Astro 1.9 Binding Missing?
I migrated from astro1 to astro2 today, looks like everything is working fine.
Note that the most current docs are here (docs.openhab.org is not updated yet):
https://github.com/openhab/openhab2-addons/tree/master/addons/binding/org.openhab.binding.astro
Events do work now, but they are triggered differently:
rule "example trigger rule"
    Channel 'astro:sun:home:rise#event' triggered START
Delayed events are not supported, but I made it working using the new expire binding:
items:
Switch Dawn15mDelay_Proxy "Dawn 15m delay" {expire="15m,command=ON"}
rule:
rule "civil Dawn delay"
    Channel 'astro:sun:home:civilDawn#event' triggered START
    Dawn15mDelay_Proxy.sendCommand(OFF) //delays dawn event for xx minutes
then trigger on Dawn15mDelay_Proxy which state will be ON after -in this case- 15 minutes.
Maybe there is a better way but this one was the easiest for me.
If you are using transformation mapping, the events are coming in now upper case, you need to change in your .map file f.e.
Autumn=Herbst to AUTUMN=Herbst
