Hello, I used to have this script that updated the status of my door lock from ‘Alarmraw’ event.
I am aware that the function ‘triggeringItem’ has changed now. I do not know how to convert this to the new script standard.
import org.openhab.core.model.script.ScriptServiceUtil
rule "Lock: Update lock states after alarm_raw event"
Item EntryLock_AlarmRaw received update
val actionItem = ItemRegistry.getItem(triggeringItem.name.toString.replace("_AlarmRaw",""))
logInfo("Rules", "Lock: Alarm events: {}=[{}]",actionItem.name,triggeringItem.state.toString)
val StringBuilder message = new StringBuilder(actionItem.name)
switch (transform("JSONPATH","$.type",triggeringItem.state.toString)) {
case "ACCESS_CONTROL" : {
switch (transform("JSONPATH", "$.event", triggeringItem.state.toString)) {
case "1": {
actionItem.postUpdate(ON)
message.append(" updated to ON (locked)")
case "2": {
actionItem.postUpdate(OFF)
message.append(" updated to OFF (unlocked)")
case "11" : {
actionItem.postUpdate(OFF)// jammed could mean unlocked, so I do this for safety... you may want to send an alert here too
message.append(" is jammed, so setting lock to OFF (unlocked)")
default : {
message.append(" unknown door lock Event, ").append(triggeringItem.state.toString)
if (transform("JSONPATH", "$.event", triggeringItem.previousState(true).state.toString) == "11" && transform("JSONPATH", "$.event", triggeringItem.state.toString) != "11") {
message.append(" and is no longer jammed")
case "BURGLAR" : {
message.append(" has detected an intruder")
case "POWER_MANAGEMENT" : {
message.append(" received a Power Management alarm, ").append(triggeringItem.state.toString)
default : {
message.append(" received and unknown Type in alarmRawParser, ").append(triggeringItem.state.toString)
logInfo("Rules", "Lock: Alarm events: {}", message.toString)
Edit: I am converting this to OH3 DSL Script. The example below shows only one item updates but I am keeping it general since I have multiple items that uses the same script. Currently, i get this error in OH3: cannot invoke method public abstract java.lang.String org.openhab.core.items.Item.getName() on null
Okay, you no longer get a triggeringItem implicit variable in OH3 DSL rules unless you have a Member of type trigger.
So for multiple lock Items you can put them in a Group and have one rule operating from Member of.
If your rule triggers from ordinary Item xxx, then you get triggeringItemName implicit variable. This is new and you might need OH3 Milestone1 or something.
Create an item as you did with your other items and don’t link it to a channel.
Creating is possible via the blue + symbol in the lower rigth corner of the items page or via the subpage “Add items via textual definition” which takes the syntax from the .items files of OH2.
I created the virtual switches and can see them in the Items list.
How do I use the virtual switch in a Rule? I can’t add it to a Model so it doesn’t show up in the Rules “Item Event” and it doesn’t show up as a “Thing” in the Thing list.
So neither response actually answered the question.
I can see the switch in the ITEM list. When I go to add an ACTION under the Rules, I select ITEM Action and it is looking for ITEMS in the MODEL definition.
So, I go to the MODEL definitions, and I can only add THINGS.
Try to check the Show non-semenatic on the lower bound of the sub-window. If your virtual item is member of a group you need to open this group to see your item.
Little late on the update, I resolved the a while back. Putting the code as a reference to anyone who needs a example.
val actionItem = triggeringItem.name.replace("_AlarmRaw","")
logInfo("Rules", "Lock: Alarm events: {}=[{}]",actionItem,triggeringItem.state.toString)
val StringBuilder message = new StringBuilder(actionItem)
case "1": {
actionItem.postUpdate("ON")
case "2": {
actionItem.postUpdate("OFF")
case "11" : {
actionItem.postUpdate("OFF")// jammed could mean unlocked, so I do this for safety... you may want to send an alert here too
default : {
case "BURGLAR" : {
default : {
