ASCII string to multiple integer or float values
Hello everybody
I have an Elsner weather station that sends me all their values combined as one single ASCII string every second by TCP.
e.g. W+05.5525280N99921.5N7121117170710N45780x03
(I know the exact positions of each value and the checksum.)
W = Start
0x03 = end marker
I managed to read the string as a whole with the TCP/UDP binding. But as an OH2 newbie I have no clue how to parse the string and save the values to seperate items (types: Number, String and Switch)
I know there are several transformation methods. But which one is the most suitable for me? And on which level should this conversion be performed? As a rule? RegEx?
(I have a working Grafana and InfluxDB setup and would like to store the weather data and control my heat pump.)
I searched this community but now I’m more confused than smarter.
TIA Matthias
Have a look into this thread ([SOLVED] How to split a string in a rule - #7 by rswennen)
Hallo Jürgen
I’ll give it a try.
But my content is not separated by a delimiter. Some values consist of 2 others of 8 bytes.
I would like to extract from position x to position y and save the content to an item.
Matthias
I would probably use a REGEX though.
Sorry for my delay. I was traveling abroad. Thank you very much for you help.
I found a way to preprocess the output (on the MODBUS master device) of the weather station and separate the values with a delimiter (e.g. ‘;’)
This makes it easier to extract the values I need
e.g. W;+05.5;5;252;80:N; -…
I’ll try to implement this as soon as I find some time during the weekend.
Matthias
