I see there is a pentair pool binding but I have an older pool controller with a PDA. I’ve been using AqualinkD for years and it works great. I’m new to openHAB and I’m trying to use the MQTT binding to control AqualinkD, There is information on the AqualinkD wiki for MQTT and instructions to set it up with homekit. Has anyone else connected AqualinkD to openHAB? Any advice? Is there a way to import the homekit2mqtt.json into openHAB?
There is no way to import a JOSN file for Homekit into openHAB. openHAB is not Homekit.
But that wiki page documents all the MQTT topics and the type of data that is publishes or expected on each one. So you’ll create a Generic MQTT Thing and set up a Channel for each topic you care about. Then you’ll link Items to those Channels and the rest of OH will interact with the Items.
See Adding Things - Advanced | openHAB for a brief example for creating a Generic MQTT Thing and Channels.
MQTT is a one of the lower level bindings. You have to do most of the set up by hand which makes it harder to use. But it makes it much more flexible and able to handle odd situations and cases where people use MQTT in odd ways.
A great tool to help building your Channels is MQTT Explorer (https://mqtt-explorer.com/).
There you see what’s going on and the actual topics and states. Then you can transfer them into the openhab configuration.
OK figured out how to set up the channels
UID: mqtt:topic:broker:aqualinkd
label: aqualinkd
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:broker
channels:
- id: Filter_Pump
channelTypeUID: mqtt:switch
label: Filter Pump
description: ""
configuration:
commandTopic: aqualinkd/Filter_Pump/set
stateTopic: aqualinkd/Filter_Pump
off: "0"
on: "1"
- id: Spa_Mode
label: Spa Mode
description: ""
configuration:
commandTopic: aqualinkd/Spa_Mode/set
stateTopic: aqualinkd/Spa_Mode
off: "0"
on: "1"
- id: Aux_1
label: Cleaner
description: ""
configuration:
commandTopic: aqualinkd/Aux_1/set
stateTopic: aqualinkd/Aux_1
off: "0"
on: "1"
- id: Aux_4
label: Pool Light
description: ""
configuration:
commandTopic: aqualinkd/Aux_4/set
stateTopic: aqualinkd/Aux_4
off: "0"
on: "1"
- id: Aux_5
label: Spa Light
description: ""
configuration:
commandTopic: aqualinkd/Aux_5/set
stateTopic: aqualinkd/Aux_5
off: "0"
on: "1"
- id: Freeze_Protect
label: Freeze Protect
description: ""
configuration:
stateTopic: aqualinkd/Freeze_Protect/enabeled
off: "0"
on: "1"
- id: Pool_Heater
label: Pool Heater
description: ""
configuration:
commandTopic: aqualinkd/Pool_Heater/set
stateTopic: aqualinkd/Pool_Heater/enabled
off: "0"
on: "1"
- id: Spa_Heater
label: Spa Heater
description: null
configuration:
commandTopic: aqualinkd/Spa_Heater/set
stateTopic: aqualinkd/Spa_Heater/enabled
off: "0"
on: "1"
- id: Temperature_Air
channelTypeUID: mqtt:number
label: Air Temperature
description: ""
configuration:
stateTopic: aqualinkd/Temperature/Air
unit: F
- id: Temperature_Pool
label: Pool Temperature
description: null
configuration:
stateTopic: aqualinkd/Temperature/Pool
unit: F
- id: Temperature_Spa
label: Spa Temperature
description: null
configuration:
stateTopic: aqualinkd/Temperature/Spa
unit: F
- id: Pool_Heater_setpoint
label: Pool Heater setpoint
description: ""
configuration:
commandTopic: aqualinkd/Pool_Heater/setpoint/set
unit: F
min: 36
stateTopic: aqualinkd/Pool_Heater/setpoint
max: 104
- id: Spa_Heater_setpoint
label: Spa Heater setpoint
description: null
configuration:
commandTopic: aqualinkd/Spa_Heater/setpoint/set
unit: F
min: 36
stateTopic: aqualinkd/Spa_Heater/setpoint
max: 104
- id: Freeze_Protect_setpoint
label: Freeze Protect setpoint
description: null
configuration:
commandTopic: aqualinkd/Freeze_Protect/setpoint/set
unit: F
min: 34
stateTopic: aqualinkd/Freeze_Protect/setpoint
max: 42
- id: Freexe_Protect_active
label: Freexe Protect active
description: null
configuration:
stateTopic: aqualinkd/Freexe_Protect
off: "0"
on: "1"
- id: Pool_Heater_active
label: Pool Heater active
description: null
configuration:
off: "0"
on: "1"
- id: Spa_Heater_active
label: Spa Heater active
description: null
configuration:
off: "0"
on: "1"
