Askoma in Openhab 4.3.5
I had a working environment in openhab 3. Set up according to HTTP Binding
Things:
Thing http:url:askoheat "HTTP Askoheat" [
    baseURL="http://192.168.192.92/",
    authMode="BASIC",
    ignoreSSLErrors=false,
    refresh=30,
    timeout=3000,
    bufferSize=2048,
    delay=0,
    stateMethod="GET",
    commandMethod="GET"] {
        Channels:
         Type number : wassertemp "Wassertemperatur" [
             stateExtension="getval.json",
             stateTransformation="JSONPATH:$.MODBUS_VAL_TEMPERATURE_SENSOR0",
             mode="READWRITE"]
         Type number : errorstatus "Error Status" [
             stateTransformation="JSONPATH:$.MODBUS_VAL_ERROR_STATUS",
             mode="READWRITE"]
         Type number : heaterload "Heater Load" [
             stateTransformation="JSONPATH:$.MODBUS_VAL_HEATER_LOAD",
             mode="READWRITE"]
         Type number : legiostatus "Legio Status" [
             stateTransformation="JSONPATH:$.MODBUS_VAL_LEGIO_STATUS",
             mode="READWRITE"]
         Type string : legiopasttime "Legio Past Time" [
             stateTransformation="JSONPATH:$.MODBUS_VAL_LEGIO_PAST_TIME",
             mode="READWRITE"]
         Type number : status "Status" [
             stateTransformation="JSONPATH:$.MODBUS_VAL_STATUS",
             mode="READWRITE"]
Items:
// Heizung *********************************************************************************************************************************************
// Typ    Name                               "Label"                                                   <Category>       (Gruppe)               {channel}
Number    Wassertemperatur                   "Wassertemperatur[%.0f °C]"                               <temperature>    (gHeizung)             {channel="http:url:askoheat:wassertemp"}
Number    Heater_Load                        "Last Heizung[%.0f W]"                                    <radiator>       (gHeizung)             {channel="http:url:askoheat:heaterload"}
Number    Error_Status                       "Error Status[%.0f]"                                      <status>         (gHeizung)             {channel="http:url:askoheat:errorstatus"}
Number    Heizung_Status                     "Heizung Status[%.0f]"                                    <status>         (gHeizung)             {channel="http:url:askoheat:status"}
Number    Legio_Status                       "Legio Status[%.0f]"                                      <status>         (gHeizung)             {channel="http:url:askoheat:legiostatus"}
String    Legio_Past_Time                    "Legio zuletzt aktiv"                                     <time>           (gLegio)               {channel="http:url:askoheat:legiopasttime"}
After upgrading to OH 3.4.5 this does not work anymore.
I get the following errors:
17:57:49.792	WARN	org.openhab.core.thing.binding.generic.ChannelTransformation$TransformationStep	Failed to use TransformationStep{serviceName='JSONPATH', function='$.MODBUS_VAL_TEMPERATURE_SENSOR0'}, service not found
17:57:49.793	WARN	org.openhab.core.thing.binding.generic.ChannelTransformation$TransformationStep	Failed to use TransformationStep{serviceName='JSONPATH', function='$.MODBUS_VAL_LEGIO_PAST_TIME'}, service not found
17:57:49.793	WARN	org.openhab.core.thing.binding.generic.ChannelTransformation$TransformationStep	Failed to use TransformationStep{serviceName='JSONPATH', function='$.MODBUS_VAL_ERROR_STATUS'}, service not found
17:57:49.793	WARN	org.openhab.core.thing.binding.generic.ChannelTransformation$TransformationStep	Failed to use TransformationStep{serviceName='JSONPATH', function='$.MODBUS_VAL_STATUS'}, service not found
17:57:49.794	WARN	org.openhab.core.thing.binding.generic.ChannelTransformation$TransformationStep	Failed to use TransformationStep{serviceName='JSONPATH', function='$.MODBUS_VAL_LEGIO_STATUS'}, service not found
17:57:49.794	WARN	org.openhab.core.thing.binding.generic.ChannelTransformation$TransformationStep	Failed to use TransformationStep{serviceName='JSONPATH', function='$.MODBUS_VAL_HEATER_LOAD'}, service not found
I also tried to add the things and item through the GUI, not working either.
Does anybody have an Idea what I am doing wrong?
The JSONPATH add-on is not installed or it’s installation is corrupted. If the add-on in showing as being installed, clear the cache. If not, install it.
Thank you very much for your help.
