The wiki page appears to lack the configuration information. Try creating a file services/asterisk.cfg containing:
############################### Asterisk Binding ######################################
# Please note: The Asterisk Management Interface (AMI) has to be activated in the
# manager.conf file of your Asterisk PBX.
# hostname of the AMI
#host=
# the username and password to login to the AMI
#username=
#password=
and supply the correct values for the configuration parameters, and remove the # that precedes them.
You can find a recent build here. With the upcoming openHAB 2.0.0 release, there will be a more official way to get the JAR. Generally, the 1.8.3 versions of 1.x addons will not work properly under openHAB 2.
Oh Can you share the tutorial how to setup Asterisk server ? As you said, Iâd rather not to install asterisk on my rasp, right?
I did google to see what should I do to create a Asterisk server, but all of them are about installing asterisk at the beginning, so this makes me confused!
Thanks alot
Why you would use the Asterisk binding without a running Asterisk?
Do you know what the Asterisk does?
It is no Problem to install Asterisk before or after Openhab on the same Raspi.
It is no need to install the Asterisk on the Raspi where Openhab runs, but if you got no running Asterisk, then it is okay to install Asterisk on the same Raspi. Or another Raspi lying around
The first and second step are up to you and unrelated to openHAB. Please feel free to come back here with any question related to step three, we will be happy to assist with problems at that point.
