 latest nightlies with via apt-get, see here as so kindly provided by @theo
https://community.openhab.org/t/oh2-on-rpi3/11317/9?u=lipp_markus
and just be clear my apt-sources include:
deb https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-offline/target/apt-repo/ /
When ever I try to update/upgrade
sudo apt-get update
sudo apt-get upgrade
my Pi tells me a new version of the snapshot is available downloads and installs it, but when I check in karaf it is built #456 from August 3.
My apologies if this is trivial and a user error, but I will appreciate any and all pointers.
Thanks and regards
Markus
Hi @lipp_markus,
may be this helps: Installing Extensions fails with "org.osgi.service.resolver .ResolutionException" - #9 by theo for now.
Regards,
Theo
Hi @theo,
Much appreciate your help prompt response, thanks!!
I am still stuck, however, at built #456 (3. Aug); I tried a variety of reinstall, remove and new install, etc etc
One of the strange things is in the past-weeks whenever i performed and update/upgrade seemingly a new snapshot was downloaded and installed as I was always presented with a remark of a file size difference. When I go into karaf, however, the same built-number is displayed, no matter what.
Unless there is another idea, I guess I will try the install method with @xsnrg’s OH2-tools https://github.com/xsnrg/OpenHAB2-tools
In the meanwhile, thanks so much again
Markus
Hi Markus,
quick remark, not sure if relevant: As I understand cloudbees, built #456 is from yesterday (25.08.). The built from 3rd August is #437. So perhaps you have the most recent version and karaf just gives you a wrong date.
You can check the version numbers using the list command in the console. The built date ist part of the verison number:
211 | Active | 80 | 1.9.0.201608250111 | openHAB MapDB Persistence Bundle
Joerg
Hi Joerg,
Thanks so much.
I am not sure what is going on thought, how can my build #456 and karaf puts the dates of all openhab things much earlier?
                         __  _____    ____
  ____  ____  ___  ____  / / / /   |  / __ )
 / __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __  |
/ /_/ / /_/ /  __/ / / / __  / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/  |_/_____/
    /_/                        2.0.0-SNAPSHOT
                               Build #456
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> bundle:list | grep openHAB
160 | Active   |  90 | 2.0.0.201608032032    | openHAB Core
161 | Active   |  80 | 2.0.0.201608032032    | openHAB Karaf Integration
181 | Active   |  80 | 2.0.0.201608032032    | openHAB REST Documentation
182 | Resolved |  80 | 2.0.0.201608032032    | openHAB Basic UI Fragment, Hosts: 178
183 | Active   |  80 | 2.0.0.201608032032    | openHAB Classic UI Fragment
184 | Active   |  80 | 2.0.0.201608032032    | openHAB Dashboard UI
185 | Resolved |  80 | 2.0.0.201608032032    | openHAB Paper UI Theme Fragment, Hosts: 180
190 | Active   |  80 | 2.0.0.201608032032    | openHAB 1.x Compatibility Layer
191 | Active   |  80 | 1.9.0.201608170111    | openHAB RRD4j Persistence Bundle
192 | Active   |  80 | 1.9.0.201608170111    | openHAB NetworkUpsTools Binding
198 | Active   |  80 | 1.9.0.201607280110    | openHAB pilight Binding
Please note build number and dates below…does not compute.
But maybe I don’t need to understand everything.
Thanks so much for your help
