After updating to 3.2 added 4 more multisensors from Aqara. Everything went good except that on the four newly added sensors, there’s no battery level and no low battery channel. On the Conbee II UI battery information ist present.
Conbee 2 UI:
I have the same problem with my eurotronic spirit thermostat.
Everything is there, just the battery channels are missing. It is the same behavior you described. The API is providing it.
I had the same problem. Had read somewhere that the channels for battery status and battery alarm need some time to appear.
So I configured my Aqara things and items without the battery information.
Because of your new posts I remembered the problem and checked, if the channels are now available. They are!
